AM3517 GPMC访问CPLD的问题
Other Parts Discussed in Thread: AM3517, SYSCONFIG
我使用的是AM3517 CPU, GPMC的CS3 上挂了CPLD器件,使用同步方式16bit NOR-Like device访问.
我配置了地址线寄存器,数据线寄存器,CS线寄存器,nADV_ALE, nOE, nWE, gpmc_clk
然后配置GPMC的寄存器。
现在遇到了这样的问题:
1. 读取数据时,从示波器上看,只GPMC_CLK线上只发送了一次clock,数据被正确读出,然后就再也不发clock了,是什么原因呢?
如下是我的配置代码,哪里有问题吗?
#define         NAND_PADCONF_SDRC_DQS3_CLR              0x0000FFFF
   #define         NAND_PADCONF_SDRC_DQS3_EN               (AM3X_CTRL_PADCONF_INPUT_DIS1       |    \
                                                            AM3X_CTRL_PADCONF_PULLTYPE_DOWN1   |    \
                                                            AM3X_CTRL_PADCONF_PULLTYPE_DIS1    |    \
                                                            AM3X_CTRL_PADCONF_MODE0_1)
   #define         NAND_PADCONF_GPMC_A2_EN                 (AM3X_CTRL_PADCONF_INPUT_DIS0       |    \
                                                            AM3X_CTRL_PADCONF_PULLTYPE_DOWN0   |    \
                                                            AM3X_CTRL_PADCONF_PULLTYPE_EN0     |    \
                                                            AM3X_CTRL_PADCONF_MODE0_0          |    \
                                                            AM3X_CTRL_PADCONF_PULLTYPE_EN1     |    \
   #define         NAND_PADCONF_GPMC_A4_EN                 (AM3X_CTRL_PADCONF_INPUT_DIS0       |    \
   #define         NAND_PADCONF_GPMC_A6_EN                 (AM3X_CTRL_PADCONF_INPUT_DIS0       |    \
   #define         NAND_PADCONF_GPMC_A8_EN                 (AM3X_CTRL_PADCONF_INPUT_DIS0       |    \
   #define         NAND_PADCONF_GPMC_A10_EN                (AM3X_CTRL_PADCONF_INPUT_DIS0       |    \
                                                            AM3X_CTRL_PADCONF_INPUT_EN1        |    \
                                                            AM3X_CTRL_PADCONF_PULLTYPE_UP1     |    \
   #define         NAND_PADCONF_GPMC_D1_EN                 (AM3X_CTRL_PADCONF_INPUT_EN0        |    \
                                                            AM3X_CTRL_PADCONF_PULLTYPE_UP0     |    \
   #define         NAND_PADCONF_GPMC_D3_EN                 (AM3X_CTRL_PADCONF_INPUT_EN0        |    \
   #define         NAND_PADCONF_GPMC_D5_EN                 (AM3X_CTRL_PADCONF_INPUT_EN0        |    \
   #define         NAND_PADCONF_GPMC_D7_EN                 (AM3X_CTRL_PADCONF_INPUT_EN0        |    \
   #define         NAND_PADCONF_GPMC_D9_EN                 (AM3X_CTRL_PADCONF_INPUT_EN0        |    \
   #define         NAND_PADCONF_GPMC_D11_EN                (AM3X_CTRL_PADCONF_INPUT_EN0        |    \
   #define         NAND_PADCONF_GPMC_D13_EN                (AM3X_CTRL_PADCONF_INPUT_EN0        |    \
   #define         NAND_PADCONF_GPMC_D15_EN                (AM3X_CTRL_PADCONF_INPUT_EN0        |    \
   #define         NAND_PADCONF_GPMC_NCS1_EN               (AM3X_CTRL_PADCONF_INPUT_DIS0       |    \
   #define         NAND_PADCONF_GPMC_NCS3_EN               (AM3X_CTRL_PADCONF_INPUT_DIS0       |    \
   #define         NAND_PADCONF_GPMC_NCS5_EN               (AM3X_CTRL_PADCONF_INPUT_DIS0       |    \
   #define         NAND_PADCONF_GPMC_NCS7_EN               (AM3X_CTRL_PADCONF_INPUT_EN0        |    \
   #define         NAND_PADCONF_GPMC_NADV_ALE_EN           (AM3X_CTRL_PADCONF_INPUT_DIS0       |    \
                                                            AM3X_CTRL_PADCONF_PULLTYPE_DIS0    |    \
   #define         NAND_PADCONF_GPMC_NWE_EN                (AM3X_CTRL_PADCONF_INPUT_DIS0       |    \
   #define         NAND_PADCONF_GPMC_NBE1_EN               (AM3X_CTRL_PADCONF_INPUT_EN0        |    \
   #define         NAND_PADCONF_GPMC_WAIT0_EN              (AM3X_CTRL_PADCONF_INPUT_EN0        |    \
#define         NAND_PADCONF_GPMC_WAIT2_EN               (AM3X_CTRL_PADCONF_INPUT_EN0        |    \
       /* Setup SDRC_DQS3 register. */
       reg32 = ESAL_GE_MEM_READ32(AM3X_CTRL_PADCONF_SDRC_DQS3);
       reg32 &= NAND_PADCONF_SDRC_DQS3_CLR;
       reg32 |= NAND_PADCONF_SDRC_DQS3_EN;
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_SDRC_DQS3, reg32);
       /* Setup GPMC_A2 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_A2, NAND_PADCONF_GPMC_A2_EN);
       /* Setup GPMC_A4 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_A4, NAND_PADCONF_GPMC_A4_EN);
       /* Setup GPMC_A6 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_A6, NAND_PADCONF_GPMC_A6_EN);
