8168的USB无法识别U盘
各位大神:
  你们好!!我们现在用8618在读取U盘时,会出现无法识别U盘,重启之后又可以识别到U盘,反反复复的!会是什么问题导致?
  • Huang Yun,
    你是否有测量一下,当U盘插入的时候,VBUS 5V是否有跌落得很厉害?
  • 你好 ,
         我也遇到类似的问题 ,我的机子也会随机出现无法读取到usb的请求 我是使用DM368 IPNC5.1方案 linux系统2.6.37 当出现无法加载USB 会有打印信息
    [ 7.465654] iscsi: registered transport (tcp)
    [ 7.994887] musb-hdrc: version 6.0, host, debug=0
    [ 8.461077] musb-hdrc musb-hdrc: dma type: dma-cppi3
    [ 8.482654] musb-hdrc: ConfigData=0x06 (UTMI-8, dyn FIFOs, SoftConn)
    [ 8.482740] musb-hdrc: MHDRC RTL version 1.500
    [ 8.482785] musb-hdrc: setup fifo_mode 2
    [ 8.482849] musb-hdrc: 9/9 max ep, 4032/4096 memory
    [ 8.483028] musb-hdrc musb-hdrc: MUSB HDRC host driver
    [ 8.483432] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 1
    [ 8.524528] hub 1-0:1.0: USB hub found
    [ 8.524735] hub 1-0:1.0: 1 port detected
    [ 8.534293] musb-hdrc musb-hdrc: USB Host mode controller at fec64000 using DMA, IRQ 12
    [ 8.972020] usb 1-1: new full speed USB device using musb-hdrc and address 2
    [ 9.090678] usb 1-1: device descriptor read/64, error -71
    [ 9.099397] loop: module loaded
    [ 9.331564] tun: Universal TUN/TAP device driver, 1.6
    [ 9.331648] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
    [ 9.352598] usb 1-1: device descriptor read/64, error -71
    [ 9.503308] console [netcon0] enabled
    [ 9.503376] netconsole: network logging started
    [ 9.583310] usb 1-1: new full speed USB device using musb-hdrc and address 3
    [ 9.701097] usb 1-1: device descriptor read/64, error -71
    [ 9.789565] PPP generic driver version 2.4.2
    [ 9.888197] PPP Deflate Compression module registered
    [ 9.952076] usb 1-1: device descriptor read/64, error -71
    [ 10.182016] usb 1-1: new full speed USB device using musb-hdrc and address 4
    [ 10.600899] usb 1-1: device not accepting address 4, error -71
    [ 10.750564] usb 1-1: new full speed USB device using musb-hdrc and address 5
    [ 11.172383] usb 1-1: device not accepting address 5, error -71
    [ 11.195632] hub 1-0:1.0: unable to enumerate USB device on port 1
    出现此问题 无论怎么软件重启都没用 一直还是一样的问题 但是 如果重新断电重启 则又能正常检测到 请问这是为什么?
