jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found......................
Other Parts Discussed in Thread: AM3358, TPS65910
你好!am3358平台,使用am335x-evm-sdk-src-08.00.00.00.tar.gz中的根文件系统,用命令mkfs.jffs2  -d filesystem -e 128 -s 2048 --pad=0x15e00000   -o rootfs_new.jffs2  将rootfs_new.jffs2烧进nand flash后,启动出现如下的错误:
[ 1.875286] bits in OOB size: 4
[ 1.878561] flash size with OOB: 135168 KiB
[ 1.882949] page address bytes: 4
[ 1.886406] sector address bytes: 3
[ 1.890068] options: 0x42
[ 1.895284] Scanning device for bad blocks
[ 2.006719] Creating 1 MTD partitions on "NAND 128MiB 1,8V 8-bit":
[ 2.013260] 0x000000000000-0x000008000000 : "NAND simulator partition 0"
[ 2.036993] usbcore: registered new interface driver asix
[ 2.043722] usbcore: registered new interface driver ax88179_178a
[ 2.050655] usbcore: registered new interface driver cdc_ether
[ 2.057221] usbcore: registered new interface driver smsc95xx
[ 2.063722] usbcore: registered new interface driver net1080
[ 2.070103] usbcore: registered new interface driver cdc_subset
[ 2.076706] usbcore: registered new interface driver zaurus
[ 2.083103] usbcore: registered new interface driver cdc_ncm
[ 2.090686] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.097517] ehci-platform: EHCI generic platform driver
[ 2.103870] ehci-omap: OMAP-EHCI Host Controller driver
[ 2.111417] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.117931] ohci-platform: OHCI generic platform driver
[ 2.123969] ohci-omap3: OHCI OMAP3 driver
[ 2.131502] fusbh200_hcd: FUSBH200 Host Controller (EHCI) Driver
[ 2.137787] Warning! fusbh200_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[ 2.147667] fotg210_hcd: FOTG210 Host Controller (EHCI) Driver
[ 2.153824] 4Warning! fotg210_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[ 2.164674] usbcore: registered new interface driver cdc_acm
[ 2.170662] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.179456] usbcore: registered new interface driver cdc_wdm
[ 2.185912] usbcore: registered new interface driver usb-storage
[ 2.192632] usbcore: registered new interface driver ums-alauda
[ 2.199212] usbcore: registered new interface driver ums_eneub6250
[ 2.206145] usbcore: registered new interface driver ums-realtek
[ 2.212917] usbcore: registered new interface driver usbtest
[ 2.224447] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 2.237629] musb-hdrc musb-hdrc.0.auto: Failed to request rx1.
[ 2.244358] musb-hdrc musb-hdrc.0.auto: musb_init_controller failed with status -517
[ 2.252627] platform musb-hdrc.0.auto: Driver musb-hdrc requests probe deferral
[ 2.262175] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 2.273827] musb-hdrc musb-hdrc.1.auto: Failed to request rx1.
[ 2.280290] musb-hdrc musb-hdrc.1.auto: musb_init_controller failed with status -517
[ 2.288469] platform musb-hdrc.1.auto: Driver musb-hdrc requests probe deferral
[ 2.341388] mousedev: PS/2 mouse device common for all mice
[ 2.353234] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 2.362940] i2c /dev entries driver
[ 2.366980] Driver for 1-wire Dallas network protocol.
[ 2.377906] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 2.400390] omap_hsmmc 48060000.mmc: unable to get vmmc regulator -517
[ 2.407801] platform 48060000.mmc: Driver omap_hsmmc requests probe deferral
[ 2.537045] usbcore: registered new interface driver usbhid
[ 2.542988] usbhid: USB HID core driver
[ 2.548353] platform 44d00000.wkup_m3: Driver wkup_m3 requests probe deferral
[ 2.568521] davinci_evm sound.11: ASoC: CODEC (null) not registered
[ 2.575511] davinci_evm sound.11: snd_soc_register_card failed (-517)
[ 2.582383] platform sound.11: Driver davinci_evm requests probe deferral
[ 2.591960] oprofile: using arm/armv7
[ 2.596542] TCP: cubic registered
[ 2.600131] Initializing XFRM netlink socket
[ 2.604741] NET: Registered protocol family 17
[ 2.609466] NET: Registered protocol family 15
[ 2.614506] Key type dns_resolver registered
[ 2.622107] PM: bootloader does not support rtc-only!
