When using the backup drive channel to detect temperature with NTC, ENOUTXn is 1 and PWM is maximum. Will the chip report an open circuit fault?
Hi,
What is your channel voltage range? PWM is maximum means 100%?
Please see the LED open-circuit fault detection criteria, and 6.3.6.8 LED Open-Circuit Diagnostics in NORMAL state of the datasheet. The open fault can be triggered under certain conditions. Many thanks!
