C66xx_0: Trouble Writing Memory Block at 0x400 on Page 0 of Length 0x200: (Error -1190 @ 0x400) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.838.0)
C66xx_0: GEL: File: D:\ti\project\test3\GPIO\Debug\GPIO.out: Load failed.
C66xx_0: Power Failure on Target CPU
C66xx_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