[ 2.627416] ThumbEE CPU extension supported.
[ 2.632380] Registering SWP/SWPB emulation handler
[ 2.637395] SmartReflex Class3 initialized
[ 2.646342] wlan-en-regulator: disabling
[ 2.650636] lis3_reg: disabling
[ 2.653923] vbat: disabling
[ 2.656841] regulator-dummy: disabling
[ 2.662442] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 2.667992] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 2.677100] nand: device found, Manufacturer ID: 0x01, Chip ID: 0xd3
[ 2.683935] nand: AMD/Spansion S34ML08G1
[ 2.688036] nand: 1024MiB, SLC, page size: 2048, OOB size: 64
[ 2.694129] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 2.700143] 10 ofpart partitions found on MTD device omap2-nand.0
[ 2.706510] Creating 10 MTD partitions on "omap2-nand.0":
[ 2.712197] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 2.724140] 0x000000020000-0x000000040000 : "NAND.SPL.backup1"
[ 2.735021] 0x000000040000-0x000000060000 : "NAND.SPL.backup2"
[ 2.745880] 0x000000060000-0x000000080000 : "NAND.SPL.backup3"
[ 2.756898] 0x000000080000-0x0000000c0000 : "NAND.u-boot-spl-os"
[ 2.768363] 0x0000000c0000-0x0000001c0000 : "NAND.u-boot"
[ 2.779527] 0x0000001c0000-0x0000001e0000 : "NAND.u-boot-env"
[ 2.790751] 0x0000001e0000-0x000000200000 : "NAND.u-boot-env.backup1"
[ 2.802464] 0x000000200000-0x000000a00000 : "NAND.kernel"
[ 2.819745] 0x000000a00000-0x000010000000 : "NAND.file-system"
[ 3.045915] tps65910 0-002d: No interrupt support, no core IRQ
[ 3.061160] vrtc: 1800 mV
[ 3.064509] vrtc: supplied by vbat
[ 3.071641] vio: at 1500 mV
[ 3.074864] vio: supplied by vbat
[ 3.081831] vdd_mpu: 912 <--> 1375 mV at 1325 mV
[ 3.086950] vdd_mpu: supplied by vbat
[ 3.094272] vdd_core: 912 <--> 1150 mV at 1137 mV
[ 3.099498] vdd_core: supplied by vbat
[ 3.106395] vdd3: 5000 mV
[ 3.112030] vdig1: at 1800 mV
[ 3.115429] vdig1: supplied by vbat
[ 3.122081] vdig2: at 1800 mV
[ 3.125471] vdig2: supplied by vbat
[ 3.132148] vpll: at 1800 mV
[ 3.135448] vpll: supplied by vbat
[ 3.141920] vdac: at 1800 mV
[ 3.145231] vdac: supplied by vbat
[ 3.151694] vaux1: at 1800 mV
[ 3.155072] vaux1: supplied by vbat
[ 3.161704] vaux2: at 3300 mV
[ 3.165087] vaux2: supplied by vbat
[ 3.171627] vaux33: at 3300 mV
[ 3.175102] vaux33: supplied by vbat
[ 3.181758] vmmc: 1800 <--> 3300 mV at 3300 mV
[ 3.186689] vmmc: supplied by vbat
[ 3.193994] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 3.210116] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 3.222100] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 3.231778] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 1
[ 3.241548] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.248650] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.256269] usb usb1: Product: MUSB HDRC host driver
[ 3.261489] usb usb1: Manufacturer: Linux 3.14.26-g07d13c6-dirty musb-hcd
[ 3.268577] usb usb1: SerialNumber: musb-hdrc.0.auto
[ 3.279130] hub 1-0:1.0: USB hub found
[ 3.284078] hub 1-0:1.0: 1 port detected
[ 3.299793] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 3.307896] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 2
[ 3.316855] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.324072] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.331653] usb usb2: Product: MUSB HDRC host driver
[ 3.336837] usb usb2: Manufacturer: Linux 3.14.26-g07d13c6-dirty musb-hcd
[ 3.343953] usb usb2: SerialNumber: musb-hdrc.1.auto
[ 3.352112] hub 2-0:1.0: USB hub found
[ 3.356168] hub 2-0:1.0: 1 port detected
[ 3.401499] remoteproc0: wkup_m3 is available
[ 3.406164] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 3.415709] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 3.428731] remoteproc0: Direct firmware load failed with error -2
[ 3.435386] remoteproc0: Falling back to user helper
[ 3.449110] davinci_evm sound.11: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[ 3.474536] pinctrl-single 44e10800.pinmux: pin 44e10948.0 already requested by 4a100000.ethernet; cannot claim for 4a101000.mdio
[ 3.486948] pinctrl-single 44e10800.pinmux: pin-82 (4a101000.mdio) status -22
[ 3.494455] pinctrl-single 44e10800.pinmux: could not request pin 82 (44e10948.0) from group davinci_mdio_default on device pinctrl-single
[ 3.507574] davinci_mdio 4a101000.mdio: Error applying setting, reverse things back
[ 3.579946] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 3.586334] davinci_mdio 4a101000.mdio: detected phy mask ffffffde
[ 3.596617] libphy: 4a101000.mdio: probed
[ 3.600954] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver unknown
[ 3.609314] davinci_mdio 4a101000.mdio: phy[5]: device 4a101000.mdio:05, driver unknown
[ 3.619532] cpsw 4a100000.ethernet: Detected MACID = 68:c9:0b:a8:3f:9a
[ 3.632650] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 3.641796] sr_init: No PMIC hook to init smartreflex
[ 3.650788] sr_init: platform driver register failed for SR
[ 3.674229] ALSA device list:
[ 3.677358] #0: AM335x-EVM
[ 3.685087] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000020: 0x0002 instead
[ 3.696621] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000024: 0x2818 instead
[ 3.707220] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000002c: 0xedf8 instead
[ 3.717332] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000030: 0x9000 instead
[ 3.727315] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000034: 0x0dd1 instead
[ 3.737253] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000038: 0x7001 instead
[ 3.747182] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000003c: 0x8002 instead
[ 3.757107] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000040: 0x2000 instead
[ 3.767199] usb 2-1: new high-speed USB device number 2 using musb-hdrc
