AM3354 从SD卡启动一直卡在 A start job is running for
Other Parts Discussed in Thread: TPS65910
我使用的是ti-processor-sdk-linux-rt-am335x-evm-03.01.00.06,用里面的工具制作SD卡启动,一开始可以正常进入系统,断电后再启动就一直卡在A start job is running for....
请问这是咋回事,怀疑文件系统坏了,重新制作了SD卡,又可以进入系统了,过一会又卡在A start job is running for....了
启动信息是:
\0
U-Boot SPL 2016.05 (Oct 19 2016 - 14:39:20)
Trying to boot from MMC1
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
reading u-boot.img
reading u-boot.img
U-Boot 2016.05 (Oct 19 2016 - 14:39:20 +0800)
Watchdog enabled
DRAM: 512 MiB
NAND: 1024 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
reading uboot.env
** Unable to read "uboot.env" from mmc0:1 **
Using default environment
<ethaddr> not set. Validating first E-fuse MAC
Net: eth0: ethernet@4a100000
Warning: usb_ether MAC addresses don't match:
Address in SROM is de:ad:be:ef:00:01
Address in environment is 68:c9:0b:cf:44:06
, eth1: usb_ether
Press SPACE to abort autoboot in 2 seconds
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
** Unable to read file uEnv.txt **
Scanning mmc 0:1...
reading boot.scr
reading uEnv.txt
3316480 bytes read in 224 ms (14.1 MiB/s)
41129 bytes read in 25 ms (1.6 MiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x329b00 ]
## Flattened Device Tree blob at 88000000
Booting using the fdt blob at 0x88000000
Loading Device Tree to 8fff2000, end 8ffff0a8 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.19-rt25-gf572d285f0 (xu@xu-virtual-machine) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05-rc2) ) #43 PREEMPT RT Thu Oct 27 18:35:49 CST 2016
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: TI AM335x EVM-SK
[ 0.000000] cma: Reserved 24 MiB at 0x9e800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=0001f2f5-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 485160K/524288K available (6115K kernel code, 315K rwdata, 2240K rodata, 260K init, 308K bss, 14552K reserved, 24576K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0830fd4 (8356 kB)
[ 0.000000] .init : 0xc0831000 - 0xc0872000 ( 260 kB)
[ 0.000000] .data : 0xc0872000 - 0xc08c0d40 ( 316 kB)
[ 0.000000] .bss : 0xc08c0d40 - 0xc090df14 ( 309 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU kthread priority: 1.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000012] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000026] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000031] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000181] clocksource_probe: no matching clocksources found
[ 0.000355] Console: colour dummy device 80x30
[ 0.000496] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000498] This ensures that you still see kernel messages. Please
[ 0.000500] update your kernel commandline.
[ 0.089230] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.089235] pid_max: default: 32768 minimum: 301
[ 0.089356] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089361] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.090033] Initializing cgroup subsys io
[ 0.090054] Initializing cgroup subsys memory
[ 0.090091] Initializing cgroup subsys devices
[ 0.090102] Initializing cgroup subsys freezer
[ 0.090111] Initializing cgroup subsys perf_event
[ 0.090119] Initializing cgroup subsys pids
[ 0.090187] CPU: Testing write buffer coherency: ok
[ 0.090553] Setting up static identity map for 0x80008200 - 0x80008258
[ 0.092938] devtmpfs: initialized
[ 0.104707] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.117737] omap_hwmod: debugss: _wait_target_disable failed
[ 0.172448] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.174603] pinctrl core: initialized pinctrl subsystem
[ 0.175870] NET: Registered protocol family 16
[ 0.177929] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.183204] OMAP GPIO hardware version 0.1
[ 0.193497] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.227308] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.228232] reg-fixed-voltage fixedregulator@2: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_wl12xx_gpio, deferring probe
[ 0.231530] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.231580] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.231699] media: Linux media interface: v0.10
[ 0.231753] Linux video capture interface: v2.00
[ 0.231798] pps_core: LinuxPPS API ver. 1 registered
[ 0.231805] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.231831] PTP clock support registered
[ 0.231887] EDAC MC: Ver: 3.0.0
[ 0.233017] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.234398] clocksource: Switched to clocksource timer1
[ 0.244566] NET: Registered protocol family 2
[ 0.245364] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.245428] TCP bind hash table entries: 4096 (order: 4, 98304 bytes)
[ 0.245582] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.245659] UDP hash table entries: 256 (order: 2, 16384 bytes)
[ 0.245690] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[ 0.245899] NET: Registered protocol family 1
[ 0.246365] RPC: Registered named UNIX socket transport module.
