我的录像工作两个小时后崩溃,麻烦大神看下,目测和内核有点关系,我是黔驴技穷了。
我的内核是 Linux-2.6.18_pro500-davinci_IPNC ,用的dm368, 录像一段时间后,一般两个小时,我用的12M码流,换了6M的码流也会,崩溃后打印一大片,1、插入U盘后,也会打印一大片内核错误信息,具体打印在附件里,但是系统还是运行正常,再次插拔U盘后内核就完全识别不到U盘了,2、或者此时访问u盘,ls 下挂载目录,也会打印,一大片,此时再次ls,ls就会挂起,终端无法输入命令,无法停止这个命令, 但是用telnet还可以登录正常, 请麻烦专家给我分析下。
[85903.600000] Vendor: SanDisk Model: Ultra Fit Rev: 1.00
[85903.610000] Type: Direct-Access ANSI SCSI revision: 06
[85903.620000] SCSI device sdb: 30375936 512-byte hdwr sectors (15552 MB)
[85903.640000] sdb: Write Protect is off
[85903.640000] sdb: Mode Sense: 43 00 00 00
[85903.640000] sdb: assuming drive cache: write through
[85903.660000] SCSI device sdb: 30375936 512-byte hdwr sectors (15552 MB)
[85903.660000] sdb: Write Protect is off
[85903.670000] sdb: Mode Sense: 43 00 00 00
[85903.670000] sdb: assuming drive cache: write through
[85903.680000] sdb:<1>Unable to handle kernel paging request at virtual address f67ef18c
[85903.680000] pgd = c6fd8000
[85903.680000] [f67ef18c] *pgd=00000000
[85903.680000] Internal error: Oops: 5 [#3]
[85903.680000] Modules linked in: dm365mmap irqk edmak cmemk drv csl m340 i2c
[85903.680000] CPU: 0
[85903.680000] PC is at cache_alloc_refill+0x164/0x5dc
[85903.680000] LR is at 0xf67ef17c
[85903.680000] pc : [<c0096070>] lr : [<f67ef17c>] Tainted: GF
[85903.680000] sp : c3d278d8 ip : c05ded28 fp : c3d27924
[85903.680000] r10: c04e3c00 r9 : c3d26000 r8 : 0000003c
[85903.680000] r7 : f67ef198 r6 : c05e5a00 r5 : c05ded20 r4 : 00000000
[85903.680000] r3 : c05ded30 r2 : 00000000 r1 : 00000000 r0 : 00000000
[85903.680000] Flags: nzCv IRQs off FIQs on Mode SVC_32 Segment kernel
[85903.680000] Control: 5317F
[85903.680000] Table: 86FD8000 DAC: 00000017
[85903.680000] Process usb-stor-scan (pid: 1077, stack limit = 0xc3d26258)
[85903.680000] Stack: (0xc3d278d8 to 0xc3d28000)
[85903.680000] 78c0: 00000050 00000000
[85903.680000] 78e0: c05ded28 c05ded30 c3d2792c 00000050 c3d2791c c3d27900 c0037ba4 60000013
[85903.680000] 7900: c04c2508 00000000 00000000 00001000 c058ce60 00000001 c3d27944 c3d27928
[85903.680000] 7920: c0095efc c0095f1c c05e7d60 00000000 c03909c0 c058ce60 c3d27964 c3d27948
[85903.680000] 7940: c009b798 c0095eb4 c3d279e8 c058ce60 00000000 00000000 c3d27994 c3d27968
[85903.680000] 7960: c009c0bc c009b788 c3d279cc c058ce60 00000000 c058ce60 00000000 00001000
[85903.680000] 7980: c05ef0a8 c00a2d60 c3d279ac c3d27998 c009c168 c009c098 00000000 c058ce60
[85903.680000] 79a0: c3d27a14 c3d279b0 c009f378 c009c15c c039a2d0 c00a3f5c c3d26000 00000000
[85903.680000] 79c0: c3d27a24 c058ce60 c05ef148 00000000 00000000 00000000 00000000 c00a2d60
[85903.680000] 79e0: c3d27a0c c3d279f0 c0077550 00000000 c058ce60 c05ef148 00000000 00000000
[85903.680000] 7a00: 00000000 c00a2d60 c3d27a24 c3d27a18 c00a2d78 c009f338 c3d27a54 c3d27a28
[85903.680000] 7a20: c0079ae8 c00a2d70 60000013 c00d8684 00000000 c3d27aa4 c65c4d80 c52b4020
[85903.680000] 7a40: c032e190 c05ef040 c3d27a74 c3d27a58 c00d8208 c0079a40 c52b4000 c00d8684
[85903.680000] 7a60: c52b4000 c52b4000 c3d27ad4 c3d27a78 c00d86d8 c00d81e4 00000000 00000011
[85903.680000] 7a80: c52b4000 c05ef040 00000001 c05ef040 00000000 c05ef040 c3d27ac4 c3d27aa8
[85903.680000] 7aa0: c004dff4 c004d680 c036ab28 c00d8684 c52b4000 00000004 c65c4d80 c52b4020
[85903.680000] 7ac0: c032e190 c05ef040 c3d27b0c c3d27ad8 c00d853c c00d8694 c3d27b0c 00000000
[85903.680000] 7ae0: c0241cc8 c53695c0 c699b820 00000000 c65c4d80 c05ef040 00000000 c3430800
[85903.680000] 7b00: c3d27c54 c3d27b10 c00a3760 c00d843c c05ef04c ffffffff fbc48000 c5e97a38
[85903.680000] 7b20: c3d27b9c c3d27b30 c00369e4 c0037b70 c5e97a38 c66011f8 c6601210 c03a28fc
[85903.680000] 7b40: c66011f8 c5e97a38 c5e97a38 c66011f8 c00d9df4 c140de18 000041ed c3d27b9c
[85903.680000] 7b60: c3d27b88 c3d27b78 c00b401c c01c859c 40000013 ffffffff 000000d0 00000000
[85903.680000] 7b80: c05e7ee8 c05e7ef0 c3d27bcc 000000d0 c3d27bcc c3d27ba0 c3d27bcc a0000013
[85903.680000] 7ba0: c05eaa00 c05eaa00 c05dbf68 c00a3f38 00006328 c3d27c64 c3d27be4 c3d27bc8
[85903.680000] 7bc0: c0095efc c0095f1c c00da670 00000000 00000002 00000000 c3d27bf4 c3d27be8
