AM4379的RTC时间不能保持
Other Parts Discussed in Thread: AM4379, TPS65218, AM4372
hi:
AM4379板子reboot后,RTC时间不能保持;
可以写入硬件RTC,但是reboot后RTC时间不能保持,不知道是什么原因?
可以写入硬件RTC时间是否表示RTC模块相关硬件电路已经正常?1.8V和1.0V电压测量均正常
使用的是内部RTC模块,未接外部RTC芯片,使用内部RTC模块是否需要开启某个开关或者说默认是外部RTC芯片,使用内部RTC需要修改
以下是开机信息:
U-Boot SPL 2016.05-gb4e185a8c3 (Jul 08 2016 - 19:41:30)
Trying to boot from MMC1
SPL: Please implement spl_start_uboot() for your board
SPL: Direct Linux boot not active!
reading u-boot.img
reading u-boot.img
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-gb4e185a8c3 (Jul 08 2016 - 19:41:30 -0400)
I2C:   ready
DRAM:  1 GiB
PMIC:  TPS65218
NAND:  0 MiB
MMC:   OMAP SD/MMC: 0
reading uboot.env
** Unable to read "uboot.env" from mmc0:1 **
Using default environment
Net:
Warning: ethernet@4a100000 using MAC address from ROM
eth0: ethernet@4a100000
Hit any key to stop autoboot:  2 1 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
717 bytes read in 5 ms (139.6 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
3676360 bytes read in 199 ms (17.6 MiB/s)
52253 bytes read in 26 ms (1.9 MiB/s)
Booting from mmc0 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x3818c8 ]
## Flattened Device Tree blob at 88000000
   Booting using the fdt blob at 0x88000000
   Loading Device Tree to 8fff0000, end 8ffffc1c ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.12-g3639bea54a (gtbldadm@ubuntu-16) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 PREEMPT Fri Jul 8 19:26:11 EDT 2016
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: TI AM437x GP EVM
[    0.000000] cma: Reserved 24 MiB at 0xbe800000
[    0.000000] Memory policy: Data cache writeback
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM437x ES1.2 (sgx neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260416
[    0.000000] Kernel command line: console=ttyO0,115200n8 video=HDMI-A-1:800x600 root=PARTUUID=cd1d2d40-02 rw rootfstype=ext4 rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1003176K/1048576K available (7115K kernel code, 299K rwdata, 2528K rodata, 296K init, 264K bss, 20824K reserved, 24576K cma-reserved, 237568K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0973034   (9645 kB)
[    0.000000]       .init : 0xc0974000 - 0xc09be000   ( 296 kB)
[    0.000000]       .data : 0xc09be000 - 0xc0a08ef0   ( 300 kB)
[    0.000000]        .bss : 0xc0a0a000 - 0xc0a4c358   ( 265 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000
[    0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000
[    0.000000] L2C-310 erratum 769419 enabled
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] OMAP L2C310: ROM does not support power control setting
[    0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled
[    0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB
[    0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000011] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000028] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000037] OMAP clocksource: timer1 at 24000000 Hz
[    0.000526] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000535] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000958] Console: colour dummy device 80x30
[    0.000983] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.000987] This ensures that you still see kernel messages. Please
[    0.000992] update your kernel commandline.
[    0.001008] Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
[    0.060178] pid_max: default: 32768 minimum: 301
[    0.060296] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.060307] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.060948] Initializing cgroup subsys io
[    0.060975] Initializing cgroup subsys memory
[    0.061008] Initializing cgroup subsys devices
[    0.061022] Initializing cgroup subsys freezer
[    0.061036] Initializing cgroup subsys perf_event
[    0.061048] Initializing cgroup subsys pids
[    0.061074] CPU: Testing write buffer coherency: ok
[    0.061429] Setting up static identity map for 0x80008200 - 0x80008258
[    0.062736] devtmpfs: initialized
[    0.072914] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.146505] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.148639] pinctrl core: initialized pinctrl subsystem
[    0.149768] NET: Registered protocol family 16
[    0.151805] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.180188] cpuidle: using governor ladder
[    0.210177] cpuidle: using governor menu
[    0.212049] omap_l3_noc 44000000.ocp: L3 debug error: target 8 mod:0 (unclearable)
[    0.212107] omap_l3_noc 44000000.ocp: L3 application error: target 8 mod:0 (unclearable)
[    0.215295] omap_gpio 44e07000.gpio: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/gpio0_pins, deferring probe
[    0.215952] OMAP GPIO hardware version 0.1
[    0.217659] omap_gpio 48322000.gpio: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/display_mux_pins, deferring probe
[    0.220916] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/nand_flash_x8_default, deferring probe
[    0.225133] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.225150] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.266711] edma 49000000.edma: TI EDMA DMA engine driver
[    0.270469] vgaarb: loaded
[    0.270969] SCSI subsystem initialized
[    0.271223] usbcore: registered new interface driver usbfs
[    0.271277] usbcore: registered new interface driver hub
[    0.271367] usbcore: registered new device driver usb
[    0.271957] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/i2c0_pins, deferring probe
[    0.272008] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/i2c1_pins_default, deferring probe
[    0.272132] media: Linux media interface: v0.10
[    0.272182] Linux video capture interface: v2.00
[    0.272226] pps_core: LinuxPPS API ver. 1 registered
[    0.272233] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.272260] PTP clock support registered
[    0.272468] EDAC MC: Ver: 3.0.0
[    0.273343] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.273696] Advanced Linux Sound Architecture Driver Initialized.