[ 0.246382] RPC: Registered udp transport module.
[ 0.246388] RPC: Registered tcp transport module.
[ 0.246394] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.247318] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.249273] futex hash table entries: 256 (order: 1, 8192 bytes)
[ 0.256902] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.257623] NFS: Registering the id_resolver key type
[ 0.257692] Key type id_resolver registered
[ 0.257699] Key type id_legacy registered
[ 0.257777] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.261259] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.261288] io scheduler noop registered
[ 0.261300] io scheduler deadline registered
[ 0.261560] io scheduler cfq registered (default)
[ 0.262870] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.265894] FunctionName:pwm_backlight_probe
[ 0.265922] pwm-backlight backlight: testOK:dev_err
[ 0.265932] FunctionName:compute_duty_cycle
[ 0.265939] max_brightness:9dft_brightness:7
[ 0.265949] max_brightness:8[ 0.266035] backlight supply power not found, using dummy regulator
[ 0.266447] FunctionName:pwm_backlight_update_status
[ 0.266456] FunctionName:compute_duty_cyclelth_brightness:0
[ 0.266466] brightness:7duty_cycle:170
[ 0.266474] period:50000scale:255
[ 0.266481] temp_cycle:33333FunctionName:pwm_backlight_power_on
[ 0.266572] FunctionName:pwm_backlight_power_on:OKpwm_backlight_remove:OK
[ 0.322300] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.325737] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[ 0.989082] console [ttyS0] enabled
[ 0.993578] [drm] Initialized drm 1.1.0 20060810
[ 1.000569] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.007248] [drm] No driver support for vblank timestamp query.
[ 1.026950] Console: switching to colour frame buffer device 100x30
[ 1.038078] tilcdc 4830e000.lcdc: fb0: frame buffer device
[ 1.064428] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 1.077028] loop: module loaded
[ 1.082810] libphy: Fixed MDIO Bus: probed
[ 1.144427] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.150566] davinci_mdio 4a101000.mdio: detected phy mask ffffffde
[ 1.158149] libphy: 4a101000.mdio: probed
[ 1.162195] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver unknown
[ 1.170271] davinci_mdio 4a101000.mdio: phy[5]: device 4a101000.mdio:05, driver unknown
[ 1.179067] cpsw 4a100000.ethernet: Detected MACID = 68:c9:0b:cf:44:04
[ 1.186515] cpsw 4a100000.ethernet: cpsw: Detected MACID = 68:c9:0b:cf:44:06
[ 1.195181] mousedev: PS/2 mouse device common for all mice
[ 1.201493] i2c /dev entries driver
[ 1.206493] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.215772] NET: Registered protocol family 10
[ 1.221733] sit: IPv6 over IPv4 tunneling driver
[ 1.227190] NET: Registered protocol family 17
[ 1.231960] Key type dns_resolver registered
[ 1.236452] omap_voltage_late_init: Voltage driver support not added
[ 1.264680] tps65910 0-002d: No interrupt support, no core IRQ
[ 1.298081] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.305376] Goodix-TS 1-005d: goodix_ts_probe start
[ 1.310280] Goodix-TS 1-005d: chip address:93
[ 1.314656] Goodix-TS 1-005d: I2C name:OMAP I2C adapter
[ 1.319903] Goodix-TS 1-005d: I2C name:gt911_ts
[ 1.346031] Goodix-TS 1-005d: ID 911, version: 1060
[ 1.373274] input: Goodix Capacitive TouchScreen as /devices/platform/ocp/4802a000.i2c/i2c-1/1-005d/input/input0
[ 1.384324] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.390653] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.395822] vmmc: supplied by vbat
[ 1.471704] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.481743] mmc0: new high speed SDHC card at address 1234
[ 1.487941] mmcblk0: mmc0:1234 SA08G 7.25 GiB
[ 1.494190] mmcblk0: p1 p2
[ 1.559499] input: gpio_buttons@0 as /devices/platform/gpio_buttons@0/input/input1
[ 1.567619] hctosys: unable to open rtc device (rtc0)
[ 1.578027] lis3_reg: disabling
[ 1.581219] vwl1271: disabling
[ 1.962961] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.971174] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.980793] devtmpfs: mounted
[ 1.984118] Freeing unused kernel memory: 260K (c0831000 - c0872000)
[ 2.293481] systemd[1]: System time before build time, advancing clock.
