TPS74801DRCR the month of body marking is different from the month on label, could you please advise if this is a normal situation and explain the reason if possible?
For TPS74801DRCR, we bought a reel that it's week code on label is 2216+ which is in April of 2022 and it also shows 24 on label which should mean April of 2022, but the body marking on chips are 25, which should mean May of 2022.
So the month of body marking is different from the month on label.
Please help advise if it is a normal situation and explain the reason if possible, thanks!