[85903.680000] 7be0: c00a2dd0 c0095eb4 c3d27c14 c3d27bf8 c05ef0a8 c3d26000 c05eaa00 c05dbf68
[85903.680000] 7c00: c00a3f38 c3d27c64 c05ef1b4 00000003 c3d27c34 c3d27c20 c0063df4 c0063da4
[85903.680000] 7c20: c05ef0a8 00000000 c3d27c44 c53695c0 c699b820 c05ef040 00000000 00000001
[85903.680000] 7c40: c140de18 c3430800 c3d27c7c c3d27c58 c00a38f4 c00a348c c3d27c64 c05ef040
[85903.680000] 7c60: c65c4d80 c34308f8 c65c4dcc c699b8e0 c3d27c9c c3d27c80 c00d83ac c00a3880
[85903.680000] 7c80: c65c4d80 c3430890 00000001 c65c4d80 c3d27cbc c3d27ca0 c01d2b9c c00d8294
[85903.680000] 7ca0: c01d2990 c65c4d80 c140de18 c3430890 c3d27d04 c3d27cc0 c02421d0 c01d2b5c
[85903.680000] 7cc0: c005fc4c c3d27ce4 c3430890 00000000 00000000 00000001 00000000 00000000
[85903.680000] 7ce0: c3430890 00000000 c0453598 00000000 c140de18 c34308f8 c3d27d24 c3d27d08
[85903.680000] 7d00: c0210cf0 c0241eb8 00000000 c0210d40 c3430890 c3d27d3c c3d27d34 c3d27d28
[85903.680000] 7d20: c0210d50 c0210c84 c3d27d64 c3d27d38 c021051c c0210d50 c01dc7e0 c045308c
[85903.680000] 7d40: c045308c c04535f8 c3430960 c3430890 c3430934 00000000 c3d27d7c c3d27d68
[85903.680000] 7d60: c0210db4 c02104dc c02104b8 c0452f7c c3d27d94 c3d27d80 c02101fc c0210d64
[85903.680000] 7d80: c3430890 c3430890 c3d27dcc c3d27d98 c020f1fc c02101ec c00956e8 00000000
[85903.680000] 7da0: c3d27e30 c3430890 c3430800 c3430800 c3430890 00000000 c140de00 00000000
[85903.680000] 7dc0: c3d27dfc c3d27dd0 c023f1c8 c020ef90 c3430800 c3430890 c3430800 c65c4e80
[85903.680000] 7de0: 00000024 00000000 c140de00 00000001 c3d27e64 c3d27e00 c023d1d8 c023f1a8
[85903.680000] 7e00: 00000024 c3d27e30 00000226 00000003 c65c4e88 00000000 c3d27edc 00000024
[85903.680000] 7e20: 00000012 c3d20024 c3d27e74 c140de80 00000000 00000000 c01dbc44 00000000
[85903.680000] 7e40: 00000000 c3430cd8 ffffffff 00000000 c3d27f98 c140de00 c3d27f0c c3d27e68
[85903.680000] 7e60: c023da24 c023cad4 00000000 00000000 c0327398 a0000013 00000064 c140de18
[85903.680000] 7e80: c3d27ec4 c3d27e90 c0328078 c00576fc 00000000 00200200 00829f4c c0058918
[85903.680000] 7ea0: c1d60740 c04becac 00000002 c1d60740 c3d26000 c3d27f0c c3d27f04 c3d27ec8
[85903.680000] 7ec0: c03279f0 c0327fe8 c3d27f98 00000001 c1d60740 c0048888 00100100 00000000
[85903.680000] 7ee0: c5d4a01c c3430c00 00000000 c3430cd8 ffffffff 00000000 c3d27f98 00000000
[85903.680000] 7f00: c3d27f3c c3d27f10 c023df00 c023d964 00000000 c3d27f10 c3430c00 00000001
[85903.680000] 7f20: ffffffff ffffffff c3430c28 00000000 c3d27f6c c3d27f40 c023dfc0 c023debc
[85903.680000] 7f40: 00000000 c3d26000 c1d60740 c3430eb4 c3d26000 00000000 c3d27f8c c3430f70
[85903.680000] 7f60: c3d27f84 c3d27f70 c023e040 c023df40 00000000 c3430eb4 c3d27fcc c3d27f88
[85903.680000] 7f80: c0264df8 c023e028 c0327270 00000000 c1d60740 c0063df8 c3d27f98 c3d27f98
[85903.680000] 7fa0: 00000000 c3430eb4 c3d26000 c0264cbc c06c3d40 00000000 00000000 00000000
[85903.680000] 7fc0: c3d27ff4 c3d27fd0 c0063cd8 c0264ccc ffffffff ffffffff 00000000 00000000
[85903.680000] 7fe0: 00000000 00000000 00000000 c3d27ff8 c0050618 c0063c00 0000a325 0000d247
[85903.680000] Backtrace:
[85903.680000] [<c0095f0c>] (cache_alloc_refill+0x0/0x5dc) from [<c0095efc>] (kmem_cache_alloc+0x58/0x68)
[85903.680000] [<c0095ea4>] (kmem_cache_alloc+0x0/0x68) from [<c009b798>] (alloc_buffer_head+0x20/0x74)
[85903.680000] r4 = C058CE60
[85903.680000] [<c009b778>] (alloc_buffer_head+0x0/0x74) from [<c009c0bc>] (alloc_page_buffers+0x34/0xc4)
[85903.680000] r6 = 00000000 r5 = 00000000 r4 = C058CE60
[85903.680000] [<c009c088>] (alloc_page_buffers+0x0/0xc4) from [<c009c168>] (create_empty_buffers+0x1c/0x140)
[85903.680000] [<c009c14c>] (create_empty_buffers+0x0/0x140) from [<c009f378>] (block_read_full_page+0x50/0x340)
[85903.680000] r5 = C058CE60 r4 = 00000000
[85903.680000] [<c009f328>] (block_read_full_page+0x0/0x340) from [<c00a2d78>] (blkdev_readpage+0x18/0x20)
[85903.680000] [<c00a2d60>] (blkdev_readpage+0x0/0x20) from [<c0079ae8>] (read_cache_page+0xb8/0x198)
[85903.680000] [<c0079a30>] (read_cache_page+0x0/0x198) from [<c00d8208>] (read_dev_sector+0x34/0xb0)
