DM385压缩卡住了
[m3video] ENC : IVAHDID : 0 Number of Req Objs exceeded limit: 1
[m3video] ENC : IVAHDID : 0 Batch creation ... DONE !!!
[m3video] ENC : IVAHDID : 0 Number of Req Objs in Batch : 1
[m3video] ENC : IVAHDID : 0 Channels included in Batch:
[m3video] ENC : IVAHDID : 0 0
[m3video] ENC : IVAHDID : 0 Submitting Batch
[m3video] ENC : IVAHDID : 0 Entering EncLink_SubmitBatch.
[m3video] IVAHDID : 0 Leaving Enclink_h264EncodeFrameBatch with error code : 0
[m3video] ENC : IVAHDID : 0 Leaving EncLink_SubmitBatch with status 0
[m3video] ENC : IVAHDID : 0 An element with width greater than 1280 encountere!
[m3video] ENC : IVAHDID : 0 1
[m3video] IVAHDID : 0 Entering Enclink_h264EncodeFrameBatch
[m3video] [ENC] H264 Encoder is called for process !!!!!!!!!
卡在这里,就是error = ((IVIDENC2_Handle)handle)->fxns->process这个函数,不出来。
上面的打印就是我不太懂的。
  • Xin Jin,
    问题是必现么?请问你的系统现在稳定么? 如果降低DDR的频率该问题会有改善么?
  • 每次都是这样,现象是一样的,我怀疑是数据引起的,所以我打算做个实验,使用NULLSRC->DUP->IPC OUT(VPSSM3)->IPC IN(VIDEOM3)->H264ENC(VIDEOM3)-> IPC BITS OUT(VIDEOM3)-> IPC BITS OUT(VIDEOM3),代码如下:
    NullSrcPrm.inputInfo.numCh = 1;
    NullSrcPrm.inputInfo.chInfo[0].width = 1920;
    NullSrcPrm.inputInfo.chInfo[0].height = 1080;
    NullSrcPrm.inputInfo.chInfo[0].pitch[0] = 1920;
    NullSrcPrm.inputInfo.chInfo[0].pitch[1] = 1920;
    NullSrcPrm.inputInfo.chInfo[0].pitch[2] = 0;
    NullSrcPrm.inputInfo.chInfo[0].dataFormat = SYSTEM_DF_YUV420SP_UV;
    NullSrcPrm.inputInfo.chInfo[0].scanFormat = 1;//FVID2_SF_PROGRESSIVE
    NullSrcPrm.outQueParams.nextLink = dupId;
    NullSrcPrm.tilerEnable =FALSE;
    /* Dup Link params */
    dupPrm.inQueParams.prevLinkId = NullSrcId;
    dupPrm.inQueParams.prevLinkQueId = 0;
    dupPrm.numOutQue = 1;
    dupPrm.outQueParams[0].nextLink = mergeId[CAM_STREAM_MERGE_IDX];
    dupPrm.notifyNextLink = TRUE;
    /* Merge Link params */
    mergePrm[CAM_STREAM_MERGE_IDX].numInQue = 1;
    mergePrm[CAM_STREAM_MERGE_IDX].inQueParams[0].prevLinkId = dupId;
    mergePrm[CAM_STREAM_MERGE_IDX].inQueParams[0].prevLinkQueId = 0;
    mergePrm[CAM_STREAM_MERGE_IDX].outQueParams.nextLink =ipcOutVpssId;// gVsysModuleContext.swOsdId;
    mergePrm[CAM_STREAM_MERGE_IDX].notifyNextLink = TRUE;
    /* SWOSD Link Params */
    swosdPrm.inQueParams.prevLinkId = mergeId[CAM_STREAM_MERGE_IDX];
    swosdPrm.inQueParams.prevLinkQueId = 0;
    // swosdPrm.outQueParams.nextLink = ipcOutVpssId;
    /* IPC Out VPSS link params */
    ipcOutVpssPrm.inQueParams.prevLinkId = mergeId[CAM_STREAM_MERGE_IDX];//gVsysModuleContext.swOsdId;
