AM3354 安卓启动报错
各位好,小弟基于 processors.wiki.ti.com/.../TI-Android-JB-4.2.2-DevKit-4.1.1_DeveloperGuide SD 卡进行启动。 SD 卡,S使用的是 SANDISK 16GB SDHC CLASS4。系统顺利启动并成功加载内核,但是在系统起来之后,会一直报错 init: untracked pid XXX exited 的错误。系统完整启动日志如下 :
[09:58:20]U-Boot SPL 2014.10 (Oct 09 2016 - 16:09:15)
[09:58:20]DDR3 frequense :: 303 MHz
[09:58:22]
[09:58:22]
[09:58:22]U-Boot 2014.10 (Oct 09 2016 - 16:09:15)
[09:58:22]
[09:58:22] Watchdog enabled
[09:58:22]I2C: ready
[09:58:22]DRAM: 512 MiB
[09:58:29]NAND: 1024 MiB
[09:58:29]MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
[09:58:30]Net: Phy not found
[09:58:30]cpsw, usb_ether
[09:58:31]Hit any key to stop autoboot: 0
[09:58:31]switch to partitions #0, OK
[09:58:31]mmc0 is current device
[09:58:31]SD/MMC found on device 0
[09:58:31]** Unable to read file boot.scr **
[09:58:31]214 bytes read in 2 ms (104.5 KiB/s)
[09:58:31]Loaded environment from uEnv.txt
[09:58:31]Importing environment from mmc ...
[09:58:31]Running uenvcmd ...
[09:58:31]4203816 bytes read in 243 ms (16.5 MiB/s)
[09:58:31]## Booting kernel from Legacy Image at 81000000 ...
[09:58:31] Image Name: Linux-3.2.0-00244-gcf99001-dirty
[09:58:31] Created: 2016-11-11 1:42:17 UTC
[09:58:31] Image Type: ARM Linux Kernel Image (uncompressed)
[09:58:31] Data Size: 4203752 Bytes = 4 MiB
[09:58:31] Load Address: 80008000
[09:58:31] Entry Point: 80008000
[09:58:31] Verifying Checksum ... OK
[09:58:31] Loading Kernel Image ... OK
[09:58:31]
[09:58:31]Starting kernel ...
[09:58:31]
[09:58:32]Uncompressing Linux... done, booting the kernel.
[09:58:32][ 0.000000] Linux version 3.2.0-00244-gcf99001-dirty (carlos@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #14 Fri Nov 11 09:42:12 CST 2016
[09:58:32][ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[09:58:32][ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[09:58:32][ 0.000000] Machine: am335xevm
[09:58:32][ 0.000000] Memory policy: ECC disabled, Data cache writeback
[09:58:32][ 0.000000] AM335X ES2.1 (sgx neon )
[09:58:32][ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[09:58:32][ 0.000000] Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait init=/init ip=off
[09:58:32][ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[09:58:32][ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[09:58:32][ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[09:58:32][ 0.000000] Memory: 256MB = 256MB total
[09:58:32][ 0.000000] Memory: 249952k/249952k available, 12192k reserved, 0K highmem
[09:58:32][ 0.000000] Virtual kernel memory layout:
[09:58:32][ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[09:58:32][ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[09:58:32][ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[09:58:32][ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[09:58:32][ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[09:58:32][ 0.000000] .text : 0xc0008000 - 0xc0796000 (7736 kB)
[09:58:32][ 0.000000] .init : 0xc0796000 - 0xc07ec000 ( 344 kB)
[09:58:32][ 0.000000] .data : 0xc07ec000 - 0xc08536b0 ( 414 kB)
[09:58:32][ 0.000000] .bss : 0xc08536d4 - 0xc09ab3d0 (1376 kB)
[09:58:32][ 0.000000] NR_IRQS:396
[09:58:32][ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[09:58:32][ 0.000000] Total of 128 interrupts on 1 active controller
[09:58:32][ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[09:58:32][ 0.000000] omap_dm_timer_switch_src: Switching to HW default clocksource(sys_clkin_ck) for timer1, this may impact timekeeping in low power state
[09:58:32][ 0.000000] OMAP clocksource: GPTIMER1 at 24000000 Hz
[09:58:32][ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[09:58:32][ 0.000000] Console: colour dummy device 80x30
[09:58:32][ 0.000183] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[09:58:32][ 0.087693] pid_max: default: 32768 minimum: 301
[09:58:32][ 0.087798] Security Framework initialized
[09:58:32][ 0.087852] Mount-cache hash table entries: 512
[09:58:32][ 0.088209] CPU: Testing write buffer coherency: ok
[09:58:32][ 0.088267] ftrace: allocating 22226 entries in 66 pages