[ 2.352901] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available)
[ 2.368398] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available)
[ 2.386723] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 2.405545] systemd[1]: Detected architecture arm.
Welcome to [1mArago 2016.08[0m!
[ 2.436599] systemd[1]: Set hostname to <am335x-evm>.
[ 2.541743] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[ 2.545436] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 25 bits of entropy available)
[ 2.545839] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 25 bits of entropy available)
[ 2.613990] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 27 bits of entropy available)
[ 2.665598] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 2.676168] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 2.686018] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 2.696182] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 3.134019] systemd[1]: Reached target Swap.
[[0;32m OK [0m] Reached target Swap.
[ 3.155291] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[[0;32m OK [0m] Listening on /dev/initctl Compatibility Named Pipe.
[ 3.185535] systemd[1]: Listening on Network Service Netlink Socket.
[[0;32m OK [0m] Listening on Network Service Netlink Socket.
[ 3.215024] systemd[1]: Reached target Remote File Systems.
[[0;32m OK [0m] Reached target Remote File Systems.
[ 3.245272] systemd[1]: Listening on udev Control Socket.
[[0;32m OK [0m] Listening on udev Control Socket.
[ 3.275262] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[[0;32m OK [0m] Started Dispatch Password Requests to Console Directory Watch.
[ 3.333891] systemd[1]: Created slice User and Session Slice.
[[0;32m OK [0m] Created slice User and Session Slice.
[ 3.365314] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[[0;32m OK [0m] Started Forward Password Requests to Wall Directory Watch.
[ 3.394894] systemd[1]: Reached target Paths.
[[0;32m OK [0m] Reached target Paths.
[ 3.415267] systemd[1]: Listening on Syslog Socket.
[[0;32m OK [0m] Listening on Syslog Socket.
[ 3.445160] systemd[1]: Listening on Journal Socket (/dev/log).
[[0;32m OK [0m] Listening on Journal Socket (/dev/log).
[ 3.476193] systemd[1]: Created slice System Slice.
[[0;32m OK [0m] Created slice System Slice.
[ 3.506367] systemd[1]: Created slice system-getty.slice.
[[0;32m OK [0m] Created slice system-getty.slice.
[ 3.534988] systemd[1]: Reached target Slices.
[[0;32m OK [0m] Reached target Slices.
[ 3.555288] systemd[1]: Listening on Journal Socket.
[[0;32m OK [0m] Listening on Journal Socket.
[ 3.589553] systemd[1]: Starting Setup Virtual Console...
[ 3.638722] systemd[1]: Mounting Temporary Directory...
[ 3.679811] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.739514] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.750880] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.813851] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of required st... nodes for the current kernel...
[ 3.869525] systemd[1]: Starting Journal Service...
[ 3.910112] systemd[1]: Mounting Debug File System...
Mounting Debug File System...[ 3.959098] systemd[1]: Created slice system-serial\x2dgetty.slice.
[[0;32m OK [0m] Created slice system-serial\x2dgetty.slice.
[ 3.995451] systemd[1]: Listening on udev Kernel Socket.
[[0;32m OK [0m] Listening on udev Kernel Socket.
[ 4.039413] systemd[1]: Starting Apply Kernel Variables...
[ 4.122806] systemd[1]: Mounted POSIX Message Queue File System.
[[0;32m OK [0m] Mounted POSIX Message Queue File System.
[ 4.175174] systemd[1]: Mounted Debug File System.
[[0;32m OK [0m] Mounted Debug File System.
[ 4.205269] systemd[1]: Mounted Temporary Directory.
[[0;32m OK [0m] Mounted Temporary Directory.
[ 4.257370] systemd[1]: Started Setup Virtual Console.
[[0;32m OK [0m] Started Setup Virtual Console.
[ 4.297484] systemd[1]: Started Remount Root and Kernel File Systems.
[[0;32m OK [0m] Started Remount Root and Kernel File Systems.
[ 4.337665] systemd[1]: Started Create list of required static device nodes for the current kernel.
[[0;32m OK [0m] Started Create list of required sta...ce nodes for the current kernel.
[ 4.387865] systemd[1]: Started Apply Kernel Variables.
[[0;32m OK [0m] Started Apply Kernel Variables.
[ 5.469440] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 5.533235] systemd[1]: Starting udev Coldplug all Devices...
[ 5.677352] systemd[1]: Started Create Static Device Nodes in /dev.