       /* Setup GPMC_A8 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_A8, NAND_PADCONF_GPMC_A8_EN);
       /* Setup GPMC_A10 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_A10, NAND_PADCONF_GPMC_A10_EN);
       /* Setup GPMC_D1 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_D1, NAND_PADCONF_GPMC_D1_EN);
       /* Setup GPMC_D3 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_D3, NAND_PADCONF_GPMC_D3_EN);
       /* Setup GPMC_D5 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_D5, NAND_PADCONF_GPMC_D5_EN);
       /* Setup GPMC_D7 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_D7, NAND_PADCONF_GPMC_D7_EN);
       /* Setup GPMC_D9 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_D9, NAND_PADCONF_GPMC_D9_EN);
       /* Setup GPMC_D11 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_D11, NAND_PADCONF_GPMC_D11_EN);
       /* Setup GPMC_D13 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_D13, NAND_PADCONF_GPMC_D13_EN);
       /* Setup GPMC_D15 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_D15, NAND_PADCONF_GPMC_D15_EN);
       /* Setup GPMC_NCS1 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_NCS1, NAND_PADCONF_GPMC_NCS1_EN);
       /* Setup GPMC_NCS3 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_NCS3, NAND_PADCONF_GPMC_NCS3_EN);
       /* Setup GPMC_NCS5 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_NCS5, NAND_PADCONF_GPMC_NCS5_EN);
       /* Setup GPMC_NCS7 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_NCS7, NAND_PADCONF_GPMC_NCS7_EN);
       /* Setup GPMC_NADV_ALE register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_NADV_ALE, NAND_PADCONF_GPMC_NADV_ALE_EN);
       /* Setup GPMC_NWE register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_NWE, NAND_PADCONF_GPMC_NWE_EN);
       /* Setup GPMC_NBE1 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_NBE1, NAND_PADCONF_GPMC_NBE1_EN);
       /* Setup GPMC_WAIT0 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_WAIT0, NAND_PADCONF_GPMC_WAIT0_EN);
       /* Setup GPMC_WAIT2 register. */
       ESAL_GE_MEM_WRITE32(AM3X_CTRL_PADCONF_GPMC_WAIT2, NAND_PADCONF_GPMC_WAIT2_EN);
       /* Reset GPMC controller. */
       ESAL_GE_MEM_WRITE32(AM3X_GPMC_SYSCONFIG, 0x00000002);
       /* Wait till the reset clears. */
       while (!(ESAL_GE_MEM_READ32(AM3X_GPMC_SYSSTATUS)));
       /* Clear GPMC timeout control register. */
       ESAL_GE_MEM_WRITE32(AM3X_GPMC_TIMEOUT_CTRL, 0);
       /* Disable GPMC IRQ. */
       ESAL_GE_MEM_WRITE32(AM3X_GPMC_IRQEN, 0);
       /* Configure limited address device support. */
       ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG, 0x00000002);
  /* CS3 -> CPLD 0x18000000                            */
  /* GPMC_CONFIG1                                           */
  /* Name                          bits      data           */
  /* wrapburst                     31        0x00000000     */
  /* readmultiple                  30        0x00000000     */
  /* readtype                      29        0x00000000     */
  /* writemultiple                 28        0x00000000     */
  /* writetype                     27        0x00000000     */
  /* clkactivationtime             25-26     0x00000000     */
  /* attacheddevicepagelength      23-24     0x00000000     */
  /* waitreadmonitoring            22        0x00000000     */
  /* waitwritemonitoring           21        0x00000000     */
  /* reserved                      20        0x00000000     */
  /* waitmonitoringtime            18-19     0x00000000     */
  /* waitpinselect                 16-17     0x00000000     */
  /* reserved                      14-15     0x00000000     */
  /* devicesize                    12-13     0x00001000     */
  /* devicetype                    10-11     0x00000000     */
  /* muxadddata                    9         0x00000000     */
  /* reserved                      5-8       0x00000000     */
  /* timeparagranularity           4         0x00000000     */
  /* reserved                      2-3       0x00000000     */
  /* gpmcfclkdivider               0-1       0x00000000     */
  /*                                         0x00001000     */
ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG1_3, 0x28001000);
  /* GPMC_CONFIG2                                           */
  /* reserved                      21-31     0x00000000     */