[ 3.774374] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000044: 0x0003 instead
[ 3.784463] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000048: 0x0001 instead
[ 3.794401] jffs2: Further such events for this erase block will not be printed
[ 3.823544] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020000: 0x8587 instead
[ 3.833689] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020004: 0x4cff instead
[ 3.843807] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020008: 0x4bfd instead
[ 3.853754] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0002000c: 0xd39f instead
[ 3.863682] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020010: 0x50b3 instead
[ 3.873608] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020014: 0xb4f5 instead
[ 3.883533] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020018: 0x3ab1 instead
[ 3.893459] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0002001c: 0x0c09 instead
[ 3.903848] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020020: 0xbabb instead
[ 3.913819] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020024: 0x5cf3 instead
[ 3.923770] jffs2: Further such events for this erase block will not be printed
[ 3.947975] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101
[ 3.955040] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.962522] usb 2-1: Product: USB 2.0 Hub
[ 3.972079] jffs2: Old JFFS2 bitmask found at 0x0003f1b8
[ 3.977639] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 3.987288] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040000: 0xc8f0 instead
[ 3.999157] hub 2-1:1.0: USB hub found
[ 4.003385] hub 2-1:1.0: 4 ports detected
[ 4.009156] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040004: 0x88c2 instead
[ 4.020627] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040008: 0x7c18 instead
[ 4.030681] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0004000c: 0xb800 instead
[ 4.040955] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040010: 0x3ac3 instead
[ 4.050950] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040014: 0xc994 instead
[ 4.060899] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040018: 0x3bc9 instead
[ 4.070829] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0004001c: 0x3403 instead
[ 4.080755] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040020: 0x3ea1 instead
[ 4.090681] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040024: 0xa023 instead
[ 4.100604] jffs2: Further such events for this erase block will not be printed
[ 4.129998] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060000: 0x2b2c instead
[ 4.143352] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060004: 0x7eb1 instead
[ 4.153338] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060008: 0xf2f3 instead
[ 4.165681] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0006000c: 0xa3ac instead
[ 4.175630] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060010: 0xc739 instead
[ 4.185561] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060014: 0xd3df instead
[ 4.195574] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060018: 0xfb4f instead
[ 4.205510] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0006001c: 0x0e3b instead
[ 4.215524] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060020: 0xa178 instead
[ 4.225460] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060024: 0xb7cc instead
[ 4.235385] jffs2: Further such events for this erase block will not be printed
[ 4.264367] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080000: 0x18c9 instead
[ 4.274344] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080004: 0xeda9 instead
[ 4.284278] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080008: 0x1a4a instead
[ 4.294205] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008000c: 0xfdf0 instead
[ 4.304132] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080010: 0xcf22 instead
[ 4.314059] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080014: 0x1f69 instead
[ 4.323984] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080018: 0x40ef instead
[ 4.333908] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008001c: 0x4206 instead
[ 4.343833] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080020: 0xd356 instead
[ 4.353758] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080024: 0x4579 instead
[ 4.363680] jffs2: Further such events for this erase block will not be printed
[ 4.392424] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0000: 0x4dd8 instead
[ 4.402375] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0004: 0x9560 instead
[ 4.412305] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0008: 0x856f instead
[ 4.422232] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a000c: 0x5ae9 instead
[ 4.432158] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0010: 0x2271 instead
[ 4.442083] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0014: 0xd1f6 instead
[ 4.452008] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0018: 0x3d6b instead
[ 4.461932] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a001c: 0xd6f0 instead
[ 4.471857] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0020: 0x16bf instead
[ 4.481782] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0024: 0x3913 instead
[ 4.491703] jffs2: Further such events for this erase block will not be printed
[ 4.520396] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0000: 0x8b70 instead
[ 4.530337] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0004: 0xb537 instead
[ 4.540265] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0008: 0x21c1 instead
[ 4.550191] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c000c: 0xcf3c instead
