Both pins are OC gate. Can I connect them together, to give out reset signal to MCU either power rail fall or watchdog timeout?
Hi,
Thank you for your interest in TI products! In order to solve your problem more effectively, we recommend that you post your problem on the E2E English Technical Forum (https://e2e.ti.com/p/addpost), and the senior English forum engineers will help you.
