[linux-devkit]:~/c> make
/root/CodeSourcery/Sourcery_G++_Lite//bin/arm-none-linux-gnueabi-gcc -I/usr/local/dvsdk/xdctools_3_16_03_36/packages -I/usr/local/dvsdk/dmai_2_20_00_14/packages -I/usr/local/dvsdk/codec-engine_2_26_01_09/packages -I/usr/local/dvsdk/framework-components_2_25_03_07/packages -I/usr/local/dvsdk/xdais_6_26_00_02/packages -I/usr/local/dvsdk/codecs-dm365_4_00_00_00/packages -DDmai_Device_dm368 -I/usr/local/dvsdk/psp/linux-2.6.32.17-psp03.01.01.38/in -g -Wall -Werror -o hello a.c
In file included from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Engine.h:57,
from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/CERuntime.h:57,
from a.c:11:
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:101: error: expected specifier-qualifier-list before 'Int'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:114: error: expected specifier-qualifier-list before 'Char'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:145: error: expected declaration specifiers or '...' before 'Int'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:167: error: expected declaration specifiers or '...' before 'Int'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:196: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_fwriteTrace'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:224: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_getAlgInfo'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:251: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_getCpuLoad'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:275: error: expected declaration specifiers or '...' before 'Int'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:296: error: expected declaration specifiers or '...' before 'Int'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:318: error: expected declaration specifiers or '...' before 'Int'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:324: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_init'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:380: error: expected declaration specifiers or '...' before 'String'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:381: error: expected declaration specifiers or '...' before 'Uint32'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:417: error: expected declaration specifiers or '...' before 'String'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:443: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_setTrace'
In file included from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Engine.h:58,
from a.c:11:
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:50: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_MSGSIZE'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:55: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_Queue'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:73: error: expected declaration specifiers or '...' before '*' token
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:73: error: expected ')' before 'callHandle'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:80: error: expected specifier-qualifier-list before 'Ptr'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:93: error: expected specifier-qualifier-list before 'UInt32'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:124: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_locate'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:130: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_alloc'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:136: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_free'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:142: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_put'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:148: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_get'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:154: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_getMsgSize'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:160: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_getSrcQueue'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:166: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_setSrcQueue'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:172: error: expected ')' before 'queueName'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:179: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_delete'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:184: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_init'
/usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:189: error: expected '=', ',', ';', 'asm' or '__attribute__'
