Other Parts Discussed in Thread: LM5160A, LM5160-Q1, LM5160, LM5161-Q1, LM5169, LM5168, LM5168-Q1, LM5161, LM5169-Q1
If you want to design a 1W(0.13A) Flybuck power supply, which IC chip is more appropriate?
Hi
Ti has these 9 chips with Flybuck topolopy.
https://www.ti.com/compare-products/?id=360082&type=GPT&partList=LM5169,LM5169-Q1,LM5168-Q1,LM5168,LM5161,LM5161-Q1,LM5160-Q1,LM5160A,LM5160&columnList=-2,1498,1192,3316,2954,1130,1129,1241,451max,238min,238max,20min,20max,2192,1077,634min,634max
Here is a Technical Article about Create a Fly-Buck Converter in WEBENCH® Power Designer
Hi
A long long time ago, webench was designed to support multi-channel output, but now it no longer supports it.
This article is relatively old and webench may have many differences.
Please refer to the current webench.
