我的CCS版本是6.1.1Linux版本,我把EMIF例程导入时,报错说我没有GNU_4.8.4:Linaro [ARM],然后我装好了Linaro,重启了CCS,删除了工程,又重新导入了工程,并且也选择了这个编译器,如下图所示,build的时候还是还是报同样的错误,所报的错误如下:
Buildfile generation error occurred..
This project was created using a version of compiler that is not currently installed: GNU_4.8.4:Linaro [ARM]. Please go to CCS App Center to install the compiler of this version, or migrate the project to one of the available compiler versions by adjusting project properties.
Build stopped..
