仿真器连接错误
Other Parts Discussed in Thread: OMAP-L138
我的板子的OMAP-L138没有用RTC,RTC_XI、RTC_Vss接地了,RTC_XO悬空了,现在是这种情况如果我用TI官方的GEL连接目标板DSP可以连接上,但是,外设没反应,只能读写片上RAM。
如果用开发板厂家的GEL,仿真器连接不上出现如下错误
Error connecting to the target: Error 0x80000244/-1178 Fatal Error during: Register, Initialization, OCS,  The target does not have a CPU clock.
  • 还是没解决,我是连的DSP,请问该怎么在ti官方的GEL文件中配置呢,为什么只能访问片上的RAM,设置GPIO之类的没反应呢?
  • 仿真器连接Omap-l138 DSP 出现如下错误提示
    Trouble Reading Memory Block at 0x1c1417c on Page 0 of Length 0x4: Error 0x00000002/-1178 Error during: Memory,  The target does not have a CPU clock.
    GEL: Error while executing OnTargetConnect(): target access failed.
    Trouble Reading Register: Error 0x00000004/-1178 Error during: Register,  The target does not have a CPU clock.
    Trouble Reading Memory Block at 0x1840020 on Page 0 of Length 0x4: Error 0x00000002/-1178 Error during: Memory,  The target does not have a CPU clockTrouble Reading Memory Block at 0x1840020 on Page 0 of Length 0x4: Error 0x00000002/-1178 Error during: Memory,  The target does not have a CPU clock.
    请问是什么原因?
    OnTargetConnect( )
       Clear_Memory_Map();
       Setup_Memory_Map();
       PSC_All_On_Full_EVM();
      Set_Core_100MHz();
    注释掉PSC_All_On_Full_EVM(); Set_Core_100MHz();就能连接上,但是外设没反应,只能读写片上RAM。
    请问是什么原因?
    OnTargetConnect( )
       Clear_Memory_Map();
       Setup_Memory_Map();
      Set_Core_100MHz();
    请问是什么原因?
    OnTargetConnect( )
       Clear_Memory_Map();
       Setup_Memory_Map();
      Set_Core_100MHz();
