STK 编译
您好,打开stk里面的srio工程,配置好路径,加好驱动文件之后编译,出现45个警告,刚看不知道那里出的问题?
   1.{((Uint32)hostDescriptor_LL2)+0x10000000,   SRIO_DESCRIPTOR_SIZE,       LL2_HOST_DESC_LINK_ENTRY_NUM},/*host descriptor in Core0 LL2*/
#172-D pointer points outside of underlying object SRIO_PktDMA_Init.c /TS_SRIO/src line 63 C/C++ Problem
   2.  {{0,                        0,                                                      0,                                                  0},   /*port0 is not availible for this case*/
#190-D enumerated type mixed with another type SRIO_2DSP_Test.c /TS_SRIO/src line 27 C/C++ Problem