    ipcOutVpssPrm.inQueParams.prevLinkQueId = 0;
    ipcOutVpssPrm.numOutQue = 1;
    ipcOutVpssPrm.outQueParams[0].nextLink = ipcInVideoId;
    ipcOutVpssPrm.notifyNextLink = TRUE;
    ipcOutVpssPrm.notifyPrevLink = TRUE;
    ipcOutVpssPrm.noNotifyMode = FALSE;
    /* IPC In VIDEO params */
    ipcInVideoPrm.inQueParams.prevLinkId = ipcOutVpssId;
    ipcInVideoPrm.inQueParams.prevLinkQueId = 0;
    ipcInVideoPrm.numOutQue = 1;
    ipcInVideoPrm.outQueParams[0].nextLink = gVencModuleContext.encId;
    ipcInVideoPrm.notifyNextLink = TRUE;
    ipcInVideoPrm.notifyPrevLink = TRUE;
    ipcInVideoPrm.noNotifyMode = FALSE;
    /* Video Encoder Link params */
    MULTICH_INIT_STRUCT(EncLink_CreateParams, encPrm);
    EncLink_ChCreateParams *pLinkChPrm;
    EncLink_ChDynamicParams *pLinkDynPrm;
    VENC_CHN_DYNAMIC_PARAM_S *pDynPrm;
    VENC_CHN_PARAMS_S *pChPrm;
    for (i = 0; i < VENC_PRIMARY_CHANNELS; i++)///VENC_PRIMARY_CHANNELS=2
    pLinkChPrm = &encPrm.chCreateParams[i];
    pLinkDynPrm = &pLinkChPrm->defaultDynamicParams;
    pChPrm = &gVencModuleContext.vencConfig.encChannelParams[i];
    pDynPrm = &pChPrm->dynamicParam;
    switch(gUI_mcfw_config.demoCfg.codec_combo) {
    case 0: pLinkChPrm->format = IVIDEO_H264HP; break; //"SINGLE_H264"
    case 1: pLinkChPrm->format = IVIDEO_MPEG4SP; break; //"SINGLE_MPEG4"
    case 2: pLinkChPrm->format = IVIDEO_MJPEG; break; //"SINGLE_JPEG"
    case 3: pLinkChPrm->format = (i==0)? IVIDEO_H264HP:IVIDEO_MJPEG; break; //"H264_JPEG"
    case 4: pLinkChPrm->format = (i==0)? IVIDEO_MPEG4SP:IVIDEO_MJPEG; break; //"MPEG4_JPEG"
    case 5: pLinkChPrm->format = (i==0)? IVIDEO_H264HP:IVIDEO_H264HP; break; //"DUAL_H264"
    case 6: pLinkChPrm->format = (i==0)? IVIDEO_MPEG4SP:IVIDEO_MPEG4SP; break; //"DUAL_MPEG4"
    case 7: pLinkChPrm->format = (i==0)? IVIDEO_H264HP:IVIDEO_MPEG4SP; break; //"H264_MPEG4"
    case 8: pLinkChPrm->format = (i==0)? IVIDEO_H264HP:IVIDEO_H264HP; break; //"TRIPLE_H264"
    case 9: pLinkChPrm->format = (i==0)? IVIDEO_MPEG4SP:IVIDEO_MPEG4SP; break; //"TRIPLE_MPEG4"
    default: pLinkChPrm->format = IVIDEO_H264HP;
    pLinkChPrm->profile = gVencModuleContext.vencConfig.h264Profile[i];
    pLinkChPrm->dataLayout = IVIDEO_PROGRESSIVE;
    pLinkChPrm->fieldMergeEncodeEnable = FALSE;
    pLinkChPrm->enableAnalyticinfo = pChPrm->enableAnalyticinfo;
    pLinkChPrm->maxBitRate = pChPrm->maxBitRate;
    pLinkChPrm->encodingPreset = pChPrm->encodingPreset;
    pLinkChPrm->rateControlPreset = IVIDEO_USER_DEFINED; //pChPrm->rcType;
    pLinkChPrm->enableHighSpeed = FALSE;