[85903.680000] [<c00d81d4>] (read_dev_sector+0x0/0xb0) from [<c00d86d8>] (msdos_partition+0x54/0x5ac)
[85903.680000] r6 = C52B4000 r5 = C52B4000 r4 = C00D8684
[85903.680000] [<c00d8684>] (msdos_partition+0x0/0x5ac) from [<c00d853c>] (rescan_partitions+0x110/0x1f8)
[85903.680000] [<c00d842c>] (rescan_partitions+0x0/0x1f8) from [<c00a3760>] (do_open+0x2e4/0x3f4)
[85903.680000] [<c00a347c>] (do_open+0x0/0x3f4) from [<c00a38f4>] (blkdev_get+0x84/0xa4)
[85903.680000] [<c00a3870>] (blkdev_get+0x0/0xa4) from [<c00d83ac>] (register_disk+0x128/0x1a8)
[85903.680000] r8 = C699B8E0 r7 = C65C4DCC r6 = C34308F8 r5 = C65C4D80
[85903.680000] r4 = C05EF040
[85903.680000] [<c00d8284>] (register_disk+0x0/0x1a8) from [<c01d2b9c>] (add_disk+0x50/0x68)
[85903.680000] r7 = C65C4D80 r6 = 00000001 r5 = C3430890 r4 = C65C4D80
[85903.680000] [<c01d2b4c>] (add_disk+0x0/0x68) from [<c02421d0>] (sd_probe+0x328/0x3b8)
[85903.680000] r4 = C3430890
[85903.680000] [<c0241ea8>] (sd_probe+0x0/0x3b8) from [<c0210cf0>] (driver_probe_device+0x7c/0xcc)
[85903.680000] [<c0210c74>] (driver_probe_device+0x0/0xcc) from [<c0210d50>] (__device_attach+0x10/0x14)
[85903.680000] r7 = C3D27D3C r6 = C3430890 r5 = C0210D40 r4 = 00000000
[85903.680000] [<c0210d40>] (__device_attach+0x0/0x14) from [<c021051c>] (bus_for_each_drv+0x50/0x8c)
[85903.680000] [<c02104cc>] (bus_for_each_drv+0x0/0x8c) from [<c0210db4>] (device_attach+0x60/0x8c)
[85903.680000] r7 = 00000000 r6 = C3430934 r5 = C3430890 r4 = C3430960
[85903.680000] [<c0210d54>] (device_attach+0x0/0x8c) from [<c02101fc>] (bus_attach_device+0x20/0x30)
[85903.680000] r4 = C0452F7C
[85903.680000] [<c02101dc>] (bus_attach_device+0x0/0x30) from [<c020f1fc>] (device_add+0x27c/0x3d0)
[85903.680000] r5 = C3430890 r4 = C3430890
[85903.680000] [<c020ef80>] (device_add+0x0/0x3d0) from [<c023f1c8>] (scsi_sysfs_add_sdev+0x30/0x204)
[85903.680000] [<c023f198>] (scsi_sysfs_add_sdev+0x0/0x204) from [<c023d1d8>] (scsi_probe_and_add_lun+0x714/0x880)
[85903.680000] [<c023cac4>] (scsi_probe_and_add_lun+0x0/0x880) from [<c023da24>] (__scsi_scan_target+0xd0/0x558)
[85903.680000] [<c023d954>] (__scsi_scan_target+0x0/0x558) from [<c023df00>] (scsi_scan_channel+0x54/0x84)
[85903.680000] [<c023deac>] (scsi_scan_channel+0x0/0x84) from [<c023dfc0>] (scsi_scan_host_selected+0x90/0xe8)
[85903.680000] [<c023df30>] (scsi_scan_host_selected+0x0/0xe8) from [<c023e040>] (scsi_scan_host+0x28/0x30)
[85903.680000] [<c023e018>] (scsi_scan_host+0x0/0x30) from [<c0264df8>] (usb_stor_scan_thread+0x13c/0x170)
[85903.680000] [<c0264cbc>] (usb_stor_scan_thread+0x0/0x170) from [<c0063cd8>] (kthread+0xe8/0x128)
[85903.680000] [<c0063bf0>] (kthread+0x0/0x128) from [<c0050618>] (do_exit+0x0/0xa24)
[85903.680000] r7 = 00000000 r6 = 00000000 r5 = 00000000 r4 = 00000000
[85903.680000] Code: e583c010 e5861000 ea000000 e28e701c (e59e3010)
[85903.680000] <6>note: usb-stor-scan[1077] exited with preempt_count 1
Mem: 105144K used, 3724K free, 0K shrd, 72K buff, 74456K cached
CPU: 8.4% usr 4.5% sys 0.0% nic 86.3% idle 0.0% io 0.3% irq 0.1% sirq
Load average: 3.41 3.32 3.29 1/75 1093
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
968 693 root S 152m142.7 0 10.6 av_server.out HD_1080P60 AUDIO 080
693 1 root S 129m121.6 0 1.1 /opt/ipnc/bin/sys_server
1093 980 root R 2140 1.9 0 1.1 top
625 14 root DW< 0 0.0 0 0.2 [mdin340]
979 1 root S 88784 81.2 0 0.0 ./wis-streamer -a
694 1 root S 31696 29.0 0 0.0 /opt/ipnc/bin/boa -c /etc
696 1 root S < 10640 9.7 0 0.0 /mnt/vis.master
717 1 root S 4556 4.1 0 0.0 /usr/sbin/inetd
611 1 root S 4240 3.8 0 0.0 /opt/ipnc/bin/boot_proc
612 1 root S 4240 3.8 0 0.0 /opt/ipnc/bin/beep_proc
735 1 root S 3768 3.4 0 0.0 /lqk/samba/bin/smbd -D
695 1 root S 3164 2.9 0 0.0 /mnt/i2cdbg.server
980 1 root S 2140 1.9 0 0.0 -sh
581 1 root S 2136 1.9 0 0.0 /usr/sbin/telnetd -p 2332
697 1 root S 1788 1.6 0 0.0 /mnt/vis.update
359 1 root S < 1572 1.4 0 0.0 udevd --daemon
1 0 root S 1552 1.4 0 0.0 init [3]
96 14 root SW 0 0.0 0 0.0 [pdflush]
285 14 root SW< 0 0.0 0 0.0 [usb-storage]
97 14 root SW< 0 0.0 0 0.0 [kswapd0]
  • Li Qiankun,
    请问你是录像到本地u盘上,还是网传码流? 如果是前者,usb是否有disable edma?
    是否有尝试过降低DDR的频率,看是否有改善?