[[0;32m OK [0m] Started Create Static Device Nodes in /dev.
[ 6.189014] systemd[1]: Starting udev Kernel Device Manager...
[ 6.245128] systemd[1]: Reached target Local File Systems (Pre).
[[0;32m OK [0m] Reached target Local File Systems (Pre).
[ 6.298964] systemd[1]: Mounting /media/ram...
[ 6.369277] systemd[1]: Mounting /var/volatile...
[ 6.508958] systemd[1]: Mounted /var/volatile.
[[0;32m OK [0m] Mounted /var/volatile.
[ 6.575293] systemd[1]: Mounted /media/ram.
[[0;32m OK [0m] Mounted /media/ram.
[ 6.616394] systemd[1]: Started udev Kernel Device Manager.
[[0;32m OK [0m] Started udev Kernel Device Manager.
[ 7.369499] systemd[1]: Reached target Local File Systems.
[[0;32m OK [0m] Reached target Local File Systems.
[ 7.420114] systemd[1]: Starting Load/Save Random Seed...
[ 7.535891] systemd[1]: Started Load/Save Random Seed.
[[0;32m OK [0m] Started Load/Save Random Seed.
[ 8.011683] systemd[1]: Created slice system-systemd\x2dbacklight.slice.
[[0;32m OK [0m] Created slice system-systemd\x2dbacklight.slice.
[ 8.119851] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight...
[ 8.216565] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 8.261908] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 8.265951] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 8.275607] TI-am335x-tsc TI-am335x-tsc: ti,charge-delay not specified
[ 8.277253] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 8.280260] input: ti-tsc as /devices/platform/ocp/44e0d000.tscadc/TI-am335x-tsc/input/input2
[ 8.365554] FunctionName:pwm_backlight_update_status
[ 8.365562] FunctionName:compute_duty_cycle
[ 8.365565] lth_brightness:0
[ 8.365570] brightness:7
[ 8.365572] duty_cycle:170
[ 8.365575] period:50000
[ 8.365577] scale:255
[ 8.365587] temp_cycle:33333
[ 8.380033] FunctionName:pwm_backlight_power_on
[ 8.899929] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
Starting Load/Save Screen Backlight...htness of backlight:backlight...
[ 9.305502] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 9.314017] systemd[1]: Started udev Coldplug all Devices.
[[0;32m OK [0m] Started udev Coldplug all Devices.
[ 9.429232] systemd[1]: Started Load/Save Screen Backlight Brightness of backlight:backlight.
[[0;32m OK [0m] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[ 9.537485] systemd[1]: Found device /dev/ttyS0.
[ 9.561477] remoteproc0: wkup_m3 is available
[ 9.608826] remoteproc0: Note: remoteproc is still under development and considered experimental.
[[0;32m OK [0m] Found device /dev/ttyS0.
[ 9.709549] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 9.971123] remoteproc0: powering up wkup_m3
[ 10.009067] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217152
[ 10.096748] remoteproc0: remote processor wkup_m3 is now up
[ 10.096790] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x191
[ 10.163224] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 10.481652] omap_hwmod: pruss: _wait_target_ready failed: -16
[ 10.577611] ti-pruss 4a300000.pruss: couldn't enable pruss
[ 10.583213] ti-pruss: probe of 4a300000.pruss failed with error -16
[ 10.684356] PM: bootloader does not support rtc-only!
[ 10.871428] systemd[1]: Found device /dev/ttyS3.
[[0;32m OK [0m] Found device /dev/ttyS3.