[    0.274655] clocksource: Switched to clocksource timer1
[    0.283011] NET: Registered protocol family 2
[    0.283644] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.283711] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.283784] TCP: Hash tables configured (established 8192 bind 8192)
[    0.283927] UDP hash table entries: 512 (order: 1, 8192 bytes)
[    0.283949] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[    0.284099] NET: Registered protocol family 1
[    0.284414] RPC: Registered named UNIX socket transport module.
[    0.284424] RPC: Registered udp transport module.
[    0.284430] RPC: Registered tcp transport module.
[    0.284435] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.286518] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.291918] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.292513] NFS: Registering the id_resolver key type
[    0.292564] Key type id_resolver registered
[    0.292571] Key type id_legacy registered
[    0.292628] ntfs: driver 2.1.32 [Flags: R/O].
[    0.294132] bounce: pool size: 64 pages
[    0.294321] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    0.294341] io scheduler noop registered
[    0.294352] io scheduler deadline registered
[    0.294464] io scheduler cfq registered (default)
[    0.297659] pinctrl-single 44e10800.pinmux: 199 pins at pa f9e10800 size 796
[    0.300331] backlight supply power not found, using dummy regulator
[    0.344449] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.347071] omap8250 44e09000.serial: No clock speed specified: using default: 48000000
[    0.347752] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[    1.097777] console [ttyS0] enabled
[    1.101716] omap8250 481a6000.serial: No clock speed specified: using default: 48000000
[    1.110396] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 31, base_baud = 3000000) is a 8250
[    1.120189] [drm] Initialized drm 1.1.0 20060810
[    1.126123] 4832a000.dss supply vdda_video not found, using dummy regulator
[    1.133244] OMAP DSS rev 2.0
[    1.136359] omapdss_dss 4832a000.dss: bound 4832a400.dispc (ops dispc_component_ops)
[    1.152266] loop: module loaded
[    1.157963] libphy: Fixed MDIO Bus: probed
[    1.224708] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[    1.230842] davinci_mdio 4a101000.mdio: detected phy mask fffffffc
[    1.238386] libphy: 4a101000.mdio: probed
[    1.242430] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Micrel KSZ9031 Gigabit PHY
[    1.252208] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
[    1.262597] cpsw 4a100000.ethernet: Detected MACID = 68:9e:19:ba:98:00
[    1.270170] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.277775] usbcore: registered new interface driver pegasus
[    1.283529] usbcore: registered new interface driver asix
[    1.289043] usbcore: registered new interface driver ax88179_178a
[    1.295224] usbcore: registered new interface driver cdc_ether
[    1.301134] usbcore: registered new interface driver smsc75xx
[    1.306972] usbcore: registered new interface driver smsc95xx
[    1.312780] usbcore: registered new interface driver net1080
[    1.318516] usbcore: registered new interface driver cdc_subset
[    1.324504] usbcore: registered new interface driver zaurus
[    1.330193] usbcore: registered new interface driver cdc_ncm
[    1.336639] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.343205] ehci-pci: EHCI PCI platform driver
[    1.347754] ehci-platform: EHCI generic platform driver
[    1.353188] ehci-omap: OMAP-EHCI Host Controller driver
[    1.358586] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.364839] ohci-pci: OHCI PCI platform driver
[    1.369360] ohci-platform: OHCI generic platform driver
[    1.375093] usbcore: registered new interface driver usb-storage
[    1.381505] mousedev: PS/2 mouse device common for all mice
[    1.387965] i2c /dev entries driver
[    1.392959] cpuidle: enable-method property 'ti,am4372' found operations
[    1.399926] sdhci: Secure Digital Host Controller Interface driver
[    1.406175] sdhci: Copyright(c) Pierre Ossman
[    1.454927] Synopsys Designware Multimedia Card Interface Driver
[    1.461469] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.475226] ledtrig-cpu: registered to indicate activity on CPUs
[    1.481485] usbcore: registered new interface driver usbhid
[    1.504657] usbhid: USB HID core driver
[    1.511012] NET: Registered protocol family 10
[    1.525772] sit: IPv6 over IPv4 tunneling driver
[    1.531038] NET: Registered protocol family 17
[    1.545008] Key type dns_resolver registered
[    1.549459] omap_voltage_late_init: Voltage driver support not added
[    1.565661] ThumbEE CPU extension supported.
