现在我的ini文件中已经设置bootExitType=securewithsk,可是我在执行setuserkey()函数中的resultval=SK——registerscwp()函数时总是返回的值和scw不相等是什么原因呢?
看一下返回值到底是什么,对照下面说明,看是出的什么错。
Syntax int SK_registerSCWP(scwp, numSC);
Parameters int *scwp – pointer to an integer owned by the Operating System that tracks the current secure context.
unsigned numSC – number of secure contexts into which the single secure stack block is divided
Return Value SCWP, if no error
SK_EPRIV if not called from supervisor privilege level
SK_EINUSE if any secure contexts are currently allocated
SK_EINVAL if scwp is not word-aligned
SK_ECTX if numSC is bad (can only be 1, 2, 4 or 8)
Constraints Must be called from supervisor privilege
