TPIC6A596: high failure rate problem
Part Number: TPIC6A596
During our functional test, we found the serious defects with I/O function fail.The defects were found with the same Trace code “3BA4TCT”. We tried to swap with different trace code"3BA5SPT",and proceeded the test.There’re 8 pcs PCBAs were re-mounted with different trace code IC, and the test results all showed pass.
We also took the different trace code unites to proceed X-ray for compare, and found the inner layout had difference.
WHY IT WOULD HAPPEN?
  • 您好
    感谢您对TI产品的关注!
    TI 论坛旨在解决客户在使用TI产品设计过程中遇到的技术问题。
    您的问题属于工艺和芯片质量问题范畴。
    建议您请按照以下方式联系客户支持部门,会有客服为您提供帮助。
    打开链接ticsc.service-now.com/csm
    点击“申请新的支持”下面的“提交申请”按钮
    在新打开的窗口中点击“质量,可靠性和环境信息”下面的“创建案例”按钮
    在打开的表格中您可以使用中文描述您的问题并且递交。
    会有专员为您服务。