[09:58:32][ 0.144565] omap_hwmod: pruss: failed to hardreset
[09:58:32][ 0.145282] print_constraints: dummy:
[09:58:32][ 0.145471] NET: Registered protocol family 16
[09:58:33][ 0.146388] OMAP GPIO hardware version 0.1
[09:58:33][ 0.147244] omap_mux_init: Add partition: #1: core, flags: 0
[09:58:33][ 0.148367] enter evm_nand_init
[09:58:33][ 0.148484] enter omap_init_gpmc
[09:58:33][ 0.148765] davinci-mcasp.0: alias fck already exists
[09:58:33][ 0.148975] omap_hsmmc.0: alias fck already exists
[09:58:33][ 0.149685] omap2_mcspi.1: alias fck already exists
[09:58:33][ 0.149779] omap2_mcspi.2: alias fck already exists
[09:58:33][ 0.149893] edma.0: alias fck already exists
[09:58:33][ 0.149908] edma.0: alias fck already exists
[09:58:33][ 0.149921] edma.0: alias fck already exists
[09:58:33][ 0.157845] bio: create slab <bio-0> at 0
[09:58:33][ 0.158680] SCSI subsystem initialized
[09:58:33][ 0.159407] usbcore: registered new interface driver usbfs
[09:58:33][ 0.159501] usbcore: registered new interface driver hub
[09:58:33][ 0.159616] usbcore: registered new device driver usb
[09:58:33][ 0.159874] registerd cppi-dma Intr @ IRQ 17
[09:58:33][ 0.159884] Cppi41 Init Done Qmgr-base(d087a000) dma-base(d0878000)
[09:58:33][ 0.159892] Cppi41 Init Done
[09:58:33][ 0.159917] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[09:58:33][ 0.160052] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[09:58:33][ 0.160586] Advanced Linux Sound Architecture Driver Version 1.0.24.
[09:58:33][ 0.161044] Bluetooth: Core ver 2.16
[09:58:33][ 0.161108] NET: Registered protocol family 31
[09:58:33][ 0.161116] Bluetooth: HCI device and connection manager initialized
[09:58:33][ 0.161128] Bluetooth: HCI socket layer initialized
[09:58:33][ 0.161137] Bluetooth: L2CAP socket layer initialized
[09:58:33][ 0.161158] Bluetooth: SCO socket layer initialized
[09:58:33][ 0.161314] Switching to clocksource gp timer
[09:58:33][ 0.175875] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[09:58:33][ 0.176072] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[09:58:33][ 0.176233] MUSB0 controller's USBSS revision = 4ea20800
[09:58:33][ 0.176259] musb0: Enabled SW babble control
[09:58:33][ 0.177016] musb-hdrc musb-hdrc.0: USB OTG mode controller at d083c000 using DMA, IRQ 18
[09:58:33][ 0.177235] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[09:58:33][ 0.177380] MUSB1 controller's USBSS revision = 4ea20800
[09:58:33][ 0.177400] musb1: Enabled SW babble control
[09:58:33][ 0.177764] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[09:58:33][ 0.177849] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[09:58:33][ 0.177982] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[09:58:33][ 0.177993] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[09:58:33][ 0.178003] usb usb1: Product: MUSB HDRC host driver
[09:58:33][ 0.178012] usb usb1: Manufacturer: Linux 3.2.0-00244-gcf99001-dirty musb-hcd
[09:58:33][ 0.178021] usb usb1: SerialNumber: musb-hdrc.1
[09:58:33][ 0.178428] hub 1-0:1.0: USB hub found
[09:58:33][ 0.178451] hub 1-0:1.0: 1 port detected
[09:58:33][ 0.178764] musb-hdrc musb-hdrc.1: USB Host mode controller at d083e800 using DMA, IRQ 19
[09:58:33][ 0.179073] NET: Registered protocol family 2
[09:58:33][ 0.179252] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[09:58:33][ 0.179587] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[09:58:33][ 0.179700] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[09:58:33][ 0.179769] TCP: Hash tables configured (established 8192 bind 8192)
[09:58:33][ 0.179779] TCP reno registered
[09:58:33][ 0.179794] UDP hash table entries: 256 (order: 0, 4096 bytes)
[09:58:33][ 0.179810] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[09:58:33][ 0.179973] NET: Registered protocol family 1
[09:58:33][ 0.180210] RPC: Registered named UNIX socket transport module.
[09:58:33][ 0.180220] RPC: Registered udp transport module.
[09:58:33][ 0.180227] RPC: Registered tcp transport module.
[09:58:33][ 0.180234] RPC: Registered tcp NFSv4.1 backchannel transport module.