  • 我们是本地的,u盘和硬盘(usb转sata)都会出现,usb已经禁止了dma,但是实验没有降低ddr频率。下面是我内核启动的信息,感谢你的回答。这个问题困惑了几天了。
    U-Boot 1.3.4 (Nov 4 2013 - 11:15:46) DM368-IPNC-1.0.1
    I2C: ready
    DRAM: 128 MB
    NAND: NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (Unknown NAND 128MiB 3,3V 8-bit)
    Bad block table found at page 65472, version 0x01
    Bad block table found at page 65408, version 0x01
    128 MiB
    In: serial
    Out: serial
    Err: serial
    ARM Clock :- 432MHz
    DDR Clock :- 340MHz
    Ethernet PHY: GENERIC @ 0x01
    Hit any key to stop autoboot: 0
    Loading from NAND 128MiB 3,3V 8-bit, offset 0x500000
    Image Name: Linux-2.6.18_pro500-davinci_IPNC
    Image Type: ARM Linux Kernel Image (uncompressed)
    Data Size: 2017688 Bytes = 1.9 MB
    Load Address: 80008000
    Entry Point: 80008000
    ## Booting kernel from Legacy Image at 80700000 ...
    Verifying Checksum ... OK
    Loading Kernel Image ... OK
    OK
    Starting kernel ...
    [ 0.000000] Linux version 2.6.18_pro500-davinci_IPNC_DM368_2.6.0-g9fd655d8-dirty (root@fedora9.zow) (gcc version 4.2.0 (MontaVista 4.2.0-16.0.32.0801914 2008-08-30)) #1 PREEMPT Tue Apr 5 15:58:23 CST 2016
    [ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
    [ 0.000000] Machine: DaVinci DM368 IPNC
    [ 0.000000] Memory policy: ECC disabled, Data cache writeback
    [ 0.000000] DaVinci DM0365 variant 0x8
    [ 0.000000] PLL0: fixedrate: 24000000, commonrate: 170000000, vpssrate: 340000000
    [ 0.000000] PLL0: vencrate_sd: 75555555, ddrrate: 340000000 mmcsdrate: 48571428
    [ 0.000000] PLL1: armrate: 432000000, voicerate: 20571428, vencrate_hd: 27000000
    [ 0.000000] CPU0: D VIVT write-back cache
    [ 0.000000] CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
    [ 0.000000] CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
    [ 0.000000] Built 1 zonelists. Total pages: 28672
    [ 0.000000] Kernel command line: mem=112M console=ttyS1,115200n8 root=/dev/mtdblock3 rootfstype=cramfs ip=192.168.1.40:192.168.1.106:192.132.1.1:255.255.255.0::eth0:off
    [ 0.000000] PID hash table entries: 512 (order: 9, 2048 bytes)
    [ 0.000000] Clock event device timer0_0 configured with caps set: 07
    [ 0.000000] Console: colour dummy device 80x30
    [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
    [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
    [ 0.000000] Memory: 112MB = 112MB total
    [ 0.000000] Memory: 108672KB available (3421K code, 1363K data, 184K init)
    [ 0.250000] Security Framework v1.0.0 initialized
    [ 0.250000] Capability LSM initialized
    [ 0.250000] Mount-cache hash table entries: 512
    [ 0.250000] CPU: Testing write buffer coherency: ok
  • 录像崩溃后打印的信息也是和这个类似,如下
    Mem: 106816K used, 2048K free, 0K shrd, 40K buff, 73584K cached
    CPU: 28.5% usr 38.0% sys 0.0% nic 23.8% idle 0.0% io 0.0% irq 9.5% sirq
    Load average: 3.01 2.90 3.13 1/69 830
    830 759 root R 2136 1.9 0 38.0 top
    827 697 root S 37004 33.8 0 19.0 record /mnt/HardDisk/DCIM/12345678
    737 697 root S 149m140.2 0 14.2 av_server.out HD_1080P 60 AUDIO 08
    697 1 root S 130m122.4 0 0.0 /opt/ipnc/bin/sys_server
    761 1 root S 42608 39.0 0 0.0 ./wis-streamer -a
    698 1 root S 32328 29.6 0 0.0 /opt/ipnc/bin/boa -c /etc
    700 1 root S < 10640 9.7 0 0.0 /mnt/vis.master
    758 1 root S 4556 4.1 0 0.0 /usr/sbin/inetd
    615 1 root S 4240 3.8 0 0.0 /opt/ipnc/bin/boot_proc
    616 1 root S 4240 3.8 0 0.0 /opt/ipnc/bin/beep_proc
    779 762 root S 4000 3.6 0 0.0 /lqk/samba/bin/smbd -D
    762 1 root S 3768 3.4 0 0.0 /lqk/samba/bin/smbd -D
    699 1 root S 3164 2.9 0 0.0 /mnt/i2cdbg.server
    759 1 root S 2140 1.9 0 0.0 -sh
    598 1 root S 2136 1.9 0 0.0 /usr/sbin/telnetd -p 2332
    701 1 root S 1788 1.6 0 0.0 /mnt/vis.update
    373 1 root S < 1572 1.4 0 0.0 udevd --daemon
    97 14 root SW 0 0.0 0 0.0 [pdflush]
    288 14 root SW< 0 0.0 0 0.0 [usb-storage]
    # [14620.570000] Unable to handle kernel paging request at virtual address 8b101b7c
    [14620.570000] pgd = c5228000
    [14620.570000] [8b101b7c] *pgd=00000000
    [14620.570000] Internal error: Oops: 5 [#1]
    [14620.570000] Modules linked in: dm365mmap irqk edmak cmemk drv csl m340 i2c
    [14620.570000] CPU: 0
    [14620.570000] PC is at cache_alloc_refill+0x144/0x5dc
    [14620.570000] LR is at 0xc67c0000
    [14620.570000] pc : [<c0096050>] lr : [<c67c0000>] Tainted: GF
    [14620.570000] sp : c3387b40 ip : 36f148a1 fp : c3387b8c
    [14620.570000] r10: c04e4c00 r9 : c3386000 r8 : 00000008
    [14620.570000] r7 : c67c001c r6 : c05e6a00 r5 : c05e0d20 r4 : 00000003
    [14620.570000] r3 : 00000033 r2 : 00000021 r1 : 00000030 r0 : 712506d8
