CCSTUDIO: 1.matlab2025b 生成DSP28035代码正常,但是CCS无法打开工程.
Part Number: CCSTUDIO
Other Parts Discussed in Thread: TI-CGT, CONTROLSUITE, TMS320F28035
2.这是matlab(2025b)的生成信息:
### 正在启动 untitled 的编译过程
### 正在为 '模型特定' 文件夹结构生成代码和工件
### 正在将代码生成到编译文件夹中: C:\Users\admin\Desktop\1\untitled_ert_rtw
### Invoking Target Language Compiler on untitled.rtw
### Using System Target File: C:\Program Files\MATLAB\R2025b\rtw\c\ert\ert.tlc
### Loading TLC function libraries
### Generating TLC interface API for custom data
### Initial pass through model to cache user defined code
### Caching model source code
### Writing header file untitled.h
### Writing header file MW_c28xx_pie.h
### Writing source file untitled.c
### Writing header file rtmodel.h
### Writing source file ert_main.c
### TLC code generation complete (took 7.193s).
### 正在保存二进制信息缓存。### Creating CCS Project at : C:\Users\admin\Desktop\1\untitled_ert_rtw\CCS_Project
### CCS project created successfully Open project in Code Composer Studio.### 使用工具链: Texas Instruments Code Composer Studio (C2000)
### 'C:\Users\admin\Desktop\1\untitled_ert_rtw\untitled.mk' 是最新的。
### 正在编译 'untitled': "C:\PROGRA~1\MATLAB\R2025b\bin\win64\gmake"  DEPRULES=1 -j5  -f untitled.mk all
C:\Users\admin\Desktop\1\untitled_ert_rtw>cd .
C:\Users\admin\Desktop\1\untitled_ert_rtw>if "all" == "" ("C:\PROGRA~1\MATLAB\R2025b\bin\win64\gmake"  DEPRULES=1 -j5  -f untitled.mk all )  else ("C:\PROGRA~1\MATLAB\R2025b\bin\win64\gmake"  DEPRULES=1 -j5  -f untitled.mk all )
"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/bin/cl2000" --abi=coffabi --compile_only --preproc_dependency="MW_c28xx_csl.dep" --preproc_with_compile -I"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/include" --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -O2 -v28 -ml -DF28035 -DBOOT_FROM_FLASH=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=0 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0  -DTID01EQ=0 -DXCP_CUSTOM_PLATFORM -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DMW_PIL_SCIFIFOLEN=4 -DMW_F2803X -DSTACK_SIZE=768 -DRT -DF28035 -DBOOT_FROM_FLASH=0 -DMW_HCCAL_INCLUDED=0 -DMODEL=untitled -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/admin/Desktop/1 -IC:/Users/admin/Desktop/1/untitled_ert_rtw -IC:/PROGRA~1/MATLAB/R2025b/extern/include -IC:/PROGRA~1/MATLAB/R2025b/simulink/include -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/ert -IC:/Users/admin/Desktop/1/slprj/ert/_sharedutils -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/inc -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/inc -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_common/include -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_headers/include -IC:/ti/controlSUITE//libs/math/CLAmath/v400/include -IC:/ti/controlSUITE//libs/math/IQmath/v160/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/shared/can/src/scanutil -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/blocks/lct/include -IC:/ti/controlSUITE//libs/utilities/hrcap_hccal/type0/v110/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/src/ipclite -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/inc/ipclite --output_file="MW_c28xx_csl.obj" "C:/Users/admin/Desktop/1/untitled_ert_rtw/MW_c28xx_csl.c"
"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/bin/cl2000" --abi=coffabi --compile_only --preproc_dependency="MW_c28xx_board.dep" --preproc_with_compile -I"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/include" --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -O2 -v28 -ml -DF28035 -DBOOT_FROM_FLASH=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=0 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0  -DTID01EQ=0 -DXCP_CUSTOM_PLATFORM -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DMW_PIL_SCIFIFOLEN=4 -DMW_F2803X -DSTACK_SIZE=768 -DRT -DF28035 -DBOOT_FROM_FLASH=0 -DMW_HCCAL_INCLUDED=0 -DMODEL=untitled -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/admin/Desktop/1 -IC:/Users/admin/Desktop/1/untitled_ert_rtw -IC:/PROGRA~1/MATLAB/R2025b/extern/include -IC:/PROGRA~1/MATLAB/R2025b/simulink/include -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/ert -IC:/Users/admin/Desktop/1/slprj/ert/_sharedutils -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/inc -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/inc -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_common/include -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_headers/include -IC:/ti/controlSUITE//libs/math/CLAmath/v400/include -IC:/ti/controlSUITE//libs/math/IQmath/v160/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/shared/can/src/scanutil -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/blocks/lct/include -IC:/ti/controlSUITE//libs/utilities/hrcap_hccal/type0/v110/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/src/ipclite -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/inc/ipclite --output_file="MW_c28xx_board.obj" "C:/Users/admin/Desktop/1/untitled_ert_rtw/MW_c28xx_board.c"
"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/bin/cl2000" --abi=coffabi --compile_only --preproc_dependency="untitled.dep" --preproc_with_compile -I"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/include" --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -O2 -v28 -ml -DF28035 -DBOOT_FROM_FLASH=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=0 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0  -DTID01EQ=0 -DXCP_CUSTOM_PLATFORM -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DMW_PIL_SCIFIFOLEN=4 -DMW_F2803X -DSTACK_SIZE=768 -DRT -DF28035 -DBOOT_FROM_FLASH=0 -DMW_HCCAL_INCLUDED=0 -DMODEL=untitled -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/admin/Desktop/1 -IC:/Users/admin/Desktop/1/untitled_ert_rtw -IC:/PROGRA~1/MATLAB/R2025b/extern/include -IC:/PROGRA~1/MATLAB/R2025b/simulink/include -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/ert -IC:/Users/admin/Desktop/1/slprj/ert/_sharedutils -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/inc -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/inc -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_common/include -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_headers/include -IC:/ti/controlSUITE//libs/math/CLAmath/v400/include -IC:/ti/controlSUITE//libs/math/IQmath/v160/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/shared/can/src/scanutil -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/blocks/lct/include -IC:/ti/controlSUITE//libs/utilities/hrcap_hccal/type0/v110/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/src/ipclite -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/inc/ipclite --output_file="untitled.obj" "C:/Users/admin/Desktop/1/untitled_ert_rtw/untitled.c"
