Other Parts Discussed in Thread: LM5113
Hello, I will only use LM5113-Q1 as a high side driver, with an output of 12V and a PWM waveform with a bias of 5V. As shown in the attached schematic below, when the output has a bias of 5V, it is not possible to output a 12V PWM waveform with a bias of 5V. When the bias of 5V is removed, a normal 12V PWM waveform can be output. May I ask what caused this? How can I solve this problem?