[09:58:33][ 0.180459] NetWinder Floating Point Emulator V0.97 (double precision)
[09:58:33][ 0.180604] enter gpmc_probe
[09:58:33][ 0.180659] omap-gpmc omap-gpmc: GPMC revision 6.0
[09:58:33][ 0.180671] enter gpmc_nand_init
[09:58:33][ 0.180678] Registering NAND on CS0
[09:58:33][ 0.268502] ashmem: initialized
[09:58:33][ 0.268718] VFS: Disk quotas dquot_6.5.2
[09:58:33][ 0.268769] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[09:58:33][ 0.269485] fuse init (API version 7.17)
[09:58:33][ 0.269698] msgmni has been set to 488
[09:58:33][ 0.270544] io scheduler noop registered
[09:58:33][ 0.270555] io scheduler deadline registered
[09:58:33][ 0.270615] io scheduler cfq registered (default)
[09:58:33][ 0.271571] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[09:58:33][ 0.918670] console [ttyO0] enabled
[09:58:33][ 0.922758] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[09:58:33][ 0.930358] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[09:58:33][ 0.937995] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[09:58:33][ 0.945609] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[09:58:33][ 0.953212] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[09:58:33][ 0.960928] [drm] Initialized drm 1.1.0 20060810
[09:58:33][ 0.970187] brd: module loaded
[09:58:33][ 0.975880] loop: module loaded
[09:58:33][ 0.979313] i2c-core: driver [tsl2550] using legacy suspend method
[09:58:33][ 0.985822] i2c-core: driver [tsl2550] using legacy resume method
[09:58:33][ 0.992275] (hci_tty): inside hci_tty_init
[09:58:33][ 0.996673] (hci_tty): allocated 251, 0
[09:58:33][ 1.000774] NFC Driver for TI WiLink
[09:58:33][ 1.005010] mtdoops: mtd device (mtddev=name/number) must be supplied
[09:58:33][ 1.012196] omap2-nand driver initializing
[09:58:33][ 1.016523] enter omap_nand_probe
[09:58:33][ 1.020333] ONFI flash detected
[09:58:33][ 1.023765] ONFI param page 0 valid
[09:58:33][ 1.027422] NAND device: Manufacturer ID: 0xc2, Chip ID: 0xd3 (Unknown MX60LF8G18AC)
[09:58:33][ 1.036098] Creating 8 MTD partitions on "omap2-nand.0":
[09:58:33][ 1.041701] 0x000000000000-0x000000020000 : "SPL"
[09:58:33][ 1.047416] 0x000000020000-0x000000040000 : "SPL.backup1"
[09:58:33][ 1.053766] 0x000000040000-0x000000060000 : "SPL.backup2"
[09:58:33][ 1.060071] 0x000000060000-0x000000080000 : "SPL.backup3"
[09:58:33][ 1.066591] 0x000000080000-0x000000260000 : "U-Boot"
[09:58:33][ 1.073253] 0x000000260000-0x000000280000 : "U-Boot Env"
[09:58:33][ 1.079517] 0x000000280000-0x000000780000 : "Kernel"
[09:58:33][ 1.087379] 0x000000780000-0x000020000000 : "File System"
[09:58:33][ 1.301154] CAN device driver interface
[09:58:33][ 1.305198] CAN bus driver for Bosch D_CAN controller 1.0
[09:58:33][ 1.351374] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[09:58:33][ 1.357839] davinci_mdio davinci_mdio.0: no live phy, scanning all
[09:58:33][ 1.364517] davinci_mdio: probe of davinci_mdio.0 failed with error -5
[09:58:33][ 1.371396] PPP generic driver version 2.4.2
[09:58:33][ 1.376003] PPP BSD Compression module registered
[09:58:33][ 1.380917] PPP Deflate Compression module registered
[09:58:33][ 1.386318] usbcore: registered new interface driver cdc_ether
[09:58:33][ 1.392471] usbcore: registered new interface driver cdc_eem
[09:58:33][ 1.398427] usbcore: registered new interface driver dm9601
[09:58:33][ 1.404300] usbcore: registered new interface driver cdc_subset
[09:58:33][ 1.410525] cdc_ncm: 04-Aug-2011
[09:58:33][ 1.413951] usbcore: registered new interface driver cdc_ncm
[09:58:33][ 1.419945] usbcore: registered new interface driver cdc_acm
[09:58:33][ 1.425872] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[09:58:33][ 1.434246] Initializing USB Mass Storage driver...
[09:58:33][ 1.439437] usbcore: registered new interface driver usb-storage
[09:58:33][ 1.445725] USB Mass Storage support registered.