"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/bin/cl2000" --abi=coffabi --compile_only --preproc_dependency="c2803xBoard_Realtime_Support.dep" --preproc_with_compile -I"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/include" --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -O2 -v28 -ml -DF28035 -DBOOT_FROM_FLASH=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=0 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0  -DTID01EQ=0 -DXCP_CUSTOM_PLATFORM -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DMW_PIL_SCIFIFOLEN=4 -DMW_F2803X -DSTACK_SIZE=768 -DRT -DF28035 -DBOOT_FROM_FLASH=0 -DMW_HCCAL_INCLUDED=0 -DMODEL=untitled -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/admin/Desktop/1 -IC:/Users/admin/Desktop/1/untitled_ert_rtw -IC:/PROGRA~1/MATLAB/R2025b/extern/include -IC:/PROGRA~1/MATLAB/R2025b/simulink/include -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/ert -IC:/Users/admin/Desktop/1/slprj/ert/_sharedutils -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/inc -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/inc -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_common/include -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_headers/include -IC:/ti/controlSUITE//libs/math/CLAmath/v400/include -IC:/ti/controlSUITE//libs/math/IQmath/v160/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/shared/can/src/scanutil -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/blocks/lct/include -IC:/ti/controlSUITE//libs/utilities/hrcap_hccal/type0/v110/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/src/ipclite -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/inc/ipclite --output_file="c2803xBoard_Realtime_Support.obj" "C:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/src/c2803xBoard_Realtime_Support.c"
"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/bin/cl2000" --abi=coffabi --compile_only --preproc_dependency="MW_c28xGlobalInterrupts.dep" --preproc_with_compile -I"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/include" --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -O2 -v28 -ml -DF28035 -DBOOT_FROM_FLASH=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=0 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0  -DTID01EQ=0 -DXCP_CUSTOM_PLATFORM -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DMW_PIL_SCIFIFOLEN=4 -DMW_F2803X -DSTACK_SIZE=768 -DRT -DF28035 -DBOOT_FROM_FLASH=0 -DMW_HCCAL_INCLUDED=0 -DMODEL=untitled -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/admin/Desktop/1 -IC:/Users/admin/Desktop/1/untitled_ert_rtw -IC:/PROGRA~1/MATLAB/R2025b/extern/include -IC:/PROGRA~1/MATLAB/R2025b/simulink/include -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/ert -IC:/Users/admin/Desktop/1/slprj/ert/_sharedutils -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/inc -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/inc -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_common/include -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_headers/include -IC:/ti/controlSUITE//libs/math/CLAmath/v400/include -IC:/ti/controlSUITE//libs/math/IQmath/v160/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/shared/can/src/scanutil -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/blocks/lct/include -IC:/ti/controlSUITE//libs/utilities/hrcap_hccal/type0/v110/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/src/ipclite -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/inc/ipclite --output_file="MW_c28xGlobalInterrupts.obj" "C:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/src/MW_c28xGlobalInterrupts.c"
"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/bin/cl2000" --abi=coffabi --compile_only --preproc_dependency="c2000HardwareTimerConfig.dep" --preproc_with_compile -I"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/include" --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -O2 -v28 -ml -DF28035 -DBOOT_FROM_FLASH=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=0 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0  -DTID01EQ=0 -DXCP_CUSTOM_PLATFORM -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DMW_PIL_SCIFIFOLEN=4 -DMW_F2803X -DSTACK_SIZE=768 -DRT -DF28035 -DBOOT_FROM_FLASH=0 -DMW_HCCAL_INCLUDED=0 -DMODEL=untitled -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/admin/Desktop/1 -IC:/Users/admin/Desktop/1/untitled_ert_rtw -IC:/PROGRA~1/MATLAB/R2025b/extern/include -IC:/PROGRA~1/MATLAB/R2025b/simulink/include -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/ert -IC:/Users/admin/Desktop/1/slprj/ert/_sharedutils -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/inc -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/inc -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_common/include -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_headers/include -IC:/ti/controlSUITE//libs/math/CLAmath/v400/include -IC:/ti/controlSUITE//libs/math/IQmath/v160/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/shared/can/src/scanutil -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/blocks/lct/include -IC:/ti/controlSUITE//libs/utilities/hrcap_hccal/type0/v110/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/src/ipclite -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/inc/ipclite --output_file="c2000HardwareTimerConfig.obj" "C:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/src/c2000HardwareTimerConfig.c"