[ 4.560121] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0010: 0x26fb instead
[ 4.570048] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0014: 0xb938 instead
[ 4.579975] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0018: 0x7c6e instead
[ 4.589900] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c001c: 0x7dff instead
[ 4.599797] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0020: 0x3cf2 instead
[ 4.609721] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0024: 0xf1a2 instead
[ 4.619643] jffs2: Further such events for this erase block will not be printed
[ 4.648291] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0000: 0xc734 instead
[ 4.658238] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0004: 0xfe61 instead
[ 4.668168] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0008: 0x99d5 instead
[ 4.678095] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e000c: 0x7f1d instead
[ 4.688020] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0010: 0x633e instead
[ 4.697945] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0014: 0x9cd4 instead
[ 4.707870] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0018: 0x1180 instead
[ 4.717795] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e001c: 0xf217 instead
[ 4.727720] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0020: 0x74a9 instead
[ 4.737644] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0024: 0x86c3 instead
[ 4.747566] jffs2: Further such events for this erase block will not be printed
[ 4.776191] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100000: 0xc7d5 instead
[ 4.786139] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100004: 0xeb8f instead
[ 4.796069] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100008: 0xeb9c instead
[ 4.805995] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0010000c: 0xf40d instead
[ 4.815921] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100010: 0xf448 instead
[ 4.825846] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100014: 0x59fb instead
[ 4.835771] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100018: 0x7bdc instead
[ 4.845696] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0010001c: 0xb4fd instead
[ 4.855621] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100020: 0xf44e instead
[ 4.865545] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100024: 0x1297 instead
[ 4.875467] jffs2: Further such events for this erase block will not be printed
[ 4.900323] jffs2: Old JFFS2 bitmask found at 0x0010a280
[ 4.905869] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 4.917028] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120000: 0x048c instead
[ 4.926970] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120004: 0xc6f4 instead
[ 4.936898] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120008: 0x41b8 instead
[ 4.946825] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0012000c: 0xcf9a instead
[ 4.956750] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120010: 0xcc76 instead
[ 4.966675] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120014: 0x2d08 instead
[ 4.976600] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120018: 0x8b94 instead
[ 4.986524] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0012001c: 0xc047 instead
[ 4.996450] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120020: 0x0377 instead
[ 5.006375] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120024: 0x385b instead
[ 5.016296] jffs2: Further such events for this erase block will not be printed
[ 5.045113] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140000: 0xbf56 instead
[ 5.055710] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140004: 0x2afa instead
[ 5.065697] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140008: 0x6c3a instead
[ 5.075629] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0014000c: 0xb51b instead
[ 5.085558] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140010: 0xfdce instead
[ 5.095483] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140014: 0x94b9 instead
[ 5.105409] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140018: 0x10c6 instead
[ 5.115335] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0014001c: 0xfb06 instead
[ 5.125261] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140020: 0xe643 instead
[ 5.135188] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140024: 0x9734 instead
[ 5.145111] jffs2: Further such events for this erase block will not be printed
[ 5.173963] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160000: 0x97ff instead
[ 5.183933] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160004: 0x3a35 instead
[ 5.193866] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160008: 0xd149 instead
[ 5.203799] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0016000c: 0x5c94 instead
[ 5.213725] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160010: 0x51de instead
[ 5.223651] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160014: 0x3ee9 instead
[ 5.233577] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160018: 0xcb26 instead
[ 5.243501] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0016001c: 0x2f32 instead
[ 5.253426] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160020: 0x7b8c instead
[ 5.263351] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160024: 0xf197 instead
[ 5.273273] jffs2: Further such events for this erase block will not be printed
[ 5.298273] jffs2: Old JFFS2 bitmask found at 0x0016b24c
[ 5.303859] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 5.314926] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180000: 0x35aa instead
[ 5.324879] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180004: 0x3b1a instead