[09:58:33][ 1.450666] usbcore: registered new interface driver usbserial
[09:58:33][ 1.456820] USB Serial support registered for generic
[09:58:34][ 1.621356] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[09:58:34][ 1.761651] usb 1-1: New USB device found, idVendor=0bda, idProduct=8179
[09:58:34][ 1.768660] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[09:58:34][ 1.776130] usb 1-1: Product: 802.11n NIC
[09:58:34][ 1.780317] usb 1-1: Manufacturer: Realtek
[09:58:34][ 1.784601] usb 1-1: SerialNumber: 38A28CC4B248
[09:58:34][ 1.790338] usbcore: registered new interface driver usbserial_generic
[09:58:34][ 1.797193] usbserial: USB Serial Driver core
[09:58:34][ 1.801799] USB Serial support registered for GSM modem (1-port)
[09:58:34][ 1.808244] usbcore: registered new interface driver option
[09:58:34][ 1.814084] option: v0.7.2:USB Driver for GSM modems
[09:58:34][ 1.820662] gadget: Mass Storage Function, version: 2009/09/11
[09:58:34][ 1.826891] gadget: Number of LUNs=1
[09:58:34][ 1.830716] lun0: LUN: removable file: (no medium)
[09:58:34][ 1.836017] gadget: android_usb ready
[09:58:34][ 1.839945] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[09:58:34][ 1.845565] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[09:58:34][ 1.853388] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[09:58:34][ 1.860484] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[09:58:34][ 1.868046] usb usb2: Product: MUSB HDRC host driver
[09:58:34][ 1.873239] usb usb2: Manufacturer: Linux 3.2.0-00244-gcf99001-dirty musb-hcd
[09:58:34][ 1.880696] usb usb2: SerialNumber: musb-hdrc.0
[09:58:34][ 1.885837] hub 2-0:1.0: USB hub found
[09:58:34][ 1.889766] hub 2-0:1.0: 1 port detected
[09:58:34][ 1.894413] mousedev: PS/2 mouse device common for all mice
[09:58:34][ 1.901134] using rtc device, am33xx-rtc, for alarms
[09:58:34][ 1.906241] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as rtc0
[09:58:34][ 1.913469] am33xx-rtc: already running
[09:58:34][ 1.917555] i2c /dev entries driver
[09:58:34][ 1.921236] Linux video capture interface: v2.00
[09:58:34][ 1.926298] usbcore: registered new interface driver uvcvideo
[09:58:34][ 1.932321] USB Video Class driver (1.1.1)
[09:58:34][ 1.937305] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[09:58:34][ 1.943821] device-mapper: uevent: version 1.0.3
[09:58:34][ 1.948780] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[09:58:34][ 1.957630] Bluetooth: HCI UART driver ver 2.2
[09:58:34][ 1.962284] Bluetooth: HCI H4 protocol initialized
[09:58:34][ 1.967288] Bluetooth: HCILL protocol initialized
[09:58:34][ 1.972210] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[09:58:34][ 1.978906] _regulator_get: deviceless supply vdd_mpu not found, using dummy regulator
[09:58:34][ 1.987398] cpuidle: using governor ladder
[09:58:34][ 1.991811] cpuidle: using governor menu
[09:58:34][ 1.998015] usbcore: registered new interface driver usbhid
[09:58:34][ 2.003890] usbhid: USB HID core driver
[09:58:34][ 2.008310] logger: created 256K log 'log_main'
[09:58:34][ 2.013152] logger: created 256K log 'log_events'
[09:58:34][ 2.018142] logger: created 256K log 'log_radio'
[09:58:34][ 2.023059] logger: created 256K log 'log_system'
[09:58:34][ 2.028427] usbcore: registered new interface driver snd-usb-audio
[09:58:34][ 2.036745] asoc: am335x-hdmi-hifi <-> davinci-mcasp.0 mapping ok
[09:58:34][ 2.043695] ALSA device list:
[09:58:34][ 2.046797] #0: AM335X BONE
[09:58:34][ 2.049893] oprofile: hardware counters not available
[09:58:34][ 2.055193] oprofile: using timer interrupt.
[09:58:34][ 2.059809] Netfilter messages via NETLINK v0.30.
[09:58:34][ 2.064852] nf_conntrack version 0.5.0 (3905 buckets, 15620 max)
[09:58:34][ 2.071425] ctnetlink v0.93: registering with nfnetlink.