"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/bin/cl2000" --abi=coffabi --compile_only --preproc_dependency="MW_c28xGPIO.dep" --preproc_with_compile -I"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/include" --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -O2 -v28 -ml -DF28035 -DBOOT_FROM_FLASH=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=0 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0  -DTID01EQ=0 -DXCP_CUSTOM_PLATFORM -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DMW_PIL_SCIFIFOLEN=4 -DMW_F2803X -DSTACK_SIZE=768 -DRT -DF28035 -DBOOT_FROM_FLASH=0 -DMW_HCCAL_INCLUDED=0 -DMODEL=untitled -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/admin/Desktop/1 -IC:/Users/admin/Desktop/1/untitled_ert_rtw -IC:/PROGRA~1/MATLAB/R2025b/extern/include -IC:/PROGRA~1/MATLAB/R2025b/simulink/include -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/ert -IC:/Users/admin/Desktop/1/slprj/ert/_sharedutils -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/inc -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/inc -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_common/include -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_headers/include -IC:/ti/controlSUITE//libs/math/CLAmath/v400/include -IC:/ti/controlSUITE//libs/math/IQmath/v160/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/shared/can/src/scanutil -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/blocks/lct/include -IC:/ti/controlSUITE//libs/utilities/hrcap_hccal/type0/v110/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/src/ipclite -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/inc/ipclite --output_file="MW_c28xGPIO.obj" "C:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/src/MW_c28xGPIO.c"
"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/bin/cl2000" --abi=coffabi --compile_only --preproc_dependency="c2803xSchedulerTimer0.dep" --preproc_with_compile -I"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/include" --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -O2 -v28 -ml -DF28035 -DBOOT_FROM_FLASH=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=0 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0  -DTID01EQ=0 -DXCP_CUSTOM_PLATFORM -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DMW_PIL_SCIFIFOLEN=4 -DMW_F2803X -DSTACK_SIZE=768 -DRT -DF28035 -DBOOT_FROM_FLASH=0 -DMW_HCCAL_INCLUDED=0 -DMODEL=untitled -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/admin/Desktop/1 -IC:/Users/admin/Desktop/1/untitled_ert_rtw -IC:/PROGRA~1/MATLAB/R2025b/extern/include -IC:/PROGRA~1/MATLAB/R2025b/simulink/include -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/ert -IC:/Users/admin/Desktop/1/slprj/ert/_sharedutils -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/inc -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/inc -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_common/include -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_headers/include -IC:/ti/controlSUITE//libs/math/CLAmath/v400/include -IC:/ti/controlSUITE//libs/math/IQmath/v160/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/shared/can/src/scanutil -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/blocks/lct/include -IC:/ti/controlSUITE//libs/utilities/hrcap_hccal/type0/v110/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/src/ipclite -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/inc/ipclite --output_file="c2803xSchedulerTimer0.obj" "C:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/src/c2803xSchedulerTimer0.c"
"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/bin/cl2000" --abi=coffabi --compile_only --preproc_dependency="ert_main.dep" --preproc_with_compile -I"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/include" --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -O2 -v28 -ml -DF28035 -DBOOT_FROM_FLASH=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=0 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0  -DTID01EQ=0 -DXCP_CUSTOM_PLATFORM -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DMW_PIL_SCIFIFOLEN=4 -DMW_F2803X -DSTACK_SIZE=768 -DRT -DF28035 -DBOOT_FROM_FLASH=0 -DMW_HCCAL_INCLUDED=0 -DMODEL=untitled -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/admin/Desktop/1 -IC:/Users/admin/Desktop/1/untitled_ert_rtw -IC:/PROGRA~1/MATLAB/R2025b/extern/include -IC:/PROGRA~1/MATLAB/R2025b/simulink/include -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2025b/rtw/c/ert -IC:/Users/admin/Desktop/1/slprj/ert/_sharedutils -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/inc -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/src -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/inc -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_common/include -IC:/ti/controlSUITE/device_support/f2803x/v130/DSP2803x_headers/include -IC:/ti/controlSUITE//libs/math/CLAmath/v400/include -IC:/ti/controlSUITE//libs/math/IQmath/v160/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/shared/can/src/scanutil -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/blocks/lct/include -IC:/ti/controlSUITE//libs/utilities/hrcap_hccal/type0/v110/include -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/src/ipclite -IC:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_soc/inc/ipclite --output_file="ert_main.obj" "C:/Users/admin/Desktop/1/untitled_ert_rtw/ert_main.c"
"### Creating standalone executable "../untitled.out" ..."
