手册上说am5728的IVAHD支持H264编解码,我想用它做两路视频编解码,需要如何配置呢?
你好,我熟悉了一下 gstreamer 下面是我的代码 我是用这个代码 而且 也是使用的交叉编译编译工具链编译的:
#include <stdio.h>
#include <string.h>
#include <gst/gst.h>
#include <glib.h>
GstElement *pipeline,*source,*demuxer,
*Videoqueue,*h264par,*Videodecoder,*Videosink,
*Audioqueue,*Audiodecoder,*Audiosink;
static gboolean bus_call(GstBus *bus,GstMessage *msg,gpointer data){
GMainLoop *loop = (GMainLoop *)data;
switch(GST_MESSAGE_TYPE(msg)){
case GST_MESSAGE_EOS:
g_print("play ending!\n");
break;
case GST_MESSAGE_ERROR: {
gchar *debug;
GError *error;
gst_message_parse_error(msg,&error,&debug);
g_free(debug);
g_printerr("Error: %s\n",error->message);
g_error_free(error);
g_main_loop_quit(loop);
break;
default:
break;
return(TRUE);
static void on_pad_added(GstElement *element,GstPad *pad,gpointer data){
char video[12]="video_0"; //char audio[9]="audio_00";
gchar *new_pad_name = GST_PAD_NAME(pad);
g_print("recvfrom '%s' new pad' %s' \n",GST_ELEMENT_NAME (element),
new_pad_name);
GstPad *audio_sink_pad ,*video_sink_pad;
video_sink_pad = gst_element_get_static_pad(Videoqueue,"sink");
audio_sink_pad = gst_element_get_static_pad(Audioqueue,"sink");
if(!strcmp(new_pad_name,video)){
g_print("link %s pad\n",new_pad_name);
gst_pad_link(pad,video_sink_pad);
}else{
gst_pad_link(pad,audio_sink_pad);
gst_object_unref(video_sink_pad);
gst_object_unref(audio_sink_pad);
int main(int argc,char *argv[]){
GMainLoop *loop;
GstBus *bus;
gst_init(&argc,&argv);
loop = g_main_loop_new(NULL,FALSE);
if (argc != 2)
g_printerr("You need file : %s <.moc filename>\n",argv[0]);
return(-1);
//创建用来容纳元件的新管道
pipeline = gst_pipeline_new("test-pipeline");
if (!pipeline){
g_printerr("pipeline creat failure,quit!\n");
return(-1);
//生成用于读取硬盘数据的元件
source = gst_element_factory_make("filesrc","file-source");
if (!source){
g_printerr("source creat failure,quit!\n");
return(-1);
//流分离器
demuxer = gst_element_factory_make("qtdemux","demuxer");
if (!demuxer){
g_printerr("demuxer creat failure,quit!\n");
return(-1);
//队列元件 同步输出设备,播放视频、音频流,双线程可以独立运行并达到更好的同步效果。
Videoqueue = gst_element_factory_make("queue","videoqueue");
if (!Videoqueue){
g_printerr("Videoqueue creat failure,quit!\n");
return(-1);
//h264parse
h264par = gst_element_factory_make("h264parse","h264par");
if (!h264par){
g_printerr("h264par creat failure,quit!\n");
return(-1);
//视频解码器
Videodecoder = gst_element_factory_make("ducatih264dec","video-decoder");
if (!Videodecoder){
g_printerr("Videodecoder creat failure,quit!\n");
return(-1);
//视频回放元件
Videosink = gst_element_factory_make("kmssink","video-output");
if (!Videosink){
g_printerr("Videosink creat failure,quit!\n");
return(-1);
//队列元件
Audioqueue = gst_element_factory_make("queue","audioqueue");
if (!Audioqueue){
g_printerr("Audioqueue creat failure,quit!\n");
return(-1);
//音频解码器
Audiodecoder = gst_element_factory_make("decodebin","audio-decoder");
if (!Audiodecoder){