[09:58:34][ 2.077036] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[09:58:34][ 2.084328] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[09:58:34][ 2.090715] xt_time: kernel timezone is -0000
[09:58:34][ 2.095483] ip_tables: (C) 2000-2006 Netfilter Core Team
[09:58:34][ 2.101202] arp_tables: (C) 2002 David S. Miller
[09:58:34][ 2.106110] TCP cubic registered
[09:58:34][ 2.109619] NET: Registered protocol family 10
[09:58:34][ 2.114925] Mobile IPv6
[09:58:34][ 2.117514] ip6_tables: (C) 2000-2006 Netfilter Core Team
[09:58:34][ 2.123345] IPv6 over IPv4 tunneling driver
[09:58:34][ 2.128245] NET: Registered protocol family 17
[09:58:34][ 2.132948] NET: Registered protocol family 15
[09:58:34][ 2.137590] can: controller area network core (rev 20090105 abi 8)
[09:58:34][ 2.144160] NET: Registered protocol family 29
[09:58:34][ 2.148803] can: raw protocol (rev 20090105)
[09:58:34][ 2.153278] can: broadcast manager protocol (rev 20090105 t)
[09:58:34][ 2.159407] Bluetooth: RFCOMM TTY layer initialized
[09:58:34][ 2.164580] Bluetooth: RFCOMM socket layer initialized
[09:58:34][ 2.169949] Bluetooth: RFCOMM ver 1.11
[09:58:34][ 2.173875] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[09:58:34][ 2.179424] Bluetooth: BNEP filters: protocol multicast
[09:58:34][ 2.184898] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[09:58:34][ 2.191212] Registering the dns_resolver key type
[09:58:34][ 2.196204] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[09:58:34][ 2.204230] ThumbEE CPU extension supported.
[09:58:34][ 2.208748] mux: Failed to setup hwmod io irq -22
[09:58:34][ 2.214261] Power Management for AM33XX family
[09:58:34][ 2.219102] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[09:58:34][ 2.225806] Copied the M3 firmware to UMEM
[09:58:34][ 2.230162] Cortex M3 Firmware Version = 0x181
[09:58:34][ 2.237856] clock: disabling unused clocks to save power
[09:58:34][ 2.244736] Detected MACID=4:a3:16:b8:97:cd
[09:58:34][ 2.250253] omap_rtc am33xx-rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[09:58:34][ 2.259682] Waiting for root device /dev/mmcblk0p2...
[09:58:34][ 2.346959] mmc0: new high speed SDHC card at address aaaa
[09:58:34][ 2.353169] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[09:58:34][ 2.359370] mmcblk0: p1 p2 p3 p4
[09:58:36][ 4.416639] EXT4-fs (mmcblk0p2): recovery complete
[09:58:36][ 4.423919] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[09:58:36][ 4.432470] VFS: Mounted root (ext4 filesystem) on device 179:2.
[09:58:36][ 4.439144] Freeing init memory: 344K
[09:58:36][ 4.460918] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[09:58:37][ 4.532740] init: cannot open '/initlogo.rle'
[09:58:39][ 6.775650] EXT4-fs (mmcblk0p3): recovery complete
[09:58:39][ 6.783061] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
[09:58:39][ 6.808857] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[09:58:39][ 6.840925] Disabling lock debugging due to kernel taint
[09:58:39][ 6.847133] Compat-wireless backport release: ol_R5.SP3.03
[09:58:39][ 6.852898] Backport based on wl12xx.git ol_R5.SP3.03
[09:58:39][ 6.912400] cfg80211: Calling CRDA to update world regulatory domain
[09:58:39][ 7.255314] wl12xx: driver version: rowboat-jb-am335x-4.1.2-244-gcf99001-dirty
[09:58:39][ 7.262925] wl12xx: compilation time: Thu Nov 10 20:44:48 2016
[09:58:39][ 7.274105] android_usb: already disabled
[09:58:39][ 7.279959] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
[09:58:39][ 7.290207] android_usb: already disabled
[09:58:39][ 7.361964] android_usb: already disabled
[09:58:39][ 7.384085] mtp_bind_config
[09:58:39][ 7.387096] adb_bind_config
[09:58:39][ 7.482481] warning: `rild' uses 32-bit capabilities (legacy support in use)
[09:58:39]root@android:/ # [ 7.522745] adb_open
[09:58:40][ 8.302415] init: untracked pid 75 exited
[09:58:44][ 11.641799] init: untracked pid 166 exited
[09:58:49][ 16.889334] init: untracked pid 320 exited
