DM8168 nsf_link 没有降噪效果
你好,
      我在用DM8168,Link的架构如下所示
      DEI -> Merge -> Dup -> Nsf -> Enc
      我把 nsfParam[].bypassNsf = FALSE,看到nsf_Link_drv.c中有一些对nsf参数的配置
        //nsfProcCfg->temporalStrength = VPS_NSF_PROCESSING_CFG_DEFAULT;         //nsfProcCfg->temporalTriggerNoise = VPS_NSF_PROCESSING_CFG_DEFAULT;         //nsfProcCfg->noiseIirCoeff = VPS_NSF_PROCESSING_CFG_DEFAULT;         //nsfProcCfg->maxNoise = VPS_NSF_PROCESSING_CFG_DEFAULT;         //nsfProcCfg->pureBlackThres = VPS_NSF_PROCESSING_CFG_DEFAULT;         //nsfProcCfg->pureWhiteThres = VPS_NSF_PROCESSING_CFG_DEFAULT;
    但是我发现 nsfParam[].bypassNsf = FALSE 或者  nsfParam[].bypassNsf = TRUE,也就是bypassNsf或者不bypassNsf,图像噪点没有任何变化,
   请问这是什么原因?谢谢!
  • 你好,
    下面是NSF相关配置寄存器在不同去噪等级下的值,请尝试:
        // Level 1
            0x00001001u,
            0x00000000u,
            0x00000C0Cu,
            0x14141414u,
            0x0000060Bu,
            0x000000ADu,
            0x00001616u,
            0x00000000u,
            0x00000000u,
            0x00000000u,
        // Level 2
            0x00001001u,
            0x00000000u,
            0x00001010u,
            0x18181818u,
            0x0000060Fu,
            0x000000ADu,
            0x00001616u,
            0x00000000u,
            0x00000000u,
            0x00000000u,
        // Level 3
            0x00001001u,
            0x00000000u,
            0x00001212u,
            0x1C1C1C1Cu,
            0x00000612u,
            0x000000CDu,
            0x00001616u,
            0x00000000u,
            0x00000000u,
            0x00000000u,
        // Level 4
            0x00001001u,
            0x00000000u,
            0x00001414u,
            0x1E1E1E1Eu,
            0x00000614u,
            0x000000DDu,
            0x00001616u,
            0x00000000u,
            0x00000000u,
            0x00000000u,
        // Level 5
            0x00001001u,
            0x00000000u,
            0x00001616u,
            0x20202020u,
            0x00000616u,
            0x000000FDu,
            0x00001616u,
            0x00000000u,
            0x00000000u,
            0x00000000u,
        // Level 6
            0x00001001u,
            0x00000000u,
            0x00001616u,
            0x20202020u,
            0x00000630u,
            0x000000FDu,
            0x00001616u,
            0x00000000u,
            0x00000000u,
            0x00000000u,
        // Level 7
            0x00001001u,
            0x00000000u,
            0x00003030u,
            0x30303030u,
            0x00000630u,
            0x000000FDu,
            0x00001616u,
            0x00000000u,
            0x00000000u,
            0x00000000u,
        // Level 8
            0x00001001u,
            0x00000000u,
            0x00004040u,
            0x40404040u,
            0x00000630u,
            0x000000FDu,
            0x00001616u,
            0x00000000u,
            0x00000000u,
            0x00000000u,
  • 你好,
    请问这些寄存器要写到哪里去。我只在nsfLink_drv.c中发现了这些,但是个数对应不上,请明示,谢谢!
            nsfProcCfg->frameNoiseAutoCalcEnable =             (nsfProcCfg->bypassMode == VPS_NSF_DISABLE_SNF_TNF) ? FALSE : TRUE;         nsfProcCfg->frameNoiseCalcReset = FALSE;         nsfProcCfg->subFrameModeEnable = FALSE;         nsfProcCfg->numLinesPerSubFrame = 128;
            for (i = 0; i < 3; i++)         {             nsfProcCfg->staticFrameNoise[i] = 0;             nsfProcCfg->spatialStrengthLow[i] = VPS_NSF_PROCESSING_CFG_DEFAULT;             nsfProcCfg->spatialStrengthHigh[i] = VPS_NSF_PROCESSING_CFG_DEFAULT;         }
            nsfProcCfg->temporalStrength = VPS_NSF_PROCESSING_CFG_DEFAULT;         nsfProcCfg->temporalTriggerNoise = VPS_NSF_PROCESSING_CFG_DEFAULT;         nsfProcCfg->noiseIirCoeff = VPS_NSF_PROCESSING_CFG_DEFAULT;         nsfProcCfg->maxNoise = VPS_NSF_PROCESSING_CFG_DEFAULT;         nsfProcCfg->pureBlackThres = VPS_NSF_PROCESSING_CFG_DEFAULT;         nsfProcCfg->pureWhiteThres = VPS_NSF_PROCESSING_CFG_DEFAULT;
  • Guanghui,
    请参考DVRRDK_04.01.00.02\ti_tools\device_collateral\dm816x目录下hdvpss文档里面NF的十个寄存器的地址。之前提供的就是这十个NF寄存器需要配置的不同滤波强度的值。