    [14620.570000] Flags: nzCv IRQs off FIQs on Mode SVC_32 Segment user
    [14620.570000] Control: 5317F
    [14620.570000] Table: 85228000 DAC: 00000015
    [14620.570000] Process record (pid: 827, stack limit = 0xc3386258)
    [14620.570000] Stack: (0xc3387b40 to 0xc3388000)
    [14620.570000] 7b40: 00000050 00000000 c05e0d28 c05e0d30 c3387b94 00000050 00000000 c3387bc4
    [14620.570000] 7b60: 00000040 20000013 c04c2888 00000000 00000e00 00000200 c05a9820 00000001
    [14620.570000] 7b80: c3387bac c3387b90 c0095efc c0095f1c c3387bf4 00000000 c010cb68 c05a9820
    [14620.570000] 7ba0: c3387bcc c3387bb0 c009b798 c0095eb4 c007704c c05a9820 00000000 00000000
    [14620.570000] 7bc0: c3387bfc c3387bd0 c009c0bc c009b788 00000000 c05a9820 00000000 00000200
    [14620.570000] 7be0: c05a9820 00001000 00001000 00000000 c3387c14 c3387c00 c009c168 c009c098
    [14620.570000] 7c00: c010cbf0 00000000 c3387c74 c3387c18 c009d430 c009c15c c2bf6080 00001000
    [14620.570000] 7c20: 00189eb8 c182a9f8 c3387c3c fffffe00 00000200 c039a2fc c3387c9c c3387c48
    [14620.570000] 7c40: c007bea0 c007b564 00000042 c010cbf0 00000000 00000000 00001000 c2bf6058
    [14620.570000] 7c60: 00001000 00000000 c3387cdc c3387c78 c009ef78 c009d3c4 c010cbf0 00000042
    [14620.570000] 7c80: c05a9820 c2bf6120 c3386000 00000000 000001ff 00000000 c007ca94 000001ff
    [14620.570000] 7ca0: c010cbf0 00001000 c2bf6080 00000200 c04c1dc8 c032fdc0 c05a9820 c05a9820
    [14620.570000] 7cc0: 00001000 00000000 4225ff1d 00000000 c3387cf4 c3387ce0 c010d574 c009ed98
    [14620.570000] 7ce0: c2bf6058 00000000 c3387d84 c3387cf8 c0078dc8 c010d550 00000002 c3387e00
    [14620.570000] 7d00: 00000000 00001000 c6bb2120 c2bf6120 c032fdc0 c2bf6080 00000000 c3387ee8
    [14620.570000] 7d20: 0013ff15 c3386000 c3387d5c 00000000 00000000 c0553120 c057cc20 c05a2380
    [14620.570000] 7d40: c05adc00 c050d800 c0546560 c0512b20 c05a9820 18387d60 c00b7800 00000000
    [14620.570000] 7d60: 00000000 c3387f70 00000000 00179316 00179316 c6bb2120 c3387dfc c3387d88
    [14620.570000] 7d80: c00795a0 c0078b38 313d7000 00000000 c3387f70 00039401 0013ff15 c3387da8
    [14620.570000] 7da0: c3387f70 c3387ee0 c3387e00 c2bf6120 00000000 00000002 c04b9800 c06c79e0
    [14620.570000] 7dc0: c3387de4 c3387dd0 c00477b0 c00476c4 c06c79e0 00000000 00000000 c3387e44
    [14620.570000] 7de0: c5210700 c3387e00 c2bf6120 c3387f70 c3387ea4 c3387e00 c007974c c0079188
    [14620.570000] 7e00: c0048870 c03277b8 00000000 00000001 ffffffff c6bb2120 00000000 00000000
    [14620.570000] 7e20: 00000000 00000000 c5210700 c3387ea8 00000000 00000000 c3387e5c c5210700
    [14620.570000] 7e40: c0063df8 c3387e44 c3387e44 c04b9800 c3387e84 c3387e60 c0074730 c00418dc
    [14620.570000] 7e60: 00000027 c03909c0 c3387ea8 00010003 c3387eac c3387e80 c00486e4 c0048544
    [14620.570000] 7e80: c0037ba4 c2bf60f4 00000002 c3387ee0 c6bb2120 c2bf6080 c3387edc c3387ea8
    [14620.570000] 7ea0: c00797b4 c00796e0 c00488a4 c00486cc c3387eec c3386000 00000000 00000002
    [14620.570000] 7ec0: 00000001 c6bb2120 c009948c c3387ee0 c3387f4c c3387ee0 c0099d08 c007977c
    [14620.570000] 7ee0: 000e74c0 00000000 42120008 00179316 00000000 c3386000 c3387f24 c05f1000
    [14620.570000] 7f00: c3387f2c c3387f10 c0235f84 c0048bc8 c3387f3c 00010001 c3386000 c05e8d60
    [14620.570000] 7f20: c3387f64 c3387f70 c6bb2120 0000000d 00000002 be80c598 c3386000 00000000
    [14620.570000] 7f40: c3387f6c c3387f50 c0099dfc c0099b9c c3387f70 c04c1d2c c3387f8c 00000002
    [14620.570000] 7f60: c3387fa4 c3387f70 c009a65c c0099da0 312970eb 00000000 00000000 00000000
    [14620.570000] 7f80: c3387fac 00000002 0000000d be80c598 00000092 c0036f88 00000000 c3387fa8
    [14620.570000] 7fa0: c0036f58 c009a5d8 00000002 0000000d 0000000d be80c598 00000002 40402000
    [14620.570000] 7fc0: 00000002 0000000d be80c598 00000092 be80c598 00179316 00179316 42120008
    [14620.570000] 7fe0: 00003078 be80c584 401f744c 4039b698 60000010 0000000d 53447b2c b94287e6
    [14620.570000] Backtrace:
    [14620.570000] [<c0095f0c>] (cache_alloc_refill+0x0/0x5dc) from [<c0095efc>] (kmem_cache_alloc+0x58/0x68)
    [14620.570000] [<c0095ea4>] (kmem_cache_alloc+0x0/0x68) from [<c009b798>] (alloc_buffer_head+0x20/0x74)
    [14620.570000] r4 = C05A9820
    [14620.570000] [<c009b778>] (alloc_buffer_head+0x0/0x74) from [<c009c0bc>] (alloc_page_buffers+0x34/0xc4)
    [14620.570000] r6 = 00000000 r5 = 00000000 r4 = C05A9820
    [14620.570000] [<c009c088>] (alloc_page_buffers+0x0/0xc4) from [<c009c168>] (create_empty_buffers+0x1c/0x140)
