6747EDMA_uart数据传输问题
// File edma3.c
// Copyright (c) 2010, Texas Instruments Inc.
// All rights reserved.
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions are met:
//     * Redistributions of source code must retain the above copyright notice,
//       this list of conditions and the following disclaimer.
//     * Redistributions in binary form must reproduce the above copyright
//       notice, this list of conditions and the following disclaimer in the
//       documentation and/or other materials provided with the distribution.
//     * Neither the name of the Texas Instruments Inc. nor the names of its
//       contributors may be used to endorse or promote products derived from
//       this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
// AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
// IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
// ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
// LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
// CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
// SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
// INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
// CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
// ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
// POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include "edma3.h"
#include "app.h"
#include "UniCtrlDspcfg.h"
#include "UniCtrlDspMain.h"
// Local Variables
static CSL_Edma3ccRegsOvly edmaCcRegs = (CSL_Edma3ccRegsOvly)CSL_EDMA3CC_0_REGS;
void *uart_register = (void *)CSL_UART_1_REGS ;
// Functions
void edmaInit()
    edmaCcRegs->ECR  = 0xffffffff; // clear events  0 -> 31
    edmaCcRegs->SECR = 0xffffffff; // clear secondary events  0 -> 31
    edmaCcRegs->IECR = 0xffffffff; // disable all interrupts
    edmaCcRegs->ICR  = 0xffffffff; // clear all pending interrupts
//发送数据
//void setup_edma_pingpong_xmt(void *src_ping_L, void *src_pong_L,
//                             void *src_ping_R, void *src_pong_R,
//                             void *dst,
//                             Uint32 sample_size, Uint32 sample_count)
void setup_edma_uart_xmt(void *src_ping_L,Uint32 sample_size)
    CSL_Edma3ccParamSetRegs param;
    param.OPT = (EDMA_XMT_PING_TCC << 12) | (1 << 20);      // transfer complete interrupt enabled
    param.SRC = (Uint32)src_ping_L;                         //源地址 发送地址 20160412mcg
    param.A_B_CNT = (1 << 16) | sample_size;                // actual format: BCNT|ACNT
    param.DST = (Uint32)uart_register;                      //(Uint32)dst;   //目的地址   数据的接收地址 20160412mcg
    param.SRC_DST_BIDX = 0x0000;                            //实现多帧数据传输时设置源索引参数  mcg20160412// actual format: DSTBIDX|SCRBIDX
    param.LINK_BCNTRLD = (0 << 16) | (0xffff);              //(2 << 16) | (EDMA_XMTPONG * 0x20); // actual format: BCNTRLD|LINK
    param.SRC_DST_CIDX = (0 << 16)| (0x0000);               //(0 << 16) | (ping_c_idx & 0x0000FFFF); // actual format: DSTCIDX|SRCCIDX
    param.CCNT = 0x0001;//sample_count;                             //三维计数器,当只有一帧数据时设置0x0001  mcg20160412
    edmaWritePaRAM(EDMA_UART2_TX, &param);// EDMA_MCASPTXCH
//void setup_edma_pingpong_rcv(void *src,
//                             void *dst_ping_L, void *dst_pong_L,
//                             void *dst_ping_R, void *dst_pong_R,
void setup_edma_uart_rcv(void *dst_ping_L,Uint32 sample_size)
    // 1. setup channel PaRAM slot
    param.OPT = (EDMA_RCV_PING_TCC << 12) | (1 << 20);     // transfer complete interrupt enabled
    param.SRC = (Uint32)uart_register;                     //(Uint32)src; //源地址
    param.DST = (Uint32)dst_ping_L;                       //目的地址