[    1.569973] Registering SWP/SWPB emulation handler
[    1.594981] omapdrm omapdrm.0: DMM not available, disable DMM support
[    1.605385] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.612037] [drm] No driver support for vblank timestamp query.
[    1.679852] Console: switching to colour frame buffer device 100x30
[    1.702931] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[    1.754683] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[    1.775143] GPIO line 119 (SelEMMCorNAND) hogged as output/low
[    1.781770] GPIO line 136 (SelLCDorHDMI) hogged as output/high
[    1.795276] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[    1.800446] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[    1.815719] nand: No NAND device found
[    1.819501] omap2-nand 8000000.nand: scan failed, may be bus-width mismatch
[    1.888383] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz
[    1.905953] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 100 kHz
[    1.912255] omap_hsmmc 48060000.mmc: Got CD GPIO
[    1.976521] hctosys: unable to open rtc device (rtc0)
[    1.985822] ALSA device list:
[    1.988824]   No soundcards found.
[    2.004809] Waiting for root device PARTUUID=cd1d2d40-02...
[    2.691982] mmc1: host does not support reading read-only switch, assuming write-enable
[    2.701940] mmc1: new high speed SDHC card at address 1234
[    2.708059] mmcblk0: mmc1:1234 SA08G 7.21 GiB
[    2.714042]  mmcblk0: p1 p2
[    5.764508] EXT4-fs (mmcblk0p2): recovery complete
[    5.777196] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    5.785464] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    5.801535] devtmpfs: mounted
[    5.805400] Freeing unused kernel memory: 296K (c0974000 - c09be000)
[    5.811799] This architecture does not have kernel memory protection.
[    6.156439] systemd[1]: System time before build time, advancing clock.
[    6.222578] random: systemd urandom read with 18 bits of entropy available
[    6.241906] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[    6.260958] systemd[1]: Detected architecture arm.
Welcome to [1mArago 2016.05[0m!
[    6.294954] systemd[1]: Set hostname to <am437x-evm>.
[    7.038395] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[    7.046356] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[    7.054079] systemd[1]: sysinit.target: Found dependency on basic.target/start
[    7.061481] systemd[1]: sysinit.target: Found dependency on sockets.target/start
[    7.068965] systemd[1]: sysinit.target: Found dependency on avahi-daemon.socket/start
[    7.076875] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[    7.084322] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[    7.093798] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
[[0;1;31m SKIP [0m] Ordering cycle found, skipping alignment.service
[    7.158240] systemd[1]: Listening on Syslog Socket.
[[0;32m  OK  [0m] Listening on Syslog Socket.
[    7.177657] systemd[1]: Created slice User and Session Slice.
[[0;32m  OK  [0m] Created slice User and Session Slice.
[    7.195013] systemd[1]: Reached target Remote File Systems.
[[0;32m  OK  [0m] Reached target Remote File Systems.
[    7.214944] systemd[1]: Reached target Swap.
[[0;32m  OK  [0m] Reached target Swap.
[    7.235639] systemd[1]: Listening on udev Control Socket.
[[0;32m  OK  [0m] Listening on udev Control Socket.
[    7.255507] systemd[1]: Listening on Network Service Netlink Socket.
[[0;32m  OK  [0m] Listening on Network Service Netlink Socket.
[    7.285145] systemd[1]: Listening on Journal Socket (/dev/log).
[[0;32m  OK  [0m] Listening on Journal Socket (/dev/log).
