DM368 usb控制器作为host,插入u盘出现如下打印:
# usb 1-1: new high speed USB device using musb_hdrc and address 15
usb 1-1: Product: OnlyDisk
usb 1-1: Manufacturer: Netac
usb 1-1: SerialNumber: 30E318184697386F2DDD63E6
usb 1-1: configuration #1 chosen from 1 choice
scsi6 : SCSI emulation for USB Mass Storage devices
Vendor: Netac Model: OnlyDisk Rev: PMAP
Type: Direct-Access ANSI SCSI revision: 06
usb 1-1: reset high speed USB device using musb_hdrc and address 15
usb 1-1: device descriptor read/64, error -71
SCSI device sdb: 15212672 512-byte hdwr sectors (7789 MB)
usb 1-1: device descriptor read/all, error -71
sdb: Write Protect is off
sdb: assuming drive cache: write through
sdb:<7>usb-storage: queuecommand called
sdb1
sd 6:0:0:0: Attached scsi removable disk sdb
sd 6:0:0:0: Attached scsi generic sg0 type 0
有错误打印,但U盘可以识别到,fdisk -l 可以看到scsi设备,如下:但不知道这个错误打印是什么造成的
# fdisk -l
Disk /dev/sdb: 7788 MB, 7788888064 bytes
241 heads, 62 sectors/track, 1018 cylinders
Units = cylinders of 14942 * 512 = 7650304 bytes
Device Boot Start End Blocks Id System
/dev/sdb1 * 70 1019 7086272 b Win95 FAT32
Partition 1 has different physical/logical beginnings (non-Linux?):
phys=(64, 189, 62) logical=(69, 147, 17)
Partition 1 has different physical/logical endings:
phys=(946, 240, 62) logical=(1018, 27, 42)
但往U盘拷贝数据是会出现错误,无法写入,写入方式和错误打印如下:
mount -t vfat /dev/sdb1 /mnt/sdb
cp /mnt/flash/test_file /mnt/sdb
usb 1-1: device descriptor read/8, error -71
sd 6:0:0:0: SCSI error: return code = 0x00070000
end_request: I/O error, dev sdb, sector 1072912
end_request: I/O error, dev sdb, sector 1073152
end_request: I/O error, dev sdb, sector 1073392
end_request: I/O error, dev sdb, sector 1073632
end_request: I/O error, dev sdb, sector 1073872
end_request: I/O error, dev sdb, sector 1074112
end_request: I/O error, dev sdb, sector 1074352
end_request: I/O error, dev sdb, sector 1074592
usb 1-1: USB disconnect, address 15
end_request: I/O error, dev sdb, sector 1074832
sd 6:0:0:0: SCSI error: return code = 0x00010000
end_request: I/O error, dev sdb, sector 1072896
Buffer I/O error on device sdb1, logical block 32768
lost page write due to I/O error on sdb1
end_request: I/O error, dev sdb, sector 1059087
Buffer I/O error on device sdb1, logical block 18959
Buffer I/O error on device sdb1, logical block 18960
end_request: I/O error, dev sdb, sector 1045278
Buffer I/O error on device sdb1, logical block 5150
Buffer I/O error on device sdb1, logical block 5151
end_request: I/O error, dev sdb, sector 1040129
usb 1-1: new high speed USB device using musb_hdrc and address 16
usb 1-1: new high speed USB device using musb_hdrc and address 17
usb 1-1: new high speed USB device using musb_hdrc and address 18
usb 1-1: new high speed USB device using musb_hdrc and address 19
请问TI的工程师,上面的错误改怎么定位,DM368使用的内核是2.6.18版本的内核,应该没有关系吧,感觉硬件上的问题吗?
该怎么定位,在线等,急
