我使用的是IPNC RDK5.1 方案 Linux系统是2.6.37 硬件在USB插上U盘 内核没发现什么变化 请问内核需要怎么配置
James,
下面的链接是基于2.6.32kernel,对于2.6.37 kernel应该是类似的,请参考一下:
https://developer.ridgerun.com/wiki/index.php?title=How_to_configure_DM365_for_USB_host,_device_and_OTG_support
你好,按照文档说明 我配置USB为host模式
│ │ < > USB Gadget Support ---> │ │
│ │ <M> DaVinci │ │
│ │ Driver Mode (USB Host) --->
禁用 USB Gadget Support ,配置 Driver Mode 为USB HOST
但当我插上usb 没看到有上面反应 如果配置为主机模式 插上U盘 内核应该是有提示的是吗?如果检测到了 那应该怎么挂载u盘呢?
V_BUS是直接接5V的电源 目前存在大部分情况能正常检测到USB 但是断电测试 有时候会出现无法检测USB的情况 ,dmesg 打印一下信息
[ 7.465654] iscsi: registered transport (tcp)
[ 7.994887] musb-hdrc: version 6.0, host, debug=0
[ 8.461077] musb-hdrc musb-hdrc: dma type: dma-cppi3
[ 8.482654] musb-hdrc: ConfigData=0x06 (UTMI-8, dyn FIFOs, SoftConn)
[ 8.482740] musb-hdrc: MHDRC RTL version 1.500
[ 8.482785] musb-hdrc: setup fifo_mode 2
[ 8.482849] musb-hdrc: 9/9 max ep, 4032/4096 memory
[ 8.483028] musb-hdrc musb-hdrc: MUSB HDRC host driver
[ 8.483432] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 1
[ 8.524528] hub 1-0:1.0: USB hub found
[ 8.524735] hub 1-0:1.0: 1 port detected
[ 8.534293] musb-hdrc musb-hdrc: USB Host mode controller at fec64000 using DMA, IRQ 12
[ 8.972020] usb 1-1: new full speed USB device using musb-hdrc and address 2
[ 9.090678] usb 1-1: device descriptor read/64, error -71
[ 9.099397] loop: module loaded
[ 9.331564] tun: Universal TUN/TAP device driver, 1.6
[ 9.331648] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 9.352598] usb 1-1: device descriptor read/64, error -71
[ 9.503308] console [netcon0] enabled
[ 9.503376] netconsole: network logging started
[ 9.583310] usb 1-1: new full speed USB device using musb-hdrc and address 3
[ 9.701097] usb 1-1: device descriptor read/64, error -71
[ 9.789565] PPP generic driver version 2.4.2
[ 9.888197] PPP Deflate Compression module registered
[ 9.952076] usb 1-1: device descriptor read/64, error -71
[ 10.182016] usb 1-1: new full speed USB device using musb-hdrc and address 4
[ 10.600899] usb 1-1: device not accepting address 4, error -71
[ 10.750564] usb 1-1: new full speed USB device using musb-hdrc and address 5
[ 11.172383] usb 1-1: device not accepting address 5, error -71
[ 11.195632] hub 1-0:1.0: unable to enumerate USB device on port 1
软件重启 一直打印这样的信息 只有硬件断电才可能启动正常 这会是跟电源有什么关系吗?
期待你的回复
james ZHANG1 说:但是断电测试 有时候会出现无法检测USB的情况
james ZHANG1 说:软件重启 一直打印这样的信息
到底是断电测试,还是软件重启测试有问题?
James,
从log看,你在usb侧挂了一个usb hub?请问这个hub是否也是外部5v供电的?
下面的e2e的usb问题是电源引起的,你看看是否有参考价值。
https://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/100/t/150995