[    7.305072] systemd[1]: Listening on udev Kernel Socket.
[[0;32m  OK  [0m] Listening on udev Kernel Socket.
[    7.326069] systemd[1]: Created slice System Slice.
[[0;32m  OK  [0m] Created slice System Slice.
[    7.346248] systemd[1]: Created slice system-serial\x2dgetty.slice.
[[0;32m  OK  [0m] Created slice system-serial\x2dgetty.slice.
[    7.365226] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[[0;32m  OK  [0m] Started Forward Password Requests to Wall Directory Watch.
[    7.395194] systemd[1]: Listening on Journal Socket.
[[0;32m  OK  [0m] Listening on Journal Socket.
[    7.419011] systemd[1]: Starting Setup Virtual Console...
[    7.449660] systemd[1]: Starting Journal Service...
[    7.499559] systemd[1]: Starting Create list of required static device nodes for the current kernel...
         Starting Create list of required st... nodes for the current kernel...
[    7.574053] systemd[1]: Starting Load Kernel Modules...
[    7.618399] systemd[1]: Mounting Temporary Directory...
[    7.657864] cryptodev: driver 1.8 loaded.
[    7.669353] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.732956] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    7.745632] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[[0;32m  OK  [0m] Started Dispatch Password Requests to Console Directory Watch.
[    7.787996] systemd[1]: Mounting Debug File System...
[    7.836612] systemd[1]: Created slice system-getty.slice.
[[0;32m  OK  [0m] Created slice system-getty.slice.
[    7.855021] systemd[1]: Reached target Paths.
[[0;32m  OK  [0m] Reached target Paths.
[    7.875016] systemd[1]: Reached target Slices.
[[0;32m  OK  [0m] Reached target Slices.
[    7.895218] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[[0;32m  OK  [0m] Listening on /dev/initctl Compatibility Named Pipe.
[    7.928937] systemd[1]: Mounting POSIX Message Queue File System...
[    7.980425] systemd[1]: Mounted POSIX Message Queue File System.
[[0;32m  OK  [0m] Mounted POSIX Message Queue File System.
[    8.005238] systemd[1]: Mounted Debug File System.
[[0;32m  OK  [0m] Mounted Debug File System.
[    8.025112] systemd[1]: Mounted Temporary Directory.
[[0;32m  OK  [0m] Mounted Temporary Directory.
[    8.045642] systemd[1]: Started Journal Service.
[[0;32m  OK  [0m] Started Journal Service.
[[0;32m  OK  [0m] Started Setup Virtual Console.
[[0;32m  OK  [0m] Started Create list of required sta...ce nodes for the current kernel.
[[0;32m  OK  [0m] Started Load Kernel Modules.
[[0;32m  OK  [0m] Started Remount Root and Kernel File Systems.
         Starting udev Coldplug all Devices...
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
         Starting Flush Journal to Persistent Storage...
[[0;32m  OK  [0m] Started Apply Kernel Variables.
[[0;32m  OK  [0m] Started Create Static Device Nodes in /dev.
[    9.386880] systemd-journald[70]: Received request to flush runtime journal from PID 1
[[0;32m  OK  [0m] Started Flush Journal to Persistent Storage.
         Starting udev Kernel Device Manager...
[[0;32m  OK  [0m] Reached target Local File Systems (Pre).
         Mounting /var/volatile...
         Mounting /media/ram...
[[0;32m  OK  [0m] Mounted /var/volatile.
[[0;32m  OK  [0m] Mounted /media/ram.
[[0;32m  OK  [0m] Started udev Kernel Device Manager.
[[0;32m  OK  [0m] Started udev Coldplug all Devices.
[[0;32m  OK  [0m] Reached target Local File Systems.
[   10.615062] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
         Starting Create Volatile Files and Directories...
         Starting Load/Save Random Seed...
[   10.794438] omap_rtc 44e3e000.rtc: already running
[   10.806959]  remoteproc0: wkup_m3 is available
[   10.811439]  remoteproc0: Note: remoteproc is still under development and considered experimental.
[[0;32m  OK  [0m] Found device /dev/ttyS0.
[   10.875014] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[   11.003780]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[[0;32m  OK  [0m] Started Load/Save Random Seed.
