C6205通过EMIF接口CE1外接Flash,那Flash里的程序是如何执行的?是DSP通过EMIF不断从Flash里读取数据吗?读取的速度是怎么控制的?
我现在用的是nor flash,发现EMIF接口有信号,片选信号每次使能(拉低)时间大约16us,禁能(拉高)时间很短,说明DSP和FLASH有通信吧?这个通信速度是DSP内部固件决定的?
现在的现象是:一样的程序,烧写在FLASH运行速度和直接在线仿真速度相差很多,比在线慢很多,这大概是什么原因呢?
Yujing Wang 说:C6205通过EMIF接口CE1外接Flash,那Flash里的程序是如何执行的?是DSP通过EMIF不断从Flash里读取数据吗?读取的速度是怎么控制的?
C6205是一款很老的DSP,还不支持XIP,NOR flash boot即文档spru642里描述的ROM boot process,不是从flash运行,而是从flash copy到address 0再运行。
4 Boot Processes
The boot process is determined by the boot configuration selected, as described
in section 5. Up to three types of boot processes are available:
No boot process: The CPU begins direct execution from the memory
located at address 0. If SDRAM is used in the system, the CPU is held until
SDRAM initialization is complete. Operation is undefined if invalid code is
ROM boot process: The program located in external ROM is copied to
address 0 by the DMA controller. Although the boot process begins when
the device is released from external reset, this transfer occurs while the
CPU is internally stalled. For the C620x/C670x DSP, these values are
expected to be stored in little-endian format in the external memory,
typically a ROM device.
The transfer is automatically done by the DMA controller as a single-frame
block transfer from the ROM to address 0. The DMA copies 64K bytes
from CE1 to address 0, using default ROM timings. After completion of the
block transfer, the CPU is unstalled and allowed to run from address 0.
Host boot process: The CPU is internally stalled while the remainder of
the device is released. During this period, an external host can initialize
the CPU memory space as necessary through the host interface, including
internal configuration registers, such as those that control the EMIF or
other peripherals. Once the host is finished with all necessary initialization,
it must set the DSPINT to complete the boot process. This transition
causes the boot configuration logic to unstall the CPU. The CPU then
begins execution from address 0. The DSPINT condition is not latched by
the CPU, because it occurs while the CPU is stalled. Also, DSPINT
unstalls the CPU only if the host boot process is selected. All memory may
be written to and read by the host. This allows for the host to verify what
it sends to the processor, if required. After the CPU is unstalled, the CPU
needs to clear the DSPINT bit; otherwise, no more DSPINTs can be received.
关于boot的配置,见文档的5.4节。
5.4 C6205 DSP Boot and Device Configuration
Yujing Wang 说:我现在用的是nor flash,发现EMIF接口有信号,片选信号每次使能(拉低)时间大约16us,禁能(拉高)时间很短,说明DSP和FLASH有通信吧?这个通信速度是DSP内部固件决定的?
这是芯片的bootloader通过DMA在从flash搬代码到adress 0. DMA访问是连续的,所以你看到CS拉低很长时间。这是DSP内部固件决定的。
Yujing Wang 说:现在的现象是:一样的程序,烧写在FLASH运行速度和直接在线仿真速度相差很多,比在线慢很多,这大概是什么原因呢?
这个你是怎么判断的?同样的代码速度有区别,那就看一下PLL的配置是不是一样了。还是参考spru642的5.4节.
我的代码是点LED的,两种方式下LED闪烁的频率不同,用示波器查看高低电平持续的时间差很多
PLL就是硬件配置的,就是PLLCONF[0:2],程序里没有
DMA会一直搬代码吗?还是搬固定大小的代码就不搬了?现在是一直有信号
我又看了一下绿色部分,是搬64K就不搬了是吧?现在是一直有信号啊
还有如果程序超过64K怎么办呢?
还有那个XIP是什么意思啊?
二级boot也是搬64K吗?还是二级boot就没有限制了呢?
一直是LED已经闪烁了,我随时测还是有拉低。或者我是什么地方配置错了导致的?
是一个程序,我刚又比较了一下代码
如果我的代码是64K的很多倍,而C6205也不支持XIP,那我的程序想跑起来要怎么办呢?
Yujing Wang 说:如果我的代码是64K的很多倍,而C6205也不支持XIP,那我的程序想跑起来要怎么办呢?
看看这个文档:
http://www.ti.com/dsp/docs/litabsmultiplefilelist.tsp?sectionId=3&tabId=409&literatureNumber=spra999a&docCategoryId=1&familyId=114&keyMatch=how%20to%20create%20a%20second%20bootloader&tisearch=Search-EN-Everything
通道支持XIP的话,你就让代码一直在NOR flash里慢慢跑吗?nor flash很慢的,所以二级boot是很必要的。
你做什么东西,非得要用C6205这么老的芯片?
是比较有规律的周期拉低拉高,每次拉低的时间比拉高的长很多,我再看看代码
我现在没看到在nor flash跑的速度,所以不太清楚这一点
二级boot能解决就好
我需要32位EMIF和PCIE,价格最好低点,选来选去最后还是选的6205...
二级boot能解决就好
我需要32位EMIF和PCIE,价格最好低点,就选了6205
初次接触DSP,基础知识很欠缺。。。
没有配置成SDRAM,配置的异步的,但是CE1还是有拉低
还可能有哪方面原因呢?
我查看了FLASH里的数据,确实与生成的.hex文件是一致的,但是执行起来闪烁速度就是比在线慢很多