[ 5.334810] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180008: 0x1d94 instead
[ 5.344735] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0018000c: 0x3baf instead
[ 5.354662] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180010: 0xc3c8 instead
[ 5.364588] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180014: 0xcc89 instead
[ 5.374512] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180018: 0x6fa9 instead
[ 5.384437] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0018001c: 0x91d9 instead
[ 5.394362] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180020: 0x1ef1 instead
[ 5.404287] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180024: 0x9aa4 instead
[ 5.414208] jffs2: Further such events for this erase block will not be printed
[ 5.442879] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0000: 0x97b1 instead
[ 5.452825] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0004: 0x77a8 instead
[ 5.462755] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0008: 0xf99e instead
[ 5.472681] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a000c: 0x8f19 instead
[ 5.482605] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0010: 0x7a24 instead
[ 5.492531] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0014: 0x25de instead
[ 5.502456] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0018: 0x8e21 instead
[ 5.512381] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a001c: 0x7936 instead
[ 5.522306] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0020: 0x4fb7 instead
[ 5.532231] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0024: 0xcb57 instead
[ 5.542153] jffs2: Further such events for this erase block will not be printed
[ 5.570805] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0000: 0x569c instead
[ 5.580745] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0004: 0x27cc instead
[ 5.590673] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0008: 0x68cc instead
[ 5.600600] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c000c: 0x9f1a instead
[ 5.610525] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0010: 0x6bb8 instead
[ 5.620450] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0014: 0xe507 instead
[ 5.630375] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0018: 0xa75b instead
[ 5.640299] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c001c: 0x1e90 instead
[ 5.650224] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0020: 0xa4f9 instead
[ 5.660149] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0024: 0x2b9c instead
[ 5.670070] jffs2: Further such events for this erase block will not be printed
[ 5.698663] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0000: 0x3a26 instead
[ 5.708606] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0004: 0x9e73 instead
[ 5.718534] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0008: 0x031c instead
[ 5.728468] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e000c: 0x1757 instead
[ 5.738401] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0010: 0xf942 instead
[ 5.748333] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0014: 0x458e instead
[ 5.758265] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0018: 0xd679 instead
[ 5.768197] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e001c: 0x26ab instead
[ 5.778129] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0020: 0x7981 instead
[ 5.788061] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0024: 0xe594 instead
[ 5.797990] jffs2: Further such events for this erase block will not be printed
[ 5.826635] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200000: 0xaf79 instead
[ 5.836583] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200004: 0x28e2 instead
[ 5.846514] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200008: 0x4ea9 instead
[ 5.856442] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020000c: 0x6ae8 instead
[ 5.866367] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200010: 0xcba4 instead
[ 5.876292] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200014: 0xc104 instead
[ 5.886217] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200018: 0x3c64 instead
[ 5.896143] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020001c: 0x76f0 instead
[ 5.906067] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200020: 0x82cf instead
[ 5.915992] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200024: 0x758e instead
[ 5.925914] jffs2: Further such events for this erase block will not be printed
[ 5.954558] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220000: 0x6350 instead
[ 5.964505] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220004: 0xf3d9 instead
[ 5.974436] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220008: 0x1e7f instead
[ 5.984363] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0022000c: 0xc8cf instead
[ 5.994290] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220010: 0xcfde instead
[ 6.004216] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220014: 0x7639 instead
[ 6.014140] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220018: 0x28d4 instead
[ 6.024065] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0022001c: 0x1735 instead
[ 6.033990] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220020: 0x9ccd instead
[ 6.044041] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220024: 0x71f9 instead
[ 6.053984] jffs2: Further such events for this erase block will not be printed
[ 6.082678] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00240000: 0xd1cf instead
[ 6.092626] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00240004: 0xfcea instead
[ 6.102556] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00240008: 0xa6a9 instead