"C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/bin/cl2000" --abi=coffabi -z -IC:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/lib --stack_size=768 --warn_sections --heap_size=1024 --reread_libs --rom_model --priority -m"untitled.map" -l"rts2800_ml.lib" --define F28035 --define BOOT_FROM_FLASH=0 --define BOOT_USING_BL=0 --output_file=../untitled.out MW_c28xx_csl.obj MW_c28xx_board.obj untitled.obj c2803xBoard_Realtime_Support.obj MW_c28xGlobalInterrupts.obj DSP2803x_CpuTimers.obj DSP2803x_DefaultIsr.obj DSP2803x_GlobalVariableDefs.obj DSP2803x_PieCtrl.obj DSP2803x_PieVect.obj DSP2803x_SysCtrl.obj DSP2803x_usDelay.obj DSP2803x_CodeStartBranch.obj DSP2803x_Adc.obj DSP2803x_Lin.obj c2000HardwareTimerConfig.obj MW_c28xGPIO.obj c2803xSchedulerTimer0.obj mw_soc_c2000_ipc.obj ert_main.obj C:/ti/controlSUITE/libs/utilities/hrcap_hccal/type0/v110/lib/HCCal_Type0_V1.lib C:/ti/controlSUITE/libs/math/IQmath/v160/lib/IQmath.lib C:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/src/c2803xPeripherals.cmd C:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000/src/c28035.cmd
<Linking>
"### Created: ../untitled.out"
"### Updating dependency files ..."
"### Invoking postbuild tool "Hex Converter" on "../untitled.out"..."
PowerShell -ExecutionPolicy Bypass -command "& 'C:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/tools/PostBuildDepedency/win64/DepedencyFileUpdate.ps1'"
C:/PROGRA~3/MATLAB/tic2000/3P778C~1.INS/TIC28X~1.INS/TI-CGT~1.LTS/bin/hex2000 -i "../untitled.out" -o "../untitled.hex" -order MS -romwidth 16 -q
"### Invoking postbuild tool "DWO Converter" on "../untitled.out"..."
C:/PROGRA~1/MATLAB/R2025b/toolbox/c2b/tic2000_shared/tools/bin/win64/extractDWARF.exe "../untitled.out"
*** Starting extraction of debug information from TI-COFF ***
Loaded : ../untitled.out, and identified as TI-COFF
Opened : ../untitled.dwo for write
coff -> dwo conversion completed successfully..
"### Done Invoking postbuild tool "DWO Converter" ..."
"### Done Invoking postbuild tool "Hex Converter" ..."
"### Done Updating dependency files ..."
"### Successfully generated all binary outputs."
C:\Users\admin\Desktop\1\untitled_ert_rtw>exit /B 0
### Creating HTML report file index.html
### Successful completion of build procedure for: untitled
### 'untitled' 的 Simulink 缓存工件是在 'C:\Users\admin\Desktop\1\untitled.slxc' 中创建的。顶层模型目标:
模型    编译原因   状态       编译持续时间
untitled  生成的代码已过期。  代码已生成并完成编译。  0h 0m 46.157s
编译了 1 个模型,共 1 个模型(0 个模型已经是最新的)
编译持续时间: 0h 0m 51.965s
3.这是CCS打开工程的信息:
Problems importing project(s): Device 'TMS320F28035_cpu' is not currently recognized
