WIN8系统-64bit 安装CCS6.1.3.00033版本,提示安装过程出错,错误信息如下:
!SESSION 2016-06-30 12:04:19.501 -----------------------------------------------
eclipse.buildId=4.5.1.M20150904-0015
java.version=1.7.0_80
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Framework arguments: -application com.ti.common.core.initialize -ccs.profileTag Installed Code Composer Studio 6.1.3.00033.
Command-line arguments: -os win32 -ws win32 -arch x86 -application com.ti.common.core.initialize -data C:/Users/Administrator/AppData/Local/Temp/ccs_f76897ee-1cae-482a-7b2f-05f40182f47e/workspace -ccs.profileTag Installed Code Composer Studio 6.1.3.00033.
!ENTRY com.ti.common.core 4 0 2016-06-30 12:04:27.149
!MESSAGE path=ccs_base/DebugServer
!ENTRY com.ti.common.core 4 0 2016-06-30 12:04:27.152
!MESSAGE debugServerDir=C:/ti/ccsv6/ccs_base/DebugServer
!ENTRY org.eclipse.core.jobs 4 2 2016-06-30 12:04:31.223
!MESSAGE An internal error occurred during: "CrashTrackerJob".
!STACK 0
java.lang.UnsatisfiedLinkError: C:\ti\ccsv6\ccs_base\DebugServer\bin\LibraryLoader.dll: Can't find dependent libraries
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary1(ClassLoader.java:1965)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1890)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1851)
at java.lang.Runtime.load0(Runtime.java:795)
at java.lang.System.load(System.java:1062)
at com.ti.debug.engine.xpcom.Runtime.preXPCOMInit(Runtime.java:163)
at com.ti.debug.engine.xpcom.Runtime.startBare(Runtime.java:116)
at com.ti.debug.engine.xpcom.Runtime.createComponent(Runtime.java:170)
at com.ti.utility.filesystem.DirectoryService.<init>(DirectoryService.java:26)
at com.ti.utility.filesystem.DirectoryService.<init>(DirectoryService.java:9)
at com.ti.utility.filesystem.DirectoryService$SingletonHolder.<clinit>(DirectoryService.java:44)
at com.ti.utility.filesystem.DirectoryService.instance(DirectoryService.java:49)
at com.ti.ccstudio.debug.server.DebugServerPlugin$1.run(DebugServerPlugin.java:117)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
!ENTRY org.eclipse.osgi 4 0 2016-06-30 12:04:33.656
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: Could not initialize class com.ti.utility.filesystem.DirectoryService$SingletonHolder
at com.ti.common.core.utils.ds.CoreUtilsProvider.getUserHomeDir(CoreUtilsProvider.java:40)
at com.ti.common.core.CoreUtils.getUserHomeDir(CoreUtils.java:135)
at com.ti.common.core.internal.ExternalReferenceParser.getUserExtRefDir(ExternalReferenceParser.java:176)
at com.ti.common.core.internal.ExternalReferenceParser.getExtRefDirectories(ExternalReferenceParser.java:158)
at com.ti.common.core.internal.ExternalReferenceParser.getReferenceFiles(ExternalReferenceParser.java:61)
at com.ti.common.core.internal.ExternalReferenceParser.getReferenceFiles(ExternalReferenceParser.java:147)
at org.eclipse.rtsc.xdctools.managedbuild.core.products.RTSCProductDiscoveryManager.getExtensionSiteDiscoveryPath(RTSCProductDiscoveryManager.java:457)
at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.getUserSearchPath(ExtensionSiteDiscoveryManager.java:122)
at org.eclipse.rtsc.project.core.extdiscovery.ProductManifestRegistry.<init>(ProductManifestRegistry.java:84)
at org.eclipse.rtsc.project.core.extdiscovery.ProductManifestRegistry.<clinit>(ProductManifestRegistry.java:73)
at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.collectExtensionSiteDirsToAdd(ExtensionSiteDiscoveryManager.java:749)
at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.createExtensionSites(ExtensionSiteDiscoveryManager.java:214)
at org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.createAndAddExtensionSites(ExtensionSiteDiscoveryManager.java:169)
at org.eclipse.rtsc.project.core.extdiscovery.RTSCIDEInitializationParticipant.run(RTSCIDEInitializationParticipant.java:89)
at com.ti.common.core.internal.headless.Initialize.run(Initialize.java:45)
at com.ti.common.core.internal.headless.Initialize.start(Initialize.java:32)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
有谁遇到过这种情况,这个问题怎么解决?
附件是安装过程产生的LOG文件
