When operating in battery mode, there is a leakage voltage of 0.8V across both ends of the inductor after powering on. Is this normal?
I attempted to remove Q4 and the input sense resistor, but after powering on and entering the system, I still observed a persistent 0.8V leakage voltage across the inductor. Currently suspecting it might be originating from the charger IC itself. Is this behavior normal?
