am4378使用CCS调试starterware出现问题
我使用CCS6.2编译了下载的starterware里的bootloader,然后用仿真器连接了cortex-a9核,但是使用load program加载out文件出错,报错内容:
CortexA9: Trouble Writing Memory Block at 0x402f0074 on Page 0 of Length 0x7ff0: (Error -1065 @ 0x3D5A) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 6.0.407.6)
CortexA9: File Loader: Verification failed: Target failed to write 0x402F0074
CortexA9: GEL: File: D:\ti\sysbios_ind_sdk_02.01.02.02\sdk\starterware\binary\bootloader\bin\am43xx-evm\ccs\bootloader_boot_mmcsd_a9host_debug.out: Load failed.
按上面说的应该是指0x402F0074无法写入,我查了芯片手册的memory map,发现
The download image resides from 0x402F4000 (0x402F0400 for PG1.1) to 0x40337C00
in GP device. 从0x402F0000到0x402F4000 (0x402F0400 for PG1.1) 这段地址空间是保留的无法访问。
那是不是说明是因为程序的入口地址或者什么地址写错了,我下载的官方的源码,没改过。想问下问题出在哪,应该怎么改,我想在ram中调试starerware里的bootloader。