  /* cswrofftime                   16-20     0x00080000     */
  /* reserved                      13-15     0x00000000     */
  /* csrdofftime                   8-12      0x00000800     */
  /* csextradelay                  7         0x00000000     */
  /* reserved                      4-6       0x00000000     */
  /* csontime                      0-3       0x00000000     */
  /*                                         0x00080800     */
  //ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG2_3, 0x001e1e01);
  /* GPMC_CONFIG3                                           */
  /* advwrofftime                  16-20     0x00080000     */
  /* advrdofftime                  8-12      0x00000800     */
  /* advextradelay                 7         0x00000000     */
  /* advontime                     0-3       0x00000000     */
  /*                                         0x00080800     */
  //ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG3_3, 0x00080300);
  /* GPMC_CONFIG4                                           */
  /* reserved                      29-31     0x00000000     */
  /* weofftime                     24-28     0x06000000     */
  /* weextradelay                  23        0x00000000     */
  /* reserved                      20-22     0x00000000     */
  /* weontime                      16-19     0x00000000     */
  /* oeofftime                     8-12      0x00000600     */
  /* oeextradelay                  7         0x00000000     */
  /* oeontime                      0-3       0x00000000     */
  /*                                         0x06000600     */
  //ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG4_3, 0x1c091c09);
  /* GPMC_CONFIG5                                           */
  /* reserved                      28-31     0x00000000     */
  /* pageburstaccesstime           24-27     0x00000000     */
  /* reserved                      21-23     0x00000000     */
  /* rdaccesstime                  16-20     0x00080000     */
  /* wrcycletime                   8-12      0x00000800     */
  /* reserved                      5-7       0x00000000     */
  /* rdcycletime                   0-4       0x00000008     */
  /*                                         0x00080808     */
  //ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG5_3, 0x00181f1f);
  /* GPMC_CONFIG6                                           */
  /* wraccesstime                  24-28     0x00000000     */
  /* reserved                      20-23     0x00000000     */
  /* wrdataonadmuxbus              16-19     0x00000000     */
  /* reserved                      12-15     0x00000000     */
  /* cycle2cycledelay              8-11      0x00000300     */
  /* cycle2cyclesamecsen           7         0x00000080     */
  /* cycle2cyclediffcsen           6         0x00000040     */
  /* reserved                      4-5       0x00000000     */
  /* busturnaround                 0-3       0x0000000F     */
  /*                                         0x000003CF     */
  //ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG6_3, 0x00000FCF);
/* GPMC_CONFIG7                                           */
/* reserved                      12-31     0x00000000     */
/* maskaddress                   8-11      0x00000F00     */
/* reserved                      7         0x00000000     */
/* csvalid                       6         0x00000040     */
/* baseaddress                   0-5       0x00000018     */
/*                                         0x00000F58     */
ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG7_3, 0x00000F58);
/* ================= CS4 SRAM Test ================= */
ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG1_4, 0x28001203);
//ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG2_4, 0x00000000);
//ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG3_4, 0x00000000);
//ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG4_4, 0x00000000);
//ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG5_4, 0x00000000);
//ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG6_4, 0x00000000);
/* base add: 0x20000000, 16MB */
ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG7_4, 0x00000F60);
       /* Disable write protect. */
       ESAL_GE_MEM_WRITE32(AM3X_GPMC_CONFIG, 0x00000010);
       /* Enable GPMC controller. */
       ESAL_GE_MEM_WRITE32(AM3X_GPMC_SYSCONFIG, 0x00000008);
如需要进一步的信息,请回复,
感激不尽!