    param.SRC_DST_BIDX = 0x0000;                           //实现多帧数据传输时设置源索引参数//(ping_offset << 16) | 0; // actual format: DSTBIDX|SCRBIDX
    param.LINK_BCNTRLD = (0 << 16) | (0xffff);             //(2 << 16) | (EDMA_RCVPONG * 0x20);  // actual format: BCNTRLD|LINK
    param.SRC_DST_CIDX = (0 << 16)| (0x0000);              //((ping_c_idx << 16) & 0xFFFF0000) | 0; // actual format: DSTCIDX|SRCCIDX
    param.CCNT = 0x0001; //sample_count;                             //三维计数器,当只有一帧数据时设置0x0001  mcg20160412
    edmaWritePaRAM(EDMA_UART2_RX, &param);// EDMA_MCASPRXCH
void edmaWritePaRAM(Int ParamNum, CSL_Edma3ccParamSetRegs *ptrParamInfo)
    edmaCcRegs->PARAMSET[ParamNum].OPT = ptrParamInfo->OPT;
    edmaCcRegs->PARAMSET[ParamNum].SRC = ptrParamInfo->SRC;
    edmaCcRegs->PARAMSET[ParamNum].A_B_CNT = ptrParamInfo->A_B_CNT;
    edmaCcRegs->PARAMSET[ParamNum].DST = ptrParamInfo->DST;
    edmaCcRegs->PARAMSET[ParamNum].SRC_DST_BIDX = ptrParamInfo->SRC_DST_BIDX;
    edmaCcRegs->PARAMSET[ParamNum].LINK_BCNTRLD = ptrParamInfo->LINK_BCNTRLD;
    edmaCcRegs->PARAMSET[ParamNum].SRC_DST_CIDX = ptrParamInfo->SRC_DST_CIDX;
    edmaCcRegs->PARAMSET[ParamNum].CCNT = ptrParamInfo->CCNT;
void edmaSetEvent(Int channelNumber)
    int mask;
    mask = 1 << channelNumber;
    edmaCcRegs->ESR = mask;
void EdmaIntClear(Int channelNumber)
    edmaCcRegs->ICR = 1 << channelNumber;
void EdmaIntEnable(Int intNumber)
    edmaCcRegs->IESR = 1 << intNumber;
    edmaCcRegs->DRA[0].DRAE &= ~(1 << intNumber);
    edmaCcRegs->DRA[1].DRAE |= 1 << intNumber;
// not a tested function
void EdmaIntDisable(Int intNumber)
    int mask;
    mask = 1 << intNumber;
    edmaCcRegs->DRA[0].DRAE &= ~mask;
void EdmaEnableChannel(Int channelNumber, Int QueueNumber)
    int mask;
    edmaCcRegs->EMCR = 1 << channelNumber;
    edmaCcRegs->SECR = 1 << channelNumber;
    QueueNumber &= 1; // only 0 or 1 are valid
    mask = 0x07 << (4 * (channelNumber & 0x07) );
    edmaCcRegs->DMAQNUM[channelNumber >> 3] &= ~mask;
    edmaCcRegs->DMAQNUM[channelNumber >> 3] |= QueueNumber << (4 * (channelNumber & 0x07) );
    edmaCcRegs->EESR = 1 << channelNumber;
void EdmaDisableChannel(Int channelNumber)
    edmaCcRegs->EECR = 1 << channelNumber;
void edmaWaitForEvent(int event)
    Uint32 mask = 1 << event;
    while((edmaCcRegs->IPR & mask) == NULL)
        asm(" nop");
    EdmaIntClear(event);
void edma3ccIsr()
    while(edmaCcRegs->IPR)
        if (edmaCcRegs->IPR & (1 << EDMA_RCV_PING_TCC))    // receive channel (ping)
            EdmaIntClear(EDMA_RCV_PING_TCC);//sem_udpstart;//sem_nav_x
            SEM_post(&sem_udpstart);//add by mcg 20160412
           // SEM_post(&rcv_ping_sem);
            //LOG_printf(&trace, "[ISR]: receive ping!");
//        if (edmaCcRegs->IPR & (1 << EDMA_RCV_PONG_TCC))    // receive channel (pong)
//            EdmaIntClear(EDMA_RCV_PONG_TCC);
//           // SEM_post(&rcv_pong_sem);
//            //LOG_printf(&trace, "[ISR]: receive pong!");
        if (edmaCcRegs->IPR & (1 << EDMA_XMT_PING_TCC))    // transmit channel (ping)
            EdmaIntClear(EDMA_XMT_PING_TCC);
            SEM_post(&sem_nav_x);//add by mcg 20160412
           // SEM_post(&xmt_ping_sem);
            //LOG_printf(&trace, "[ISR]: transmit ping!");
//        if (edmaCcRegs->IPR & (1 << EDMA_XMT_PONG_TCC))    // transmit channel (pong)
//            EdmaIntClear(EDMA_XMT_PONG_TCC);
//           // SEM_post(&xmt_pong_sem);
//            //LOG_printf(&trace, "[ISR]: transmit pong!");
    return;
// End of File edma3.c
调用方式
   setup_edma_uart_xmt(uart_sendm,10);
      EdmaEnableChannel(EDMA_UART2_RX, 0);
      EdmaEnableChannel(EDMA_UART2_TX, 0);
      EdmaIntEnable(EDMA_XMT_PING_TCC);
      EdmaIntEnable(EDMA_RCV_PING_TCC);
      //EdmaIntEnable(EDMA_XMT_PING_TCC);
但是串口没有数,是什么原因呢?  希望高手解答一下
