TPS61088: TPS61088RHLR
Part Number: TPS61088
TPS61088RHLR   What does ANCT mean on product MARKING?
  • Hi,
    Regarding device labeling query, please refer to: www.ti.com.cn/.../partlookup.tsp
    The TI forum aims to address technical issues encountered by customers during the use of TI products. We suggest that you contact the customer support department using the following methods, as there will be customer service available to assist you.
    • Open the link ticsc.service-now.com/csm
    • Click on the 'Submit Application' button under 'Apply for New Support'
    • Click the "Create Case" button under "Other" in the newly opened window
    • In the opened form, you can describe your problem in Chinese and submit it.