    [14620.570000] [<c009c14c>] (create_empty_buffers+0x0/0x140) from [<c009d430>] (__block_prepare_write+0x7c/0x4d8)
    [14620.570000] r5 = 00000000 r4 = C010CBF0
    [14620.570000] [<c009d3b4>] (__block_prepare_write+0x0/0x4d8) from [<c009ef78>] (cont_prepare_write+0x1f0/0x2b0)
    [14620.570000] [<c009ed88>] (cont_prepare_write+0x0/0x2b0) from [<c010d574>] (fat_prepare_write+0x34/0x40)
    [14620.570000] [<c010d540>] (fat_prepare_write+0x0/0x40) from [<c0078dc8>] (generic_file_buffered_write+0x2a0/0x650)
    [14620.570000] [<c0078b28>] (generic_file_buffered_write+0x0/0x650) from [<c00795a0>] (__generic_file_aio_write_nolock+0x428/0x478)
    [14620.570000] [<c0079178>] (__generic_file_aio_write_nolock+0x0/0x478) from [<c007974c>] (__generic_file_write_nolock+0x7c/0x9c)
    [14620.570000] [<c00796d0>] (__generic_file_write_nolock+0x0/0x9c) from [<c00797b4>] (generic_file_writev+0x48/0xbc)
    [14620.570000] r8 = C2BF6080 r7 = C6BB2120 r6 = C3387EE0 r5 = 00000002
    [14620.570000] r4 = C2BF60F4
    [14620.570000] [<c007976c>] (generic_file_writev+0x0/0xbc) from [<c0099d08>] (do_readv_writev+0x17c/0x204)
    [14620.570000] [<c0099b8c>] (do_readv_writev+0x0/0x204) from [<c0099dfc>] (vfs_writev+0x6c/0x7c)
    [14620.570000] [<c0099d90>] (vfs_writev+0x0/0x7c) from [<c009a65c>] (sys_writev+0x94/0x11c)
    [14620.570000] r4 = 00000002
    [14620.570000] [<c009a5c8>] (sys_writev+0x0/0x11c) from [<c0036f58>] (__sys_trace_return+0x0/0x28)
    [14620.570000] r8 = C0036F88 r7 = 00000092 r6 = BE80C598 r5 = 0000000D
    [14620.570000] Code: e59e200c e5963000 e02c2190 e58e4010 (e7972100)
    [14620.570000] <6>note: record[827] exited with preempt_count 1
    REC already exit ret = 99
    Run a[14622.470000] Unable to handle kernel paging request at virtual address 02a93325
    t Sat Oct 24 17:[14622.490000] pgd = c6888000
    19:56 2015
    [14622.490000] [02a93325] *pgd=00000000
    [14622.490000] Internal error: Oops: 801 [#2]
    [14622.490000] Modules linked in: dm365mmap irqk edmak cmemk drv csl m340 i2c
    [14622.490000] CPU: 0
    [14622.490000] PC is at alloc_page_buffers+0x40/0xc4
    [14622.490000] LR is at alloc_buffer_head+0x4c/0x74
    [14622.490000] pc : [<c009c0c8>] lr : [<c009b7c4>] Tainted: GF
    [14622.490000] sp : c6b75b90 ip : c6b75b70 fp : c6b75bbc
    [14622.490000] r10: 00000000 r9 : c059d240 r8 : 00000200
    [14622.490000] r7 : 00000e00 r6 : 00000000 r5 : 00000000 r4 : 02a93321
    [14622.490000] r3 : ffffffff r2 : 00000001 r1 : c04c2888 r0 : 02a93321
    [14622.490000] Flags: nzCv IRQs on FIQs on Mode SVC_32 Segment user
    [14622.490000] Control: 5317F
    [14622.490000] Table: 86888000 DAC: 00000015
    [14622.490000] Process sys_server (pid: 705, stack limit = 0xc6b74258)
    [14622.490000] Stack: (0xc6b75b90 to 0xc6b76000)
    [14622.490000] 5b80: c6b75bdc c059d240 00004d68 00000200
    [14622.490000] 5ba0: c6b74000 000009ad 00000000 c05f0a00 c6b75bf4 c6b75bc0 c009c650 c009c098
    [14622.490000] 5bc0: c6b74000 00004d6e c6b75bfc c65ece00 c6b75c94 00004d6e c039db08 00000124
    [14622.490000] 5be0: c66a3340 c6b75c94 c6b75c0c c6b75bf8 c009e668 c009c4f8 c65ece00 c6b75c94
    [14622.490000] 5c00: c6b75c34 c6b75c10 c010b82c c009e668 c6b75c4c c6b75c94 c6b75c94 00000001
    [14622.490000] 5c20: c039db08 c65ece00 c6b75c64 c6b75c38 c010b0c4 c010b7e8 00004d6e 00000124
    [14622.490000] 5c40: c6b75c94 0026a749 0026a749 c071c000 c65ece00 c6b75c74 c6b75cdc c6b75c68
    [14622.490000] 5c60: c010b310 c010af44 c039db08 c071c028 c00b4bdc c01db06c c6b74000 c64d73d0
    [14622.490000] 5c80: c65b0998 c64d71b0 c6b75f28 c65bdf38 c6b75df4 0026a749 00000000 c00b4bb4
    [14622.490000] 5ca0: 00000000 00000000 00000000 00000000 00000001 0026a749 0026a749 c66a3340
    [14622.490000] 5cc0: c66a3308 0000000f 00000000 00000000 c6b75d3c c6b75ce0 c010c364 c010b2b4
    [14622.490000] 5ce0: c6b75cfc c6b75cf0 c005de94 c65ece00 c6b75d1c ffffffff ffffffff 00000000
    [14622.490000] 5d00: 00000000 c66a3340 00000000 c66a33e0 c6b75d3c 00000000 00000000 00000000
    [14622.490000] 5d20: 00000000 c66a3340 00000000 c66a33e0 c6b75d74 c6b75d40 c00875f4 c010c0f0
    [14622.490000] 5d40: 00000000 00000000 00000001 c6b75d58 00000000 c66a3340 0000008b 00000000
    [14622.490000] 5d60: c6b75e20 00000068 c6b75dac c6b75d78 c00b8098 c00874a0 00000000 00000000
    [14622.490000] 5d80: c6b75ddc c6b75d90 00000000 00000000 c66a3340 c6b75e20 0000008b 00000000
    [14622.490000] 5da0: c6b75dec c6b75db0 c010c080 c00b8024 c04c0050 c04c003c c071c000 000081ed
    [14622.490000] 5dc0: c6b75ddc c6b75e20 00000000 00000068 c66a3340 c5a94138 c6b74000 00000008
    [14622.490000] 5de0: c6b75e1c c6b75df0 c00b82f4 c010bf14 562bbdbc 00000000 00000000 00000000
