我想把图像灰度处理,当加载完图像之后,在View/Grap中无法显示出来,显示就是一张混乱的彩图
//#include <csl.h>
#include <stdio.h>
//#include <math.h>
#define width 205
#define height 202
//#pragma DATA_SECTION(Image ,"sect_my")
//#define Image_R (*(unsigned char *)(0x80000000))
//#define Image_G (*(unsigned char *)(0x80000000))
//#define Image_B (*(unsigned char *)(0x80000000))
//#define Gray (*(unsigned char *)(0x80003000))
unsigned char *Image_R ;
unsigned char *Image_G ;
unsigned char *Image_B ;
unsigned char *Gray ;
#pragma DATA_SECTION(RGB_IMG ,".image") ; //为RGB_IMG分配一个段,段名为
int RGB_IMG[40000] ;
#pragma DATA_SECTION(R_IMG ,".image") ;
unsigned char R_IMG[20000] ;
#pragma DATA_SECTION(G_IMG ,".image") ;
unsigned char G_IMG[20000] ;
#pragma DATA_SECTION(B_IMG ,".image") ;
unsigned char B_IMG[20000] ;
#pragma DATA_SECTION(Gray_IMG ,".image") ;
unsigned char Gray_IMG[20000] ;
void RGB2Gray() ;
void main()
int i ;
int *Img ;
int cols_1 = width ;
int rows_1 = height ;
Image_R = R_IMG ;
Image_G = G_IMG ;
Image_B = B_IMG ;
Img = RGB_IMG ;
Gray = Gray_IMG ;
for(i = 0 ;i < cols_1*rows_1 ;i++)
*Image_R++ = *Img++ ;
*Image_G++ = *Img++ ;
*Image_B++ = *Img++ ;
Image_R = R_IMG ;
Image_G = G_IMG ;
Image_B = B_IMG ;
Gray = Gray_IMG ;
while(1)
RGB2Gray(Image_R,Image_G,Image_B,cols_1,rows_1,1);
//对图形进行灰度处理
void RGB2Gray
unsigned char *R ,
unsigned char *G ,
unsigned char *B ,
unsigned char *Gray ,
int cols ,
int rows ,
int flag
int i ;
//为待生成的灰度图像分配空间
// Gray = (unsigned char *)calloc(cols * rows ,sizwof(unsigned char)) ;
// Gray = (unsigned char *)0x800030000 ;
for(i = 0 ;i < cols * rows ;i++)
if(flag == 1)
*Gray++ = 0.3 * (*R++) + 0.59 * (*G++) + 0.11 *(*G++) ;
else if(flag == 2)
*Gray++ = ((* R++) + (* G++) + (* B++))/3 ;
else
Gray[i] = R[i] ;
if(G[i] > Gray[i])
Gray[i] = G[i] ;
if(B[i] > Gray[i])
Gray[i] = B[i] ;
