这两个寄存器里的GIE位是一样的。这在下面的文档中有说明。
The GIE bit in TSR is physically the same bit as the GIE bit in CSR. It is retained in CSR for compatibility
reasons, but placed in TSR so that it will be copied in the event of either an exception or an interrupt.
http://www.ti.com/lit/ug/sprufe8b/sprufe8b.pdf