[ 11.491848] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ 11.549936] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[[0;32m OK [0m] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ 14.150442] usbcore: registered new interface driver usbfs
[ 14.187865] usbcore: registered new interface driver hub
[ 14.238688] usbcore: registered new device driver usb
[ 14.405572] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 14.411420] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 1
[ 14.501670] hub 1-0:1.0: USB hub found
[ 14.535858] hub 1-0:1.0: 1 port detected
[ 14.574813] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 14.580656] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 2
[ 14.611535] hub 2-0:1.0: USB hub found
[ 14.625568] hub 2-0:1.0: 1 port detected
[ 15.034896] usb 2-1: new high-speed USB device number 2 using musb-hdrc
[ 15.198530] hub 2-1:1.0: USB hub found
[ 15.208945] hub 2-1:1.0: 4 ports detected
[[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (13s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (14s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (15s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (15s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (16s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (2 of 3) A start job is running for dev-ttyO3.device (16s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (3 of 3) A start job is running for dev-ttyO0.device (17s / 1min 30s)[K[ [0;31m*[0m] (3 of 3) A start job is running for dev-ttyO0.device (18s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (3 of 3) A start job is running for dev-ttyO0.device (18s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (1 of 3) A start job is running for Journal Service (19s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (19s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (20s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (21s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (21s / 1min 30s)[K[[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (22s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (23s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (23s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (24s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (24s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (1 of 3) A start job is running for Journal Service (25s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (1 of 3) A start job is running for Journal Service (26s / 1min 30s)[K[ [0;31m*[0m] (2 of 3) A start job is running for dev-ttyO3.device (26s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (2 of 3) A start job is running for dev-ttyO3.device (27s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (2 of 3) A start job is running for dev-ttyO3.device (27s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (28s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (29s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (29s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (30s / 1min 30s)[K[[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (30s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (31s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (32s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (32s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (33s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (3 of 3) A start job is running for dev-ttyO0.device (34s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (3 of 3) A start job is running for dev-ttyO0.device (34s / 1min 30s)[K[ [0;31m*[0m] (3 of 3) A start job is running for dev-ttyO0.device (35s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (1 of 3) A start job is running for Journal Service (35s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (1 of 3) A start job is running for Journal Service (36s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (37s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (37s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (38s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (38s / 1min 30s)[K[[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (39s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (40s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (40s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (41s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (41s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (1 of 3) A start job is running for Journal Service (42s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (2 of 3) A start job is running for dev-ttyO3.device (43s / 1min 30s)[K[ [0;31m*[0m] (2 of 3) A start job is running for dev-ttyO3.device (43s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (2 of 3) A start job is running for dev-ttyO3.device (44s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (3 of 3) A start job is running for dev-ttyO0.device (44s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (45s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (46s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (46s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (47s / 1min 30s)[K[[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (48s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (48s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (49s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (49s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (50s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (3 of 3) A start job is running for dev-ttyO0.device (51s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (3 of 3) A start job is running for dev-ttyO0.device (51s / 1min 30s) [K[ [0;31m*[0m] (1 of 3) A start job is running for Journal Service (52s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (1 of 3) A start job is running for Journal Service (52s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (1 of 3) A start job is running for Journal Service (53s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (54s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (54s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for dev-ttyO3.device (55s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (55s / 1min 30s)[K[[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (56s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for dev-ttyO0.device (57s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (57s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (58s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for Journal Service (58s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (2 of 3) A start job is running for dev-ttyO3.device (59s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (2 of 3) A start job is running for dev-ttyO3.device (59s / 1min 30s)[K[ [0;31m*[0m] (2 of 3) A start job is running for dev-ttyO3.device (1min / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (3 of 3) A start job is running for dev-ttyO0.device (1min / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (3 of 3) A start job is running for...tyO0.device (1min 1s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for...tyO0.device (1min 1s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for...nal Service (1min 2s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for...nal Service (1min 2s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for...nal Service (1min 3s / 1min 30s)[K[[0m[0;31m* [0m] (2 of 3) A start job is running for...tyO3.device (1min 3s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for...tyO3.device (1min 4s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for...tyO3.device (1min 4s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for...tyO0.device (1min 5s / 1min 30s)[ 68.360738] random: nonblocking pool is initialized
