Hi,
I need to change REG reset value(for example, change REG Chargecurrent reset value from 0x0080h to 0x0A00(5A)), what should i do,? waitting for your kind answer, thank you~
Hi
Unfortunately, the default value could not change, it is hard-coded inside the part, however, the customer is free to change any register values after power up.