[   11.026417] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[   11.095428] ov2659 0-0030: Sensor detection failed (3030, 0)
[   11.172404] ov2659 1-0030: Sensor detection failed (3030, 0)
[   11.180103]  remoteproc0: powering up wkup_m3
[   11.235733]  remoteproc0: Booting fw image am335x-pm-firmware.elf, size 216252
[   11.243839]  remoteproc0: remote processor wkup_m3 is now up
[   11.249620] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x191
[[0;32m  OK  [0m] Started Create Volatile Files and Directories.
[   11.402794] CAN device driver interface
[   11.407142] pixcir_ts 1-005c: pixcir_set_power_mode: can't read reg 0x33 : -121
[   11.414490] pixcir_ts 1-005c: Failed to set IDLE mode
[   11.484849] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[   11.541231] c_can_platform 481cc000.can: c_can_platform device registered (regs=fa1cc000, irq=154)
[   11.595161] pixcir_ts: probe of 1-005c failed with error -121
[   11.633822] c_can_platform 481d0000.can: c_can_platform device registered (regs=fa1d0000, irq=155)
[   11.806356] omap-sham 53100000.sham: hw accel on OMAP rev 0.0
[   12.068077] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1
[   12.172274] omap-des 53701000.des: OMAP DES hw accel rev: 0.33
[   12.244195] ti-pruss 54400000.pruss: creating PRU cores and other child platform devices
         Starting Update UTMP about System Boot/Shutdown...
[   12.393180] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[   12.406611]  remoteproc1: 54434000.pru0 is available
[   12.411613]  remoteproc1: Note: remoteproc is still under development and considered experimental.
         Starting Network Time Synchronization...
[   12.625400] input: matrix_keypad@0 as /devices/platform/matrix_keypad@0/input/input1
[   12.633309]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[   12.768686]  remoteproc1: registered virtio0 (type 7)
[   12.773840] pru-rproc 54434000.pru0: PRU rproc node /ocp/pruss@54400000/pru0@54434000 probed successfully
[   12.882124]  remoteproc2: 54438000.pru1 is available
[   12.905102] PM: bootloader does not support rtc-only!
[[0;32m  OK  [0m] Started Network Time Synchronization.
[   12.976473]  remoteproc2: Note: remoteproc is still under development and considered experimental.
[   12.992303] asoc-simple-card sound@0: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[   13.103584]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[   13.277841]  remoteproc2: registered virtio1 (type 7)
[   13.320749] pru-rproc 54438000.pru1: PRU rproc node /ocp/pruss@54400000/pru1@54438000 probed successfully
[   13.849629] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[[0;32m  OK  [0m] Started Update UTMP about System Boot/Shutdown.
[[0;32m  OK  [0m] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[[0;32m  OK  [0m] Created slice system-systemd\x2dbacklight.slice.
         Starting Load/Save Screen Backlight...htness of backlight:backlight...
[[0;32m  OK  [0m] Reached target System Time Synchronized.
         Starting Synchronize System and HW clocks...
[[0;32m  OK  [0m] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[[0;32m  OK  [0m] Started Synchronize System and HW clocks.
[   16.080034]  remoteproc1: powering up 54434000.pru0
[   16.136520]  remoteproc1: Booting fw image am437x-pru1_0-fw, size 86204
[   16.143271] ti-pruss 54400000.pruss: configured system_events = 0x1000000000000000 intr_channels = 0x00000001 host_intr = 0x00000001
[   16.269255]  remoteproc1: remote processor 54434000.pru0 is now up
[   16.295572] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[   16.303119] virtio_rpmsg_bus virtio0: rpmsg host is online
[   16.323193]  remoteproc2: powering up 54438000.pru1
[   16.355244]  remoteproc2: Booting fw image am437x-pru1_1-fw, size 86204
[   16.361994] ti-pruss 54400000.pruss: configured system_events = 0x0800000000000000 intr_channels = 0x00000002 host_intr = 0x00000002
[   16.424767]  remoteproc2: remote processor 54438000.pru1 is now up
[   16.431345] virtio_rpmsg_bus virtio1: creating channel rpmsg-pru addr 0x1f
[   16.454709] virtio_rpmsg_bus virtio1: rpmsg host is online
[   16.517985] rpmsg_pru rpmsg0: new rpmsg_pru device: /dev/rpmsg_pru30
[   16.535767] rpmsg_pru rpmsg1: new rpmsg_pru device: /dev/rpmsg_pru31
[   16.766899] dwc3 48390000.usb: otg: primary host xhci-hcd.0.auto registered
[   16.773914] dwc3 48390000.usb: otg: shared host xhci-hcd.0.auto registered
[   16.794863] dwc3 48390000.usb: otg: can't start till gadget registers
[[0;32m  OK  [0m] Reached target Sound Card.