    [14622.490000] 5e00: c5a94138 00000006 00000000 c5a94138 c6b75e74 c6b75e20 c00980c8 c00b81a8
    [14622.490000] 5e20: 00000068 c5d08558 c6b75e6c c66a3340 00000000 00000000 562bbdbc 00000000
    [14622.490000] 5e40: 562bbdbc 00000000 562bbdbc 00000000 00020243 c6b75f08 c6b75e74 c66a3340
    [14622.490000] 5e60: 00020243 c6b75f08 c6b75ea4 c6b75e78 c00aae50 c0098074 00000060 00000000
    [14622.490000] 5e80: 00000000 c5d08558 c6b75f08 c6b74000 ffffff9c 00020243 c6b75efc c6b75ea8
    [14622.490000] 5ea0: c00ad9a4 c00aac7c 00020243 000001b6 c003dd38 00000000 00000000 000001b6
    [14622.490000] 5ec0: 00000006 00000000 c05eaaa0 c5a94138 00000000 00020242 c6b75f08 c642f000
    [14622.490000] 5ee0: 000001b6 ffffff9c c6b74000 00000000 c6b75f6c c6b75f00 c0097d0c c00ad730
    [14622.490000] 5f00: c6b75f08 00000000 c5a94138 c05eaaa0 b47ddf8b 00000010 c642f026 00000300
    [14622.490000] 5f20: 00000000 00000000 c06bba60 ffffff9c c6b74000 00000000 c6b75f6c c6b75f48
    [14622.490000] 5f40: c00978ec c00b8610 c00aaf20 00020243 000001b6 c6c30780 00020242 0000000f
    [14622.490000] 5f60: c6b75f94 c6b75f70 c0097d7c c0097cf0 c6b75fa4 0009e638 00000000 0009e638
    [14622.490000] 5f80: 00000005 c0036f88 c6b75fa4 c6b75f98 c0097e4c c0097d38 00000000 c6b75fa8
    [14622.490000] 5fa0: c0036f58 c0097e38 0009e638 00000000 41693b70 00020242 000001b6 000001b6
    [14622.490000] 5fc0: 0009e638 00000000 0009e638 00000005 4059e000 003d0f00 00000002 41693b4c
    [14622.490000] 5fe0: 00000000 41693ae8 4054aab4 40530384 60000010 41693b70 00000020 00002002
    [14622.490000] Backtrace:
    [14622.490000] [<c009c088>] (alloc_page_buffers+0x0/0xc4) from [<c009c650>] (__getblk+0x168/0x25c)
    [14622.490000] [<c009c4e8>] (__getblk+0x0/0x25c) from [<c009e668>] (__bread+0x10/0xd4)
    [14622.490000] [<c009e658>] (__bread+0x0/0xd4) from [<c010b82c>] (fat_ent_bread+0x54/0xa4)
    [14622.490000] r5 = C6B75C94 r4 = C65ECE00
    [14622.490000] [<c010b7d8>] (fat_ent_bread+0x0/0xa4) from [<c010b0c4>] (fat_ent_read+0x190/0x1b0)
    [14622.490000] r8 = C65ECE00 r7 = C039DB08 r6 = 00000001 r5 = C6B75C94
    [14622.490000] r4 = C6B75C94
    [14622.490000] [<c010af34>] (fat_ent_read+0x0/0x1b0) from [<c010b310>] (fat_free_clusters+0x6c/0x218)
    [14622.490000] r8 = C6B75C74 r7 = C65ECE00 r6 = C071C000 r5 = 0026A749
    [14622.490000] r4 = 0026A749
    [14622.490000] [<c010b2a4>] (fat_free_clusters+0x0/0x218) from [<c010c364>] (fat_truncate+0x284/0x29c)
    [14622.490000] [<c010c0e0>] (fat_truncate+0x0/0x29c) from [<c00875f4>] (vmtruncate+0x164/0x198)
    [14622.490000] [<c0087490>] (vmtruncate+0x0/0x198) from [<c00b8098>] (inode_setattr+0x84/0x184)
    [14622.490000] [<c00b8014>] (inode_setattr+0x0/0x184) from [<c010c080>] (fat_notify_change+0x17c/0x1dc)
    [14622.490000] [<c010bf04>] (fat_notify_change+0x0/0x1dc) from [<c00b82f4>] (notify_change+0x15c/0x260)
    [14622.490000] [<c00b8198>] (notify_change+0x0/0x260) from [<c00980c8>] (do_truncate+0x64/0x80)
    [14622.490000] [<c0098064>] (do_truncate+0x0/0x80) from [<c00aae50>] (may_open+0x1e4/0x264)
    [14622.490000] r6 = C6B75F08 r5 = 00020243 r4 = C66A3340
    [14622.490000] [<c00aac6c>] (may_open+0x0/0x264) from [<c00ad9a4>] (open_namei+0x284/0x744)
    [14622.490000] [<c00ad720>] (open_namei+0x0/0x744) from [<c0097d0c>] (do_filp_open+0x2c/0x48)
    [14622.490000] [<c0097ce0>] (do_filp_open+0x0/0x48) from [<c0097d7c>] (do_sys_open+0x54/0xec)
    [14622.490000] r5 = 0000000F r4 = 00020242
    [14622.490000] [<c0097d28>] (do_sys_open+0x0/0xec) from [<c0097e4c>] (sys_open+0x24/0x28)
    [14622.490000] r8 = C0036F88 r7 = 00000005 r6 = 0009E638 r5 = 00000000
    [14622.490000] r4 = 0009E638
    [14622.490000] [<c0097e28>] (sys_open+0x0/0x28) from [<c0036f58>] (__sys_trace_return+0x0/0x28)
    [14622.490000] Code: ebfffdae e2504000 0a000010 e3e03000 (e5845004)
    [14622.490000] <1>Unable to handle kernel paging request at virtual address 8b101b7c
    [14653.190000] pgd = c0004000
    [14653.190000] [8b101b7c] *pgd=00000000
    [14653.190000] Internal error: Oops: 5 [#3]
    [14653.190000] Modules linked in: dm365mmap irqk edmak cmemk drv csl m340 i2c
    [14653.190000] CPU: 0
    [14653.190000] PC is at cache_alloc_refill+0x144/0x5dc
    [14653.190000] LR is at 0xc67c0000
    [14653.190000] pc : [<c0096050>] lr : [<c67c0000>] Tainted: GF
    [14653.190000] sp : c0741d28 ip : 36f148a1 fp : c0741d74
    [14653.190000] r10: c04e4c00 r9 : c0740000 r8 : 0000000f
    [14653.190000] r7 : c67c001c r6 : c05e6a00 r5 : c05e0d20 r4 : 00000004
    [14653.190000] r3 : 00000000 r2 : 00000021 r1 : 00000030 r0 : 712506d8
