这几天在做语音信号的时域分析基于DSP5509实现的实验时,工程编译通过,没有错误,但有两个警告。下载程序无法成功,以下是具体情况描述。
1、编译警告
(1)、Severity and Description Path Resource Location Creation Time Id creating ".stack" section with default size of 0x3e8; use the -stack option to change the default size audio_fir line 0 1467274960686 430
(2)、Severity and Description Path Resource Location Creation Time Id creating ".sysstack" section with default size of 0x3e8; use the -sysstack option to change the default size audio_fir line 0 1467274960686 431
2、程序下载时出现的问题:
C55xx: GEL Output: C5509A Init Complete.
C55xx: File Loader: Data verification failed at address 0x00FFFF00 Please verify target memory and memory map.
Error found during data verification.
Ensure the linker command file matches the memory map.
警告暂时还不明白是什么问题。程序下载不成功,提示自己的内存映射不对,但是这一块暂时不知道该怎么改。下面是我工程的cmd文件内容,各位路过的牛人、老师知道的话,谢谢你们指点一二。
-w
-lrts55x.lib
MEMORY
PAGE 0:
MMR : origin = 0000000h, length = 00000c0h
SPRAM : origin = 00000c0h, length = 0000040h
DARAM0 : origin = 0000100h, length = 0003F00h
DARAM1 : origin = 0004000h, length = 0004000h
DARAM2 : origin = 0008000h, length = 0004000h
DARAM3 : origin = 000c000h, length = 0004000h
SARAM0 : origin = 0010000h, length = 0004000h
SARAM1 : origin = 0014000h, length = 0004000h
SARAM2 : origin = 0018000h, length = 0004000h
SARAM3 : origin = 001c000h, length = 0004000h
SARAM4 : origin = 0020000h, length = 0004000h
SARAM5 : origin = 0024000h, length = 0004000h
SARAM6 : origin = 0028000h, length = 0004000h
SARAM7 : origin = 002c000h, length = 0004000h
SARAM8 : origin = 0030000h, length = 0004000h
SARAM9 : origin = 0034000h, length = 0004000h
SARAM10 : origin = 0038000h, length = 0004000h
SARAM11 : origin = 003c000h, length = 0004000h
SARAM12 : origin = 0040000h, length = 0004000h
SARAM13 : origin = 0044000h, length = 0004000h
SARAM14 : origin = 0048000h, length = 0004000h
SARAM15 : origin = 004c000h, length = 0004000h
CE0 : origin = 0050000h, length = 03b0000h
CE1 : origin = 0400000h, length = 0400000h
CE2 : origin = 0800000h, length = 0400000h
CE3 : origin = 0c00000h, length = 03f8000h
PDROM : origin = 0ff8000h, length = 07f00h
VECS : origin = 0ffff00h, length = 00100h /* reset vector */
SECTIONS
vectors : {} > VECS PAGE 0 /* interrupt vector table */
.cinit : {} > SARAM0 PAGE 0
.text : {} > SARAM1 PAGE 0
isrs : {} > SARAM2 PAGE 0
.stack : {} > DARAM0 PAGE 0
.sysstack: {} > DARAM0 PAGE 0
.sysmem : {} > DARAM1 PAGE 0
.data : {} > DARAM1 PAGE 0
.bss : {} > DARAM1 PAGE 0
.const : {} > DARAM1 PAGE 0
.coeffs : {} > DARAM2 PAGE 0
.dbuffer : {} > DARAM3 PAGE 0
files : {} > DARAM2 PAGE 0 /* User-defined sections */
statvar : {} > DARAM2 PAGE 0
statarry : {} > DARAM2 PAGE 0
tempvar : {} > DARAM2 PAGE 0
temparry : {} > DARAM2 PAGE 0
sounds : {} > SARAM3 PAGE 0