    pLinkChPrm->enableWaterMarking = pChPrm->enableWaterMarking;
    pLinkChPrm->StreamPreset = gUI_mcfw_config.StreamPreset[i];
    pLinkDynPrm->intraFrameInterval = pDynPrm->intraFrameInterval;
    pLinkDynPrm->targetBitRate = pDynPrm->targetBitRate;
    pLinkDynPrm->interFrameInterval = 1;
    pLinkDynPrm->mvAccuracy = IVIDENC2_MOTIONVECTOR_QUARTERPEL;
    pLinkDynPrm->inputFrameRate = pDynPrm->inputFrameRate;
    pLinkDynPrm->rcAlg = pDynPrm->rcAlg;
    pLinkDynPrm->qpMin = pDynPrm->qpMin;
    pLinkDynPrm->qpMax = pDynPrm->qpMax;
    pLinkDynPrm->qpInit = pDynPrm->qpInit;
    pLinkDynPrm->vbrDuration = pDynPrm->vbrDuration;
    pLinkDynPrm->vbrSensitivity = pDynPrm->vbrSensitivity;
    if ((gUI_mcfw_config.demoCfg.resolution_combo == RES_10MP_D1) && (i == 0))
    encPrm.numBufPerCh[i] = 2;
    else if ((gUI_mcfw_config.demoCfg.resolution_combo == RES_8MP_D1) && (i == 0))
    encPrm.numBufPerCh[i] = 3;
    else
    encPrm.numBufPerCh[i] = 4;
    gVencModuleContext.encFormat[i] = pLinkChPrm->format;
    /* Video Encoder Framerate */
    #ifdef IMGS_OMNIVISION_OV10630
    encPrm.chCreateParams[0].defaultDynamicParams.inputFrameRate = 30; // ENC_LINK_DEFAULT_ALGPARAMS_INPUTFRAMERATE;
    #elif defined IMGS_MICRON_MT9M034
    #else
    #endif
    encPrm.chCreateParams[1].defaultDynamicParams.inputFrameRate = 30; // ENC_LINK_DEFAULT_ALGPARAMS_INPUTFRAMERATE;
    encPrm.vsEnable = gUI_mcfw_config.vsEnable;
    if(gUI_mcfw_config.vaUseCase == TRUE)
    encPrm.isVaUseCase = 1;
    else
    encPrm.isVaUseCase = 0;
    /////////////////////////////JPEG///////////////////////////////////////////////
    for (i = VENC_PRIMARY_CHANNELS; i < (VENC_CHN_MAX - 1); i++)///i=VENC_PRIMARY_CHANNELS,就是把最后一路用雨JPEG压缩
    encPrm.chCreateParams[i].format = IVIDEO_MJPEG;
    encPrm.chCreateParams[i].profile = 0;
    encPrm.chCreateParams[i].dataLayout = IVIDEO_PROGRESSIVE;
    encPrm.chCreateParams[i].fieldMergeEncodeEnable = FALSE;
    encPrm.chCreateParams[i].defaultDynamicParams.intraFrameInterval = 0;
    encPrm.chCreateParams[i].encodingPreset = 0;
    encPrm.chCreateParams[i].enableAnalyticinfo = 0;
    encPrm.chCreateParams[i].enableWaterMarking = 0;
    encPrm.chCreateParams[i].defaultDynamicParams.inputFrameRate = 30;
    encPrm.chCreateParams[i].rateControlPreset = 0;
    encPrm.chCreateParams[i].defaultDynamicParams.targetBitRate = 100 * 1000;
    encPrm.chCreateParams[i].defaultDynamicParams.interFrameInterval = 0;
    encPrm.chCreateParams[i].defaultDynamicParams.mvAccuracy = 0;