[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for...tyO0.device (1min 5s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (3 of 3) A start job is running for...tyO0.device (1min 6s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (1 of 3) A start job is running for...nal Service (1min 6s / 1min 30s)[K[ [0;31m*[0m] (1 of 3) A start job is running for...nal Service (1min 7s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (1 of 3) A start job is running for...nal Service (1min 7s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (2 of 3) A start job is running for...tyO3.device (1min 8s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for...tyO3.device (1min 8s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for...tyO3.device (1min 9s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for...tyO0.device (1min 9s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for...yO0.device (1min 10s / 1min 30s)[K[[0m[0;31m* [0m] (3 of 3) A start job is running for...yO0.device (1min 10s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for...al Service (1min 11s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for...al Service (1min 11s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for...al Service (1min 12s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for...yO3.device (1min 12s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (2 of 3) A start job is running for...yO3.device (1min 13s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (2 of 3) A start job is running for...yO3.device (1min 13s / 1min 30s)[K[ [0;31m*[0m] (3 of 3) A start job is running for...yO0.device (1min 14s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (3 of 3) A start job is running for...yO0.device (1min 14s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (3 of 3) A start job is running for...yO0.device (1min 15s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for...al Service (1min 15s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for...al Service (1min 16s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for...al Service (1min 16s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for...yO3.device (1min 17s / 1min 30s)[K[[0m[0;31m* [0m] (2 of 3) A start job is running for...yO3.device (1min 17s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for...yO3.device (1min 18s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for...yO0.device (1min 18s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for...yO0.device (1min 19s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for...yO0.device (1min 19s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (1 of 3) A start job is running for...al Service (1min 20s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (1 of 3) A start job is running for...al Service (1min 20s / 1min 30s)[K[ [0;31m*[0m] (1 of 3) A start job is running for...al Service (1min 21s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (2 of 3) A start job is running for...yO3.device (1min 21s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (2 of 3) A start job is running for...yO3.device (1min 22s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for...yO3.device (1min 22s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for...yO0.device (1min 23s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for...yO0.device (1min 23s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (3 of 3) A start job is running for...yO0.device (1min 24s / 1min 30s)[K[[0m[0;31m* [0m] (1 of 3) A start job is running for...al Service (1min 24s / 1min 30s)[K[[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for...al Service (1min 25s / 1min 30s)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for...al Service (1min 25s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for...yO3.device (1min 26s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (2 of 3) A start job is running for...yO3.device (1min 26s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (2 of 3) A start job is running for...yO3.device (1min 27s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (3 of 3) A start job is running for...yO0.device (1min 27s / 1min 30s)[K[ [0;31m*[0m] (3 of 3) A start job is running for...yO0.device (1min 28s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m] (3 of 3) A start job is running for...yO0.device (1min 28s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] (1 of 3) A start job is running for...al Service (1min 29s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for...al Service (1min 29s / 1min 30s)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] (1 of 3) A start job is running for...al Service (1min 30s / 1min 30s)[ 93.205106] systemd[1]: dev-ttyO3.device: Job dev-ttyO3.device/start timed out.
[ 93.212531] systemd[1]: Timed out waiting for device dev-ttyO3.device.
[K[[0;1;31m TIME [0m] Timed out waiting for device dev-ttyO3.device.
[ 93.255120] systemd[1]: Dependency failed for Serial Getty on ttyO3.
[[0;1;33mDEPEND[0m] Dependency failed for Serial Getty on ttyO3.
[ 93.295081] systemd[1]: serial-getty@ttyO3.service: Job serial-getty@ttyO3.service/start failed with result 'dependency'.
[ 93.316395] systemd[1]: dev-ttyO3.device: Job dev-ttyO3.device/start failed with result 'timeout'.
[ 93.335789] systemd[1]: dev-ttyO0.device: Job dev-ttyO0.device/start timed out.
[ 93.343204] systemd[1]: Timed out waiting for device dev-ttyO0.device.
[[0;1;31m TIME [0m] Timed out waiting for device dev-ttyO0.device.
[ 93.385076] systemd[1]: Dependency failed for Serial Getty on ttyO0.
[[0;1;33mDEPEND[0m] Dependency failed for Serial Getty on ttyO0.
[ 93.425072] systemd[1]: serial-getty@ttyO0.service: Job serial-getty@ttyO0.service/start failed with result 'dependency'.
[ 93.446401] systemd[1]: dev-ttyO0.device: Job dev-ttyO0.device/start failed with result 'timeout'.
[ 93.922664] systemd[1]: systemd-journald.service: Start operation timed out. Terminating.
[[0;31m*[0;1;31m*[0m[0;31m* [0m] A start job is running for Journal Service (1min 35s / 3min)[K[[0;1;31m*[0m[0;31m* [0m] A start job is running for Journal Service (1min 36s / 3min)[K[[0m[0;31m* [0m] A start job is running for Journal Service (1min 36s / 3min)[K[[0;1;31m*[0m[0;31m* [0m] A start job is running for Journal Service (1min 37s / 3min)[K[[0;31m*[0;1;31m*[0m[0;31m* [0m] A start job is running for Journal Service (1min 37s / 3min)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] A start job is running for Journal Service (1min 38s / 3min)[K[ [0;31m*[0;1;31m*[0m[0;31m* [0m] A start job is running for Journal Service (1min 38s / 3min)[K[ [0;31m*[0;1;31m*[0m[0;31m*[0m] A start job is running for Journal Service (1min 39s / 3min)[K[ [0;31m*[0;1;31m*[0m] A start job is running for Journal Service (1min 39s / 3min)