[09:58:49][ 16.897621] init: untracked pid 324 exited
[09:58:54][ 22.148512] init: untracked pid 351 exited
[09:58:54][ 22.157194] init: untracked pid 347 exited
[09:58:58][ 26.407807] init: untracked pid 380 exited
[09:58:58][ 26.416179] init: untracked pid 376 exited
[09:59:04][ 31.668746] init: untracked pid 407 exited
[09:59:04][ 31.677444] init: untracked pid 403 exited
[09:59:09][ 36.937954] init: untracked pid 430 exited
[09:59:09][ 36.951866] init: untracked pid 434 exited
[09:59:14][ 42.217307] init: untracked pid 461 exited
[09:59:14][ 42.225696] init: untracked pid 457 exited
[09:59:18][ 46.479870] init: untracked pid 488 exited
[09:59:18][ 46.488546] init: untracked pid 484 exited
[09:59:24][ 51.751801] init: untracked pid 515 exited
[09:59:24][ 51.756453] init: untracked pid 511 exited
[09:59:29][ 57.008146] init: untracked pid 538 exited
[09:59:29][ 57.021874] init: untracked pid 542 exited
[09:59:33][ 61.277437] init: untracked pid 569 exited
[09:59:33][ 61.285798] init: untracked pid 565 exited
[09:59:38][ 66.538084] init: untracked pid 592 exited
[09:59:38][ 66.551874] init: untracked pid 596 exited
[09:59:44][ 71.807460] init: untracked pid 623 exited
[09:59:44][ 71.816135] init: untracked pid 619 exited
[09:59:49][ 77.068252] init: untracked pid 646 exited
[09:59:49][ 77.081865] init: untracked pid 650 exited
[09:59:53][ 81.337331] init: untracked pid 677 exited
[09:59:53][ 81.345706] init: untracked pid 673 exited
[09:59:58][ 86.598257] init: untracked pid 700 exited
[09:59:58][ 86.611869] init: untracked pid 704 exited
[10:00:04]@[ 91.867893] init: untracked pid 731 exited
[10:00:04][ 91.876596] init: untracked pid 727 exited
[10:00:09][ 97.136664] init: untracked pid 758 exited
[10:00:09][ 97.141415] init: untracked pid 754 exited
[10:00:13][ 101.397011] init: untracked pid 785 exited
[10:00:13][ 101.405377] init: untracked pid 781 exited
[10:00:18][ 106.658566] init: untracked pid 808 exited
[10:00:18][ 106.686001] init: untracked pid 812 exited
[10:00:24][ 111.938137] init: untracked pid 835 exited
[10:00:24][ 111.951872] init: untracked pid 839 exited
[10:00:29][ 117.208176] init: untracked pid 866 exited
[10:00:29][ 117.216860] init: untracked pid 862 exited
[10:00:33][ 121.468154] init: untracked pid 889 exited
[10:00:33][ 121.481884] init: untracked pid 893 exited
[10:00:38][ 126.737947] init: untracked pid 920 exited
[10:00:38][ 126.746629] init: untracked pid 916 exited
[10:00:44][ 132.006797] init: untracked pid 947 exited
[10:00:44][ 132.011570] init: untracked pid 943 exited
[10:00:49][ 137.268697] init: untracked pid 974 exited
[10:00:49][ 137.277393] init: untracked pid 970 exited
[10:00:53][ 141.528195] init: untracked pid 1001 exited
[10:00:53][ 141.536948] init: untracked pid 997 exited
[10:00:59][ 146.806483] init: untracked pid 1028 exited
[10:00:59][ 146.811282] init: untracked pid 1023 exited
[10:01:04][ 152.086984] init: untracked pid 1055 exited
[10:01:04][ 152.096245] init: untracked pid 1050 exited
[10:01:08][ 156.347744] init: untracked pid 1082 exited
[10:01:08][ 156.356219] init: untracked pid 1078 exited
[10:01:13][ 161.626669] init: untracked pid 1109 exited
[10:01:13][ 161.631514] init: untracked pid 1104 exited
[10:01:19][ 166.906593] init: untracked pid 1136 exited
[10:01:19][ 166.911489] init: untracked pid 1131 exited
[10:01:32][ 172.189316] init: untracked pid 1163 exited
[10:01:32][ 172.202152] init: untracked pid 1158 exited
[10:01:32][ 176.454179] init: untracked pid 1190 exited
[10:01:32][ 176.476318] init: untracked pid 1186 exited
[10:01:33][ 181.738570] init: untracked pid 1212 exited
[10:01:33][ 181.766007] init: untracked pid 1217 exited
[10:01:39][ 187.029730] init: untracked pid 1244 exited
[10:01:39][ 187.041957] init: untracked pid 1239 exited
[10:01:43]@[ 191.304477] init: untracked pid 1271 exited
[10:01:43][ 191.326295] init: untracked pid 1266 exited