    encPrm.inQueParams.prevLinkId = ipcInVideoId;
    encPrm.inQueParams.prevLinkQueId = 0;
    encPrm.outQueParams.nextLink = gVencModuleContext.ipcBitsOutRTOSId;
    /* null Link Params */
    hdNullPrm.numInQue = 1;
    hdNullPrm.inQueParams[0].prevLinkId = gVencModuleContext.encId;
    hdNullPrm.inQueParams[0].prevLinkQueId = 0;
    /* IPC Bits Out VIDEO Link params */
    ipcBitsOutVideoPrm.baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.encId;
    ipcBitsOutVideoPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
    ipcBitsOutVideoPrm.baseCreateParams.numOutQue = 1;
    ipcBitsOutVideoPrm.baseCreateParams.outQueParams[0].nextLink = gVencModuleContext.ipcBitsInHLOSId;
    MultiCh_ipcBitsInitCreateParams_BitsOutRTOS(&ipcBitsOutVideoPrm, TRUE);
    /* IPC Bits In HOST Link params */
    ipcBitsInHostPrm0.baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.ipcBitsOutRTOSId;
    ipcBitsInHostPrm0.baseCreateParams.inQueParams.prevLinkQueId = 0;
    MultiCh_ipcBitsInitCreateParams_BitsInHLOS(&ipcBitsInHostPrm0);
    /* Links Creation */
    System_linkCreate(NullSrcId, &NullSrcPrm,sizeof(NullSrcPrm));
    /* Camera Link */
    // System_linkCreate(gVcamModuleContext.cameraId, &cameraPrm,sizeof(cameraPrm));
    // System_linkControl(gVcamModuleContext.cameraId,CAMERA_LINK_CMD_DETECT_VIDEO, NULL, 0, TRUE);
    gIsGlbceInitDone = 0;
    /* Dup Link */
    System_linkCreate(dupId, &dupPrm, sizeof(dupPrm));
    /* Merge Link */
    System_linkCreate(mergeId[CAM_STREAM_MERGE_IDX],&mergePrm[CAM_STREAM_MERGE_IDX],sizeof(mergePrm[CAM_STREAM_MERGE_IDX]));
    /* SWOSD Link */
    // System_linkCreate(gVsysModuleContext.swOsdId, &swosdPrm, sizeof(swosdPrm));
    /* IPC Links */
    System_linkCreate(ipcOutVpssId, &ipcOutVpssPrm, sizeof(ipcOutVpssPrm));
    System_linkCreate(ipcInVideoId, &ipcInVideoPrm, sizeof(ipcInVideoPrm));
    /* Video Encoder Link */
    System_linkCreate(gVencModuleContext.encId, &encPrm, sizeof(encPrm));
    // System_linkCreate(hdNullId, &hdNullPrm, sizeof(hdNullPrm));
    /* VSTAB link */
    System_linkCreate(vstabId, &vstabPrm, sizeof(vstabPrm));
    /* IPC Bits Links */
    System_linkCreate(gVencModuleContext.ipcBitsOutRTOSId, &ipcBitsOutVideoPrm, sizeof(ipcBitsOutVideoPrm));
    System_linkCreate(gVencModuleContext.ipcBitsInHLOSId, &ipcBitsInHostPrm0, sizeof(ipcBitsInHostPrm0));
    OSA_printf("USECASE SETUP DONE\n");
    但是会一直打印[m3video]  188: SYSTEM: Attaching to [VPSS-M3]。。,不知道为什么
  • Xin Jin,
    如果怀疑是数据的问题,可以手动篡改一下编码输入的buffer数据。
    数据问题让编码器挂起的概率一般来说是比较小的。
