TLV76701DRVR Schematic review
 This is a 5V to 2.5V circuit using the TLV76701DRVR chip. Can you help me check if there are any issues
  • Dear
    I  assume that you set VFB  as 0.8 V, Output current as 100 mA and IFB = as 50  n A .
    Importantly, I suggest you to add a Cout which is a key point ,and its value range is from 1 uf to 220 uf.
    After that, you can please take a simulator for your design.