[10:01:48][ 196.596685] init: untracked pid 1298 exited
[10:01:48][ 196.601533] init: untracked pid 1293 exited
[10:01:54][ 201.876905] init: untracked pid 1325 exited
[10:01:54][ 201.881747] init: untracked pid 1320 exited
[10:01:59][ 207.157182] init: untracked pid 1352 exited
[10:01:59][ 207.166492] init: untracked pid 1347 exited
[10:02:03][ 211.417830] init: untracked pid 1379 exited
[10:02:03][ 211.426616] init: untracked pid 1375 exited
[10:02:08][ 216.696963] init: untracked pid 1406 exited
[10:02:08][ 216.701846] init: untracked pid 1401 exited
[10:02:14][ 221.976984] init: untracked pid 1433 exited
[10:02:14][ 221.981862] init: untracked pid 1428 exited
[10:02:19][ 227.254913] init: untracked pid 1460 exited
[10:02:19][ 227.280851] init: untracked pid 1455 exited
[10:02:23][ 231.536617] init: untracked pid 1487 exited
[10:02:23][ 231.541486] init: untracked pid 1483 exited
[10:02:28][ 236.817099] init: untracked pid 1514 exited
[10:02:28][ 236.821975] init: untracked pid 1509 exited
[10:02:34][ 242.094563] init: untracked pid 1541 exited
[10:02:34][ 242.106033] init: untracked pid 1536 exited
[10:02:38][ 246.357456] init: untracked pid 1568 exited
[10:02:38][ 246.366250] init: untracked pid 1564 exited
[10:02:43][ 251.634273] init: untracked pid 1595 exited
[10:02:43][ 251.656300] init: untracked pid 1590 exited
[10:02:48][ 256.917681] init: untracked pid 1617 exited
[10:02:49][ 256.946193] init: untracked pid 1622 exited
[10:02:54][ 262.208454] init: untracked pid 1644 exited
[10:02:54][ 262.221681] init: untracked pid 1649 exited
[10:02:58][ 266.484420] init: untracked pid 1676 exited
[10:02:58][ 266.506337] init: untracked pid 1672 exited
[10:03:03][ 271.768541] init: untracked pid 1698 exited
[10:03:03][ 271.795972] init: untracked pid 1703 exited
[10:03:09][ 277.058544] init: untracked pid 1725 exited
[10:03:09][ 277.071659] init: untracked pid 1730 exited
[10:03:13][ 281.334447] init: untracked pid 1757 exited
[10:03:13][ 281.356329] init: untracked pid 1753 exited
[10:03:18][ 286.617650] init: untracked pid 1779 exited
[10:03:18][ 286.631886] init: untracked pid 1784 exited
[10:03:23][ 291.915324] init: untracked pid 1811 exited
[10:03:23][ 291.936272] init: untracked pid 1806 exited
[10:03:29]@[ 297.214868] init: untracked pid 1838 exited
[10:03:29][ 297.240855] init: untracked pid 1833 exited
[10:03:33][ 301.496853] init: untracked pid 1865 exited
[10:03:33][ 301.501726] init: untracked pid 1861 exited
[10:03:38][ 306.774637] init: untracked pid 1892 exited
[10:03:38][ 306.796263] init: untracked pid 1887 exited
[10:03:44][ 312.065067] init: untracked pid 1920 exited
[10:03:44][ 312.090796] init: untracked pid 1914 exited
[10:03:48][ 316.346954] init: untracked pid 1947 exited
[10:03:48][ 316.351834] init: untracked pid 1943 exited
[10:03:53][ 321.624649] init: untracked pid 1974 exited
[10:03:53][ 321.646324] init: untracked pid 1969 exited
[10:03:58][ 326.914795] init: untracked pid 2001 exited
[10:03:58][ 326.936321] init: untracked pid 1996 exited
[10:04:04][ 332.204904] init: untracked pid 2028 exited
[10:04:04][ 332.230809] init: untracked pid 2023 exited
[10:04:08][ 336.487034] init: untracked pid 2055 exited
[10:04:08][ 336.491927] init: untracked pid 2051 exited
[10:04:13][ 341.764750] init: untracked pid 2082 exited
[10:04:13][ 341.786330] init: untracked pid 2077 exited
[10:04:19][ 347.055008] init: untracked pid 2109 exited
[10:04:19][ 347.080809] init: untracked pid 2104 exited
[10:04:23][ 351.337112] init: untracked pid 2136 exited
[10:04:23][ 351.341994] init: untracked pid 2132 exited
[10:04:28][ 356.614725] init: untracked pid 2163 exited
[10:04:28][ 356.636321] init: untracked pid 2158 exited
[10:04:33][ 361.904667] init: untracked pid 2190 exited
[10:04:33][ 361.926309] init: untracked pid 2185 exited
[10:04:39][ 367.195258] init: untracked pid 2217 exited
[10:04:39][ 367.220734] init: untracked pid 2212 exited