[ 6.112482] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0024000c: 0x0c33 instead
[ 6.122409] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00240010: 0x9e67 instead
[ 6.132335] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00240014: 0x1a3b instead
[ 6.142262] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00240018: 0xba24 instead
[ 6.152187] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0024001c: 0xe68e instead
[ 6.162111] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00240020: 0xcd38 instead
[ 6.172037] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00240024: 0x8a45 instead
[ 6.181958] jffs2: Further such events for this erase block will not be printed
[ 6.210623] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00260000: 0xd07d instead
[ 6.220565] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00260004: 0xc4a5 instead
[ 6.230494] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00260008: 0xb6a5 instead
[ 6.240420] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0026000c: 0xf2f7 instead
[ 6.250344] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00260010: 0xfa43 instead
[ 6.260269] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00260014: 0x0b7f instead
[ 6.270194] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00260018: 0x35c5 instead
[ 6.280119] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0026001c: 0x0afa instead
[ 6.290044] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00260020: 0x99fd instead
[ 6.299969] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00260024: 0x84ad instead
[ 6.309890] jffs2: Further such events for this erase block will not be printed
[ 6.338493] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00280000: 0x922d instead
[ 6.348440] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00280004: 0x2b97 instead
[ 6.358370] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00280008: 0x0fb8 instead
[ 6.368297] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0028000c: 0xb24c instead
[ 6.378222] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00280010: 0xb35f instead
[ 6.388147] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00280014: 0x3812 instead
[ 6.398072] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00280018: 0x5592 instead
[ 6.407998] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0028001c: 0x95cc instead
[ 6.417922] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00280020: 0x47e9 instead
[ 6.427847] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00280024: 0xd924 instead
[ 6.437769] jffs2: Further such events for this erase block will not be printed
[ 6.466390] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002a0000: 0x7586 instead
[ 6.476334] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002a0004: 0xdeeb instead
[ 6.486266] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002a0008: 0x1d1e instead
[ 6.496193] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002a000c: 0x9bfb instead
[ 6.506118] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002a0010: 0x671b instead
[ 6.516043] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002a0014: 0x5bbf instead
[ 6.525968] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002a0018: 0x4875 instead
[ 6.535893] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002a001c: 0x78ea instead
[ 6.545817] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002a0020: 0xfc24 instead
[ 6.555743] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002a0024: 0x51cc instead
[ 6.565664] jffs2: Further such events for this erase block will not be printed
[ 6.594299] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002c0000: 0xb2d7 instead
[ 6.604247] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002c0004: 0xf7b8 instead
[ 6.614177] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002c0008: 0xcfcb instead
[ 6.624102] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002c000c: 0x95f9 instead
[ 6.634027] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002c0010: 0x7efd instead
[ 6.643952] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002c0014: 0x3e32 instead
[ 6.653876] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002c0018: 0x687d instead
[ 6.663801] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002c001c: 0x304d instead
[ 6.673726] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002c0020: 0x90bb instead
[ 6.683650] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002c0024: 0xbf3a instead
[ 6.693572] jffs2: Further such events for this erase block will not be printed
[ 6.722203] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e0000: 0xf7c9 instead
[ 6.732144] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e0004: 0xc8a9 instead
[ 6.742072] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e0008: 0xefdd instead
[ 6.751999] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e000c: 0xab3c instead
[ 6.761924] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e0010: 0xaf56 instead
[ 6.771849] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e0014: 0x0f78 instead
[ 6.781773] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e0018: 0x63e6 instead
[ 6.791699] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e001c: 0x19f4 instead
[ 6.801624] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e0020: 0xde85 instead
[ 6.811548] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e0024: 0x277b instead
[ 6.821470] jffs2: Further such events for this erase block will not be printed
[ 6.848844] jffs2: Old JFFS2 bitmask found at 0x002fc3c4
[ 6.854425] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 6.863037] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00300000: 0x8e7a instead
