我们现在用的是一个24位rgb的lcd,这个是lcd的数据脚定义,使用的24bit:
我们的硬件连接,am335测如下:
lcd的FPC测如下:
软件配置:
static struct da8xx_panel known_lcd_panels[] = {
[0] = {//使用这项
.name = "4.3inch_LCD",
.width = 320,
.height = 240,
.hfp = 20,
.hbp = 20,
.hsw = 41,
.vfp = 2,
.vbp = 2,
.vsw = 10,
.pxl_clk = 8000000,
.invert_pxl_clk = 0,
static struct pinmux_config lcdc_pin_mux[] = {
{"lcd_data0.lcd_data0", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data1.lcd_data1", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data2.lcd_data2", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data3.lcd_data3", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data4.lcd_data4", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data5.lcd_data5", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data6.lcd_data6", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data7.lcd_data7", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data8.lcd_data8", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data9.lcd_data9", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data10.lcd_data10", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data11.lcd_data11", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data12.lcd_data12", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data13.lcd_data13", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data14.lcd_data14", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data15.lcd_data15", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"gpmc_ad15.lcd_data16", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"gpmc_ad14.lcd_data17", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"gpmc_ad13.lcd_data18", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"gpmc_ad12.lcd_data19", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"gpmc_ad11.lcd_data20", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"gpmc_ad10.lcd_data21", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"gpmc_ad9.lcd_data22", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"gpmc_ad8.lcd_data23", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_vsync.lcd_vsync", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT},
{"lcd_hsync.lcd_hsync", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT},
{"lcd_pclk.lcd_pclk", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT},
{"lcd_ac_bias_en.lcd_ac_bias_en", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT},
{NULL, 0},
static const struct display_panel disp_panel = {
WVGA,
32,
16,
COLOR_ACTIVE,
static struct lcd_ctrl_config lcd_cfg = {
&disp_panel,
.ac_bias = 255,
.ac_bias_intrpt = 0,
.dma_burst_sz = 16,
.bpp = 24,
.fdd = 0x80,
.tft_alt_mode = 0,
.stn_565_mode = 0,
.mono_8bit_mode = 0,
.invert_line_clock = 1,
.invert_frm_clock = 1,
.sync_edge = 0,
.sync_ctrl = 1,
.raster_order = 0,
现在屏幕上没有红色出现,应该是红色的地方显示黄色了,像是r组没生效
图中的A背景应该是红色,现在显示黄色;
这个现象会是什么问题?