[10:04:43][ 371.476762] init: untracked pid 2244 exited
[10:04:43][ 371.481607] init: untracked pid 2240 exited
[10:04:48][ 376.754855] init: untracked pid 2271 exited
[10:04:48][ 376.776307] init: untracked pid 2266 exited
[10:04:53][ 382.045413] init: untracked pid 2298 exited
[10:04:53][ 382.070710] init: untracked pid 2293 exited
[10:04:58][ 386.324275] init: untracked pid 2325 exited
[10:04:58][ 386.346310] init: untracked pid 2321 exited
[10:05:03][ 391.608561] init: untracked pid 2347 exited
[10:05:03][ 391.616938] init: untracked pid 2352 exited
[10:05:08]@[ 396.884841] init: untracked pid 2379 exited
[10:05:08][ 396.906314] init: untracked pid 2374 exited
[10:05:14][ 402.177185] init: untracked pid 2406 exited
[10:05:14][ 402.186546] init: untracked pid 2401 exited
[10:05:18][ 406.439206] init: untracked pid 2433 exited
[10:05:18][ 406.447978] init: untracked pid 2429 exited
[10:05:23][ 411.714860] init: untracked pid 2460 exited
[10:05:23][ 411.736308] init: untracked pid 2455 exited
[10:05:28][ 417.004810] init: untracked pid 2487 exited
[10:05:28][ 417.027022] init: untracked pid 2482 exited
[10:05:33][ 421.285221] init: untracked pid 2514 exited
[10:05:33][ 421.306288] init: untracked pid 2509 exited
[10:05:38][ 426.577188] init: untracked pid 2541 exited
[10:05:38][ 426.582083] init: untracked pid 2536 exited
[10:05:43][ 431.854902] init: untracked pid 2568 exited
[10:05:43][ 431.876304] init: untracked pid 2563 exited
[10:05:48][ 437.137804] init: untracked pid 2590 exited
[10:05:48][ 437.151867] init: untracked pid 2595 exited
[10:05:53][ 441.419887] init: untracked pid 2622 exited
[10:05:53][ 441.428660] init: untracked pid 2618 exited
[10:05:58][ 446.695409] init: untracked pid 2649 exited
[10:05:58][ 446.716250] init: untracked pid 2644 exited
[10:06:03][ 451.985450] init: untracked pid 2676 exited
[10:06:03][ 452.006296] init: untracked pid 2671 exited
[10:06:08][ 456.268586] init: untracked pid 2698 exited
[10:06:08][ 456.276957] init: untracked pid 2703 exited
[10:06:13][ 461.551856] init: untracked pid 2730 exited
[10:06:13][ 461.556608] init: untracked pid 2725 exited
[10:06:18][ 466.825365] init: untracked pid 2757 exited
[10:06:18][ 466.846269] init: untracked pid 2752 exited
[10:06:23][ 472.122219] init: untracked pid 2784 exited
[10:06:23][ 472.135917] init: untracked pid 2779 exited
[10:06:28][ 476.390113] init: untracked pid 2811 exited
[10:06:28][ 476.398884] init: untracked pid 2807 exited
[10:06:33][ 481.671866] init: untracked pid 2838 exited
[10:06:33][ 481.676625] init: untracked pid 2833 exited
[10:06:38][ 486.951856] init: untracked pid 2865 exited
[10:06:38][ 486.956596] init: untracked pid 2860 exited
[10:06:43][ 492.232182] init: untracked pid 2892 exited
[10:06:43][ 492.245805] init: untracked pid 2887 exited
[10:06:48][ 496.498745] init: untracked pid 2919 exited
[10:06:48][ 496.507526] init: untracked pid 2915 exited
[10:06:53]@[ 501.782020] init: untracked pid 2946 exited
[10:06:53][ 501.786774] init: untracked pid 2941 exited
[10:06:58][ 507.062157] init: untracked pid 2973 exited
[10:06:58][ 507.075773] init: untracked pid 2968 exited
[10:07:03][ 511.329218] init: untracked pid 3000 exited
[10:07:03][ 511.337976] init: untracked pid 2996 exited
[10:07:08][ 516.611859] init: untracked pid 3027 exited
[10:07:08][ 516.616606] init: untracked pid 3022 exited
[10:07:13][ 521.892165] init: untracked pid 3054 exited
[10:07:13][ 521.896946] init: untracked pid 3049 exited
[10:07:18][ 527.182166] init: untracked pid 3081 exited
[10:07:18][ 527.195847] init: untracked pid 3076 exited
[10:07:23][ 531.449228] init: untracked pid 3108 exited
[10:07:23][ 531.458005] init: untracked pid 3104 exited
[10:07:28][ 536.732173] init: untracked pid 3135 exited
[10:07:28][ 536.736960] init: untracked pid 3130 exited
[10:07:33][ 542.015534] init: untracked pid 3162 exited
[10:07:33][ 542.025786] init: untracked pid 3157 exited
