调试EVM板过程中遇到连接问题,Core0无法运行。显示如下:
DEBUG过程图像:
显示信息:
C66xx_0: GEL Output: Setup_Memory_Map...
C66xx_0: GEL Output: Setup_Memory_Map... Done.
Connecting Target...
C66xx_0: GEL: Error while executing OnTargetConnect(): identifier not found: DNUM.
C66xx_0: GEL Output: Invalidate All Cache...
C66xx_0: GEL Output: Invalidate All Cache... Done.
C66xx_0: GEL: Error calling OnPreFileLoaded(): identifier not found: IER
C66xx_0: GEL: Error while executing OnRestart(0): identifier not found: DNUM.
C66xx_0: GEL: Error while executing OnFileLoaded(0, 0): identifier not found: DNUM.
C66xx_1: The callstack was unable to find Frame Pointer register information
C66xx_2: The callstack was unable to find Frame Pointer register information
C66xx_3: The callstack was unable to find Frame Pointer register information
C66xx_4: The callstack was unable to find Frame Pointer register information
C66xx_5: The callstack was unable to find Frame Pointer register information
C66xx_6: The callstack was unable to find Frame Pointer register information
C66xx_7: The callstack was unable to find Frame Pointer register information
在其他核中运行单步调试,显示:
ccxml以及cmd文件见附件
请问各位专家这是什么问题呢?