g_printerr("Audiodecoder creat failure,quit!\n");
return(-1);
//音频回放元件
Audiosink = gst_element_factory_make("fakesink","audio-output");
if (!Audiosink){
g_printerr("Audiosink creat failure,quit!\n");
return(-1);
//|| !h264par
if (!pipeline || !source || !demuxer || !queue || !decoder
|| !textoverlay || !sink || !Audioqueue || !Audiodecoder
|| !Audiosink){
g_printerr("element creat failure,quit!\n");
return(-1);
//设置 source的location 参数 文件地址
g_object_set(G_OBJECT(source),"location",argv[1],NULL);
//g_object_set(G_OBJECT(Videosink),"scale",1,NULL);
//得到 管道的消息总线
bus = gst_pipeline_get_bus(GST_PIPELINE(pipeline));
gst_bus_add_watch(bus,bus_call,loop); //添加消息监视器
gst_object_unref(bus);
//添加元件
gst_bin_add_many(GST_BIN(pipeline),
source,demuxer,Videoqueue,h264par,Videodecoder,Videosink,
Audioqueue,Audiodecoder,Audiosink,NULL);
//分别链接元件
gst_element_link(source,demuxer);
gst_element_link_many(Videoqueue,h264par,Videodecoder,Videosink,NULL);
gst_element_link_many(Audioqueue,Audiodecoder,Audiosink,NULL);
//按照不同的流,动态链接不同的接收衬垫 sink pad
g_signal_connect(demuxer,"pad-added",G_CALLBACK(on_pad_added),NULL);
//开始播放
g_print("start playing %s\n",argv[1]);
gst_element_set_state(pipeline,GST_STATE_PLAYING);
g_main_loop_run(loop);
//停止管道处理流程
gst_element_set_state(pipeline,GST_STATE_NULL);
//释放占用的资源
gst_object_unref(GST_OBJECT(pipeline));
return(0);
编译命令:/home/aba/ti-processor-sdk-linux-am57xx-evm-03.00.00.04/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-gcc -pthread gst_mov.c -o gst_mov -I/home/aba/ti-processor-sdk-linux-am57xx-evm-03.00.00.04/targetNFS/usr/include/gstreamer-1.0/ -I/home/aba/ti-processor-sdk-linux-am57xx-evm-03.00.00.04/targetNFS/usr/include/glib-2.0/ -I/home/aba/ti-processor-sdk-linux-am57xx-evm-03.00.00.04/targetNFS/usr/lib/glib-2.0/include/ -I/home/aba/ti-processor-sdk-linux-am57xx-evm-03.00.00.04/targetNFS/usr/include/glib-2.0/glib/ -L/home/aba/ti-processor-sdk-linux-am57xx-evm-03.00.00.04/targetNFS/usr/lib -L/home/aba/ti-processor-sdk-linux-am57xx-evm-03.00.00.04/targetNFS/lib -lgstreamer-1.0 -lgobject-2.0 -lgmodule-2.0 -lpthread -lxml2 -lglib-2.0
//板子接上键盘 ctrl+Backspace ctrl+F2 模式
runing: ./gst_mov /usr/share/ti/video/TearOfSteel-Short-1920x800.mov
//上面这的程序运行没有错误 可是并没有出现视频画面 谢谢
//下面这个命令是可以执行的
gst-launch-1.0 filesrc location=b.mov ! qtdemux name=demux demux.audio_0 ! queue ! decodebin ! fakesink demux.video_0 ! queue ! h264parse ! ducatih264dec ! kmssink scale=true
请问您是在哪个板子上做的实验,另外,请您参考 http://processors.wiki.ti.com/index.php/Processor_Training:_Multimedia
命令行就是给出了需要用的plugin以及连接方式,如果要写成代码,请您自行研究gstreamer的文档写代码了,其实网上的资源很多。
对于应用层,我们支持有限。
请问我发现打不份的管道在长时间运行都会出现这个问题,你知道怎么解决么?
(gst-launch-1.0:1355): CRITICAL **: gst_fd_memory_get_fd: assertion 'GST_IS_FD_ALLOCATOR (mem->allocator)' failed
** (gst-launch-1.0:1355): CRITICAL **: gst_fd_memory_get_fd: assertion 'GST_IS_FD_ALLOCATOR (mem->allocator)' failed
详细请看我发的帖子:e2e.ti.com/.../656704
