CCS Memory Browser符号
Other Parts Discussed in Thread: DM3730
请问在CCS Memory Browser里,短横线表示什么意思?
MPU_INTC寄存器在程序运行的时候会显示问号,暂停了就显示短横线
而UART3始终显示的是问号
  • He Zhiwen,
    请问你使用的是什么芯片? 请确认相应模块的时钟有正确打开。
  • DM3730,请问MPU_INTC模块的时钟怎么开?TRM似乎没有明确说明
    如果URAT的模块时钟没有打开, memory browser显示的也是问号, 但MPU_INTC这里始终显示的是" - "
    请问短横线表示什么?
  • TRM里写到INTC的interface clock的source是PRCM模块,但PRCM的哪个寄存器可以控制ICLK呢?
  • When you first invoke Code Composer Studio, the memory map is turned off. You can access any memory location; the memory map does not interfere. When memory mapping is enabled, the debugger checks each of its memory accesses against the memory map provided. If you try to access an undefined or protected area, the debugger will prevent the access from occurring and the debugger will display the value as a series of dashes (-).