[ 6.872973] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00300004: 0xba8c instead
[ 6.882901] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00300008: 0x8175 instead
[ 6.892827] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0030000c: 0x5dac instead
[ 6.902751] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00300010: 0xe81e instead
[ 6.912676] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00300014: 0x239e instead
[ 6.922600] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00300018: 0xe7ab instead
[ 6.932524] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0030001c: 0xabb6 instead
[ 6.942449] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00300020: 0x7319 instead
[ 6.952374] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00300024: 0x6ff5 instead
[ 6.962295] jffs2: Further such events for this erase block will not be printed
[ 6.985898] jffs2: Old JFFS2 bitmask found at 0x00301808
[ 6.991471] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 7.003855] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00320000: 0x2eb6 instead
[ 7.013798] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00320004: 0x9f7b instead
[ 7.023726] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00320008: 0xb626 instead
[ 7.033653] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0032000c: 0x94dc instead
[ 7.044202] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00320010: 0xc47d instead
[ 7.054188] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00320014: 0xff54 instead
[ 7.064125] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00320018: 0x656c instead
[ 7.074053] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0032001c: 0xc286 instead
[ 7.083979] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00320020: 0x09fb instead
[ 7.093904] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00320024: 0x6981 instead
[ 7.103826] jffs2: Further such events for this erase block will not be printed
[ 7.132681] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00340000: 0xe795 instead
[ 7.142653] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00340004: 0x6b5e instead
[ 7.152584] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00340008: 0xdf82 instead
[ 7.162510] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0034000c: 0xc656 instead
[ 7.172437] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00340010: 0x0654 instead
[ 7.182363] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00340014: 0x9553 instead
[ 7.192287] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00340018: 0xd18a instead
[ 7.202212] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0034001c: 0xa518 instead
[ 7.212136] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00340020: 0x34ff instead
[ 7.222061] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00340024: 0x8bf9 instead
[ 7.231984] jffs2: Further such events for this erase block will not be printed
[ 7.260700] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00360000: 0x9f55 instead
[ 7.270646] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00360004: 0x681d instead
[ 7.280576] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00360008: 0x34dd instead
[ 7.290503] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0036000c: 0x8eb3 instead
[ 7.300430] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00360010: 0xcb6d instead
[ 7.310355] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00360014: 0x85b6 instead
[ 7.320281] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00360018: 0xda88 instead
[ 7.330205] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0036001c: 0xb690 instead
[ 7.340130] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00360020: 0x89bf instead
[ 7.350056] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00360024: 0xfbe3 instead
[ 7.359977] jffs2: Further such events for this erase block will not be printed
[ 7.384805] jffs2: Old JFFS2 bitmask found at 0x0036a068
[ 7.390383] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 7.401590] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00380000: 0x5ebe instead
[ 7.411531] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00380004: 0x5ec7 instead
[ 7.421459] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00380008: 0x19f7 instead
[ 7.431385] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0038000c: 0x213b instead
[ 7.441312] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00380010: 0xca38 instead
[ 7.451237] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00380014: 0xb386 instead
[ 7.461162] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00380018: 0x7b1e instead
[ 7.471087] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0038001c: 0x763c instead
[ 7.481012] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00380020: 0x7b1e instead
[ 7.490937] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00380024: 0xe2e5 instead
[ 7.500859] jffs2: Further such events for this erase block will not be printed
[ 7.529469] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a0000: 0x4bdc instead
[ 7.539417] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a0004: 0x6d29 instead
[ 7.549347] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a0008: 0x88bb instead
[ 7.559273] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a000c: 0x513e instead
[ 7.569198] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a0010: 0xdcaf instead
[ 7.579123] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a0014: 0xc55d instead
[ 7.589049] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a0018: 0xd24e instead
[ 7.598973] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a001c: 0x2286 instead