    [14653.190000] Flags: nzCv IRQs off FIQs on Mode SVC_32 Segment kernel
    [14653.190000] Control: 5317F
    [14653.190000] Table: 865E4000 DAC: 00000017
    [14653.190000] Process pdflush (pid: 97, stack limit = 0xc0740258)
    [14653.190000] Stack: (0xc0741d28 to 0xc0742000)
    [14653.190000] 1d20: 00000050 00000000 c05e0d28 c05e0d30 c0741d7c 00000050
    [14653.190000] 1d40: c039a2d0 c072f920 c0740000 20000013 c04c2888 00000000 00000e00 00000200
    [14653.190000] 1d60: c05b1be0 00000000 c0741d94 c0741d78 c0095efc c0095f1c c0077550 00000000
    [14653.190000] 1d80: 00000000 c05b1be0 c0741db4 c0741d98 c009b798 c0095eb4 c0077680 c05b1be0
    [14653.190000] 1da0: 00000000 00000000 c0741de4 c0741db8 c009c0bc c009b788 c00c3228 c05b1be0
    [14653.190000] 1dc0: 000e8f40 00000200 c0740000 0001d1e8 00000000 c05f0a00 c0741e1c c0741de8
    [14653.190000] 1de0: c009c650 c009c098 ffffffff 000e8f40 c0740000 00e8f404 00000000 c0740000
    [14653.190000] 1e00: c66a3340 c66a3308 00000000 c65ece00 c0741e34 c0741e20 c009e668 c009c4f8
    [14653.190000] 1e20: 00e8f404 00000000 c0741e7c c0741e38 c010c798 c009e668 c66a3308 00000000
    [14653.190000] 1e40: 00000000 c071c000 c0741e64 c0741e58 c010ccd4 00000007 c65ece00 c66a33e0
    [14653.190000] 1e60: c66a3340 00000000 00000000 c0741f30 c0741ecc c0741e80 c00c1574 c010c714
    [14653.190000] 1e80: c00369e4 c0037b70 00000000 c65ece80 0015dab7 00000000 c66a3340 c65ece00
    [14653.190000] 1ea0: c0add0f0 c66a3340 c65ece00 c0add0f0 c0741f30 c0740000 c65ece78 00000000
    [14653.190000] 1ec0: c0741f04 c0741ed0 c00c19c0 c00c1380 c65ece80 0015e6b7 c039a390 c65ece00
    [14653.190000] 1ee0: c0740000 c65ece40 c0741f30 c039aa2c 00000002 00000000 c0741f2c c0741f08
    [14653.190000] 1f00: c00c1eac c00c17dc c0741f2c 00000460 0015e77f 00000400 c0741f30 c0399128
    [14653.190000] 1f20: c0741f84 c0741f30 c007dd7c c00c1e08 00000000 00000000 c0741f64 00000400
    [14653.190000] 1f40: 00000000 00000000 00000000 00000000 00000000 00000000 00000025 00000000
    [14653.190000] 1f60: c0741f84 0015daff c0740000 c039a3c4 c0741f94 c04c1e24 c0741fcc c0741f88
    [14653.190000] 1f80: c007e68c c007dcd4 c072f920 c007dcc4 00000000 c0741f94 c0741f94 0015e5ef
    [14653.190000] 1fa0: 00000000 00000000 c0740000 c007e510 c05fdf20 00000000 00000000 00000000
    [14653.190000] 1fc0: c0741ff4 c0741fd0 c0063cd8 c007e520 ffffffff ffffffff 00000000 00000000
    [14653.190000] 1fe0: 00000000 00000000 00000000 c0741ff8 c0050618 c0063c00 c1666040 a95e7d87
    [14653.190000] Backtrace:
    [14653.190000] [<c0095f0c>] (cache_alloc_refill+0x0/0x5dc) from [<c0095efc>] (kmem_cache_alloc+0x58/0x68)
    [14653.190000] [<c0095ea4>] (kmem_cache_alloc+0x0/0x68) from [<c009b798>] (alloc_buffer_head+0x20/0x74)
    [14653.190000] r4 = C05B1BE0
    [14653.190000] [<c009b778>] (alloc_buffer_head+0x0/0x74) from [<c009c0bc>] (alloc_page_buffers+0x34/0xc4)
    [14653.190000] r6 = 00000000 r5 = 00000000 r4 = C05B1BE0
    [14653.190000] [<c009c088>] (alloc_page_buffers+0x0/0xc4) from [<c009c650>] (__getblk+0x168/0x25c)
    [14653.190000] [<c009c4e8>] (__getblk+0x0/0x25c) from [<c009e668>] (__bread+0x10/0xd4)
    [14653.190000] [<c009e658>] (__bread+0x0/0xd4) from [<c010c798>] (fat_write_inode+0x94/0x23c)
    [14653.190000] r5 = 00000000 r4 = 00E8F404
    [14653.190000] [<c010c704>] (fat_write_inode+0x0/0x23c) from [<c00c1574>] (__writeback_single_inode+0x204/0x384)
    [14653.190000] [<c00c1370>] (__writeback_single_inode+0x0/0x384) from [<c00c19c0>] (sync_sb_inodes+0x1f4/0x2e0)
    [14653.190000] [<c00c17cc>] (sync_sb_inodes+0x0/0x2e0) from [<c00c1eac>] (writeback_inodes+0xb4/0x138)
    [14653.190000] [<c00c1df8>] (writeback_inodes+0x0/0x138) from [<c007dd7c>] (wb_kupdate+0xb8/0x140)
    [14653.190000] r8 = C0399128 r7 = C0741F30 r6 = 00000400 r5 = 0015E77F
    [14653.190000] r4 = 00000460
    [14653.190000] [<c007dcc4>] (wb_kupdate+0x0/0x140) from [<c007e68c>] (pdflush+0x17c/0x25c)
    [14653.190000] r7 = C04C1E24 r6 = C0741F94 r5 = C039A3C4 r4 = C0740000
    [14653.190000] [<c007e510>] (pdflush+0x0/0x25c) from [<c0063cd8>] (kthread+0xe8/0x128)
    [14653.190000] [<c0063bf0>] (kthread+0x0/0x128) from [<c0050618>] (do_exit+0x0/0xa24)
    [14653.190000] r7 = 00000000 r6 = 00000000 r5 = 00000000 r4 = 00000000
    [14653.190000] Code: e59e200c e5963000 e02c2190 e58e4010 (e7972100)
    [14653.190000] <6>note: pdflush[97] exited with preempt_count 1
  • n你好,你有什么建议没
  • Li Qiankun,
    DDR降频试验一下,看看是否会是DDR不稳定的问题导致的。
    DDR的时序参数请参下面链接工具配置:
    【TI FAE 分享】TI DM36x DDR2 寄存器配置表
    http://www.deyisupport.com/question_answer/dsp_arm/davinci_digital_media_processors/f/39/t/69143.aspx