[[0;32m  OK  [0m] Reached target System Initialization.
[[0;32m  OK  [0m] Started Daily Cleanup of Temporary Directories.
[[0;32m  OK  [0m] Reached target Timers.
[[0;32m  OK  [0m] Listening on dropbear.socket.
[   17.130564] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[[0;32m  OK  [0m] Listening on RPCbind Server Activation Socket[   17.139125] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[[0;32m  OK  [0m] Listening on D-Bus System Message Bus Socket.[   17.155940] xhci-hcd xhci-hcd.1.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x00010010
[   17.168268] xhci-hcd xhci-hcd.1.auto: irq 261, io mem 0x483d0000
[   17.178664] hub 1-0:1.0: USB hub found
[   17.182495] hub 1-0:1.0: 1 port detected
[[0;32m  OK  [0m] Listening on Avahi mDNS/DNS-SD Stack Activati[   17.191757] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
on Socket.
[   17.202035] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[   17.210780] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[[0;32m  OK  [0m] Reached target Sockets.
[   17.224182] hub 2-0:1.0: USB hub found
[   17.229373] hub 2-0:1.0: 1 port detected
[[0;32m  OK  [0m] Reached target Basic System.
[[0;32m  OK  [0m] Started D-Bus System Message Bus.
         Starting Network Service...
         Starting Permit User Sessions...
         Starting Login Service...
         Starting Telephony service...
[[0;32m  OK  [0m] Started System Logging Service.
[[0;32m  OK  [0m] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
         Starting uim-sysfs.service...
[   17.782359] net eth0: initializing cpsw version 1.15 (0)
[[0;32m  OK  [0m] Started Kernel Logging Service.
[   17.839291] net eth0: initialized cpsw ale version 1.4
         Starting Avahi mDNS/DNS-SD Stack...
[   17.976439] net eth0: phy found : id is : 0x221622
         Starting Save/Restore Sound Card State...
[[0;32m  OK  [0m] Started Network Service.
[   18.041296] Bluetooth: Core ver 2.21
[   18.050381] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[[0;32m  OK  [0m] Started Permit User Sessions.
[   18.090797] NET: Registered protocol family 31
[   18.151764] Bluetooth: HCI device and connection manager initialized
[   18.208495] Bluetooth: HCI socket layer initialized
[   18.213422] Bluetooth: L2CAP socket layer initialized
[   18.284234] Bluetooth: SCO socket layer initialized
[[0;32m  OK  [0m] Started Save/Restore Sound Card State.
[   18.406461] NET: Registered protocol family 15
[   18.849029] Initializing XFRM netlink socket
[[0;32m  OK  [0m] Started Telephony service.
[[0;32m  OK  [0m] Started Avahi mDNS/DNS-SD Stack.
[[0;32m  OK  [0m] Started Login Service.
[[0;32m  OK  [0m] Started Getty on tty1.
[[0;32m  OK  [0m] Started Serial Getty on ttyS0.
[[0;32m  OK  [0m] Reached target Network.
         Starting Lightning Fast Webserver With Light System Requirements...
         Starting Network Name Resolution...
[[0;32m  OK  [0m] Started Lightning Fast Webserver With Light System Requirements.
[[0;32m  OK  [0m] Started Network Name Resolution.
[   21.334771] random: nonblocking pool is initialized
[[0;32m  OK  [0m] Started uim-sysfs.service.
         Starting rc.pvr.service...
[   22.089750] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[[0;32m  OK  [0m] Started rc.pvr.service.
         Starting weston.service...
[[0;32m  OK  [0m] Started weston.service.
         Starting telnetd.service...
[[0;32m  OK  [0m] Started telnetd.service.
         Starting thttpd.service...
[[0;32m  OK  [0m] Started thttpd.service.
         Starting rng-tools.service...
[[0;32m  OK  [0m] Started rng-tools.service.
         Starting matrix-gui-2.0.service...
[[0;32m  OK  [0m] Started matrix-gui-2.0.service.
         Starting parse-ip.service...
         Starting thermal-zone-init.service...
[[0;32m  OK  [0m] Started thermal-zone-init.service.
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org am437x-evm ttyS0
Arago 2016.05 am437x-evm ttyS0
am437x-evm login:
