TDA4VM: J721EXSOMG01EVM 11:02:00:04 镜像里也找不到vx_app_tidl_front_cam.out
Part Number: TDA4VM
J721EXCP01EVM Jacinto 7 处理板搭载J721EXSOMG01EVM
镜像 ti-processor-sdk-linux-adas-j721e-evm-11_02_00_04
执行demo遇到两个问题:
1、vision_apps 执行报错
root@j721e-evm:/opt/edgeai-tiovx-apps# /opt/vision_apps/run_app_tidl_front_cam.sh
/opt/vision_apps/run_app_tidl_front_cam.sh: line 1: /opt/vision_apps/vx_app_tidl_front_cam.out: No such file or directory
另vision_apps有无对应版本的源码
2、
root@j721e-evm:/opt/edgeai-tiovx-apps# ./bin/Release/edgeai-tiovx-apps-main ./configs/linux/object_detection.yaml
APP: Init ... !!!
 18836.085996 s: MEM: Init ... !!!
 18836.086190 s: MEM: Initialized DMA HEAP (fd=4) !!!
 18836.086421 s: MEM: Init ... Done !!!
 18836.086439 s: IPC: Init ... !!!
 18836.136548 s: IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
 18836.141228 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
 18836.141358 s: VX_ZONE_INFO: Globally Enabled VX_ZONE_ERROR
 18836.141370 s: VX_ZONE_INFO: Globally Enabled VX_ZONE_WARNING
 18836.141376 s: VX_ZONE_INFO: Globally Enabled VX_ZONE_INFO
 18836.142190 s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-0
 18836.142317 s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-1
 18836.142405 s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-2
 18836.142480 s: VX_ZONE_INFO: [tivxPlatformCreateTargetId:169] Added target MPU-3
 18836.142493 s: VX_ZONE_INFO: [tivxInitLocal:202] Initialization Done !!!
 18836.142504 s: VX_ZONE_INFO: Globally Disabled VX_ZONE_INFO
[TIOVX_APPS][ERROR] 202: create_resize_block: Input dims for resize block is invalid
[TIOVX_APPS][ERROR] 490: connect_blocks: Cannot create resize block
[TIOVX_APPS][ERROR] 633: run_app: Error connecting blocks
APP: Deinit ... !!!
REMOTE_SERVICE: Deinit ... !!!
REMOTE_SERVICE: Deinit ... Done !!!
 18836.151773 s: IPC: Deinit ... !!!
 18836.154885 s: IPC: DeInit ... Done !!!
 18836.154947 s: MEM: Deinit ... !!!
 18836.154970 s: DDR_SHARED_MEM: Alloc's: 0 alloc's of 0 bytes
 18836.154989 s: DDR_SHARED_MEM: Free's : 0 free's  of 0 bytes
 18836.155006 s: DDR_SHARED_MEM: Open's : 0 allocs  of 0 bytes
 18836.155029 s: MEM: Deinit ... Done !!!
APP: Deinit ... Done !!!
Segmentation fault (core dumped)
而且曾尝试过包同样错误
cat > /root/od_file_h264.yaml <<'EOF'
title: YOLOX file -> H264 file
inputs:
    input0:
        source: VIDEO
        width: 1280
        height: 768
        video_path: /opt/edgeai-test-data/videos/video0_1280_768.h264
models:
    model0:
        model_path: /opt/model_zoo/ONR-OD-8200-yolox-nano-lite-mmdet-coco-416x416
        viz-threshold: 0.4
outputs:
    output0:
        sink: H264_ENCODE
        width: 1920
        height: 1088
        output_path: /opt/edgeai-test-data/output/det_yolox.h264
flows:
    flow0:
        pipeline: [input0, model0, output0]
        mosaic:
            - [320, 150, 1280, 720]
EOF
mkdir -p /opt/edgeai-test-data/output
rm -f /opt/edgeai-test-data/output/det_yolox.h264
pkill -f vx_app_arm_remote_log 2>/dev/null
/opt/vision_apps/vision_apps_init.sh >/dev/null 2>&1
/opt/vision_apps/vx_app_arm_remote_log.out &
sleep 2
cd /opt/edgeai-tiovx-apps
./bin/Release/edgeai-tiovx-apps-main /root/od_file_h264.yaml -v 2>&1 | tee /tmp/demo_h264.log,
