LP87745-Q1: functional safety disable CAN PHY via nSTB ?
Part Number: LP87745-Q1
Hi,
The picture below is from 《Functional Safety Manual for LP87745-Q1》Revision A (November 2022)。
I am confused if we use nINT to disable CAN PHY via nSTB,  TCAN1043 transitions into go-to-sleep mode, finally change to sleep mode and the INH pin goes to a high impedance state.
Then the power of radar will be disabled, is this procedure correct?
Thanks.
