参照IPC_Install_Guide_linux编辑/ti/ipc_3_36_02_13文件夹下的products.mak,编辑如下:
TOOLCHAIN_LONGNAME = arm-linux-gnueabihf
TOOLCHAIN_INSTALL_DIR = /home/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux
TOOLCHAIN_PREFIX = $(TOOLCHAIN_INSTALL_DIR)/bin/$(TOOLCHAIN_LONGNAME)-
KERNEL_INSTALL_DIR = /home/ict/Work/TI_GIT/linux-keystone
XDC_INSTALL_DIR = $(DEPOT)/xdctools_3_31_02_38_core
BIOS_INSTALL_DIR = $(DEPOT)/bios_6_41_04_54
执行make -f ipc-linux.mak config;make;make instal
make -f ipc-bios.mak all
执行到这都没有问题,能够编译成功。
但在编译examples/TCI6638_linux_elf/ex44_compute时候出现了以下问题:
make[2]: 正在进入目录 `/ti/ipc_3_36_02_13/examples/TCI6638_linux_elf/ex44_compute/host'
# Making bin/debug/obj/MainHost.ov7A ...
/home/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/bin/arm-linux-gnueabihf-gcc -c -MD -MF bin/debug/obj/MainHost.ov7A.dep -D_REENTRANT -Wall -ffloat-store -fPIC -Wunused -Dfar= -ggdb -D DEBUG -I. -I/ti/ipc_3_36_02_13/include -o bin/debug/obj/MainHost.ov7A MainHost.c
MainHost.c:43:24: fatal error: ti/ipc/Std.h: 没有那个文件或目录
compilation terminated.
make[2]: *** [bin/debug/obj/MainHost.ov7A] 错误 1
make[2]:正在离开目录 `/ti/ipc_3_36_02_13/examples/TCI6638_linux_elf/ex44_compute/host'
make[1]: *** [all] 错误 2
make[1]:正在离开目录 `/ti/ipc_3_36_02_13/examples/TCI6638_linux_elf/ex44_compute/host'
make: *** [host] 错误 2
ex44_compute文件夹下的products.mak编辑为:
EPOT =/ti
#### Linux toolchain ####
#### BIOS-side dependencies ####
IPC_INSTALL_DIR = $(DEPOT)/ipc_3_36_02_13
DESTDIR = $(DEPOT)/ipc_3_36_02_13
#### BIOS-side toolchains ####
ti.targets.elf.C66 = /ti/ccsv6/tools/compiler/ti-cgt-c6000_8.1.0
请帮忙看一下是哪里出了问题,为什么会找不到ti/ipc/Std.h文件呢?