[ 7.608898] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a0020: 0x2c30 instead
[ 7.618823] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a0024: 0xc4ba instead
[ 7.628744] jffs2: Further such events for this erase block will not be printed
[ 7.657369] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003c0000: 0x2019 instead
[ 7.667315] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003c0004: 0xbe87 instead
[ 7.677244] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003c0008: 0x2d33 instead
[ 7.687170] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003c000c: 0xe64a instead
[ 7.697095] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003c0010: 0xced2 instead
[ 7.707021] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003c0014: 0x182f instead
[ 7.716945] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003c0018: 0x9928 instead
[ 7.726871] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003c001c: 0xced3 instead
[ 7.736796] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003c0020: 0x3181 instead
[ 7.746720] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003c0024: 0xb992 instead
[ 7.756642] jffs2: Further such events for this erase block will not be printed
[ 7.785278] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003e0000: 0x8708 instead
[ 7.795224] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003e0004: 0xbfb1 instead
[ 7.805153] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003e0008: 0x5483 instead
[ 7.815079] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003e000c: 0xd290 instead
[ 7.825004] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003e0010: 0x7d65 instead
[ 7.834929] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003e0014: 0x1d92 instead
[ 7.844854] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003e0018: 0x3ec8 instead
[ 7.854779] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003e001c: 0xfec4 instead
[ 7.864705] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003e0020: 0x1242 instead
[ 7.874630] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003e0024: 0x5c8f instead
[ 7.884551] jffs2: Further such events for this erase block will not be printed
[ 7.908749] jffs2: Old JFFS2 bitmask found at 0x003e5b30
[ 7.914325] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 7.926138] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00400000: 0x1ff7 instead
[ 7.936086] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00400004: 0x2a1a instead
[ 7.946016] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00400008: 0x2656 instead
[ 7.955942] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0040000c: 0x35c5 instead
[ 7.965868] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00400010: 0x679d instead
[ 7.975793] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00400014: 0x3599 instead
[ 7.985719] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00400018: 0xcb52 instead
[ 7.995643] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0040001c: 0x03f5 instead
[ 8.005569] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00400020: 0x4e65 instead
[ 8.015493] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00400024: 0x33eb instead
[ 8.025415] jffs2: Further such events for this erase block will not be printed
[ 8.054254] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420000: 0x8306 instead
[ 8.064220] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420004: 0xe877 instead
[ 8.074152] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420008: 0x3b5b instead
[ 8.084081] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0042000c: 0xc01e instead
[ 8.094007] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420010: 0x1005 instead
[ 8.103933] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420014: 0xab14 instead
[ 8.113858] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420018: 0xff2f instead
[ 8.123783] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0042001c: 0x78aa instead
[ 8.133708] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420020: 0xd9b5 instead
[ 8.143634] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420024: 0x3d8c instead
[ 8.153556] jffs2: Further such events for this erase block will not be printed
[ 8.177988] jffs2: Old JFFS2 bitmask found at 0x004273f4
[ 8.183565] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 8.195158] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00440000: 0xa90d instead
[ 8.205107] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00440004: 0x8f9c instead
[ 8.215039] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00440008: 0x27cf instead
[ 8.224966] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0044000c: 0xe59e instead
  • 我的nand flash分区如下:
    device nand0 <nand.0>, # parts = 10
    #: name size offset mask_flags
    0: NAND.SPL 0x00020000 0x00000000 0
    1: NAND.SPL.backup1 0x00020000 0x00020000 0
    2: NAND.SPL.backup2 0x00020000 0x00040000 0
    3: NAND.SPL.backup3 0x00020000 0x00060000 0
    4: NAND.u-boot-spl-os 0x00040000 0x00080000 0
    5: NAND.u-boot 0x00100000 0x000c0000 0
    6: NAND.u-boot-env 0x00020000 0x001c0000 0
    7: NAND.u-boot-env.backup10x00020000 0x001e0000 0
    8: NAND.kernel 0x00800000 0x00200000 0
    9: NAND.file-system 0x3f600000 0x00a00000 0
    我的根文件系统大概有334M,所以我使用0x15e00000(大概350M)使用如下命令写进nand flash:
    U-Boot# mmc rescan
    U-Boot# mw.b 0x82000000 0xFF 0x15e00000
    U-Boot# ext4load mmc 0:2 0x82000000 /boot/rootfs_new.jffs2
    U-Boot# nand erase 0x80000 0x3f600000
    U-Boot# nand write.i 0x82000000 0xa00000 0x15e00000
  • 两天了,没人回复,快急死人了。
  • 根据经验,一般出这种错误,都是命令参数没有设置正确,请根据NAND Flash的属性检查一下参数。
    另外,针对NAND Flash,目前的更多的是用JFFS2的升级版本UBIFS文件系统,论坛也提供相关资料。
