Thank you. OK,I'll try it.
I also want to know, if I have adjusted registers on LP50 GUI,then I saved the data.But how can I use these data in my own program?
Hi,
The data saved from the LP50 GUI, actually it's only used by LP50 GUI. If customer wants to use these data in their own program. They can read and understand by themselves and manually write the code for their program.
BR
