TPS62816-Q1: tps62816-q1 support parallel output or not?
Part Number: TPS62816-Q1
Hi,
TPS62816-Q1 support voltage tracking, if the output voltage same, can be parallel output to support high current?
if not, what's the reason?
If Yes, for load transient response, two chip response similar?
best regards,
jeff wang
