DM385 syslink启动异常
Other Parts Discussed in Thread: TPS65910
你好,我司使用DM385平台,设备运行几个月后,发现有两台设备断电重启后出现同样问题,内核报出错误Unable to handle kernel paging request at virtual address a0000000,问题点指向PC is at Cfg_prop+0xa8/0xc0 [syslink],Cfg_prop函数属于TI直接提供的,能否协助解决?详细的调试信息如下:
Loading from nand0, offset 0x280000    Image Name:   Linux-2.6.37_DM385_IPNC_3.50.00    Image Type:   ARM Linux Kernel Image (uncompressed)    Data Size:    2531124 Bytes = 2.4 MiB    Load Address: 80008000    Entry Point:  80008000 ## Booting kernel from Legacy Image at 81000000 ...    Image Name:   Linux-2.6.37_DM385_IPNC_3.50.00    Image Type:   ARM Linux Kernel Image (uncompressed)    Data Size:    2531124 Bytes = 2.4 MiB    Load Address: 80008000    Entry Point:  80008000    Verifying Checksum ... OK    Loading Kernel Image ... OK OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel. Linux version 2.6.37_DM385_IPNC_3.50.00 (root@jifeng-desktop) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #41 PREEMPT Tue Dec 29 10:35:50 CST 2015 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: dm385ipnc vram size = 4194304 at 0x0 bootconsole [earlycon0] enabled ti81xx_reserve: ### Reserved DDR region @84f00000 reserved size = 4194304 at 0x0 FB: Reserving 4194304 bytes SDRAM for VRAM Memory policy: ECC disabled, Data cache writeback OMAP chip is DM385 1.0 SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000 Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 19040 Kernel command line: console=ttyO0,115200n8 rootwait=1 rw ubi.mtd=4,2048 rootfstype=ubifs root=ubi0:rootfs init=/init mem=80M vram=4M notifyk.vpssm3_sva=0xBFD00000  cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 earlyprintk PID hash table entries: 512 (order: -1, 2048 bytes) Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Memory: 74MB 1MB = 75MB total Memory: 70556k/70556k available, 11364k reserved, 0K highmem Virtual kernel memory layout:     vector  : 0xffff0000 - 0xffff1000   (   4 kB)     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)     DMA     : 0xffc00000 - 0xffe00000   (   2 MB)     vmalloc : 0xc5800000 - 0xf8000000   ( 808 MB)     lowmem  : 0xc0000000 - 0xc5000000   (  80 MB)     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)     modules : 0xbf000000 - 0xbfe00000   (  14 MB)       .init : 0xc0008000 - 0xc003e000   ( 216 kB)       .text : 0xc003e000 - 0xc04d9000   (4716 kB)       .data : 0xc04da000 - 0xc0518d40   ( 252 kB) SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:375 IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts Total of 128 interrupts on 1 active controller GPMC revision 6.0 Trying to install interrupt handler for IRQ368 Trying to install interrupt handler for IRQ369 Trying to install interrupt handler for IRQ370 Trying to install interrupt handler for IRQ371 Trying to install interrupt handler for IRQ372 Trying to install interrupt handler for IRQ373 Trying to install interrupt handler for IRQ374 Trying to install type control for IRQ375 Trying to set irq flags for IRQ375 OMAP clockevent source: GPTIMER1 at 20000000 Hz Console: colour dummy device 80x30 Calibrating delay loop... 598.01 BogoMIPS (lpj=2990080) pid_max: default: 32768 minimum: 301 Security Framework initialized Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok devtmpfs: initialized TI81XX: Map 0x84f00000 to 0xfe500000 for dram barrier TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier omap_voltage_early_init: voltage driver support not added regulator: core version 0.5 regulator: dummy: NET: Registered protocol family 16 omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting! omap_voltage_add_dev: VDD specified does not exist! OMAP GPIO hardware version 0.1 OMAP GPIO hardware version 0.1 OMAP GPIO hardware version 0.1 OMAP GPIO hardware version 0.1 omap_mux_init: Add partition: #1: core, flags: 4 Cannot clk_get ck_32 Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now registered ti81xx_vpss device registered ti81xx_vidout device registered ti81xx on-chip HDMI device registered ti81xx_fb device PWM0 init success. PWM1 init success. bio: create slab <bio-0> at 0 SCSI subsystem initialized omap2_mcspi: probe of omap2_mcspi.3 failed with error -2 omap2_mcspi: probe of omap2_mcspi.4 failed with error -2 USBSS revision 4ea2080b registerd cppi-dma Intr @ IRQ 17 Cppi41 Init Done omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz tps65910 1-002d: read from reg 3f failed tps65910 1-002d: read from reg 1e failed set_machine_constraints: failed to enable VRTC tps65910 1-002d: failed to register tps65910-pmic regulator tps65910-pmic: probe of tps65910-pmic failed with error -121 tps65910 1-002d: No interrupt support, no core IRQ Switching to clocksource gp timer musb-hdrc: version 6.0, peripheral, debug=0 musb-hdrc musb-hdrc.0: dma type: dma-cppi41 MUSB controller-0 revision 4ea20800 usb2phy: computed values rxcalib(15)DACs(23 15 16) usb2phy: override computed values rxcalib(15)DACs(23 15 16) usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f6bdf86 musb-hdrc musb-hdrc.0: USB Peripheral mode controller at c581e000 using DMA, IRQ 18 NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 4096 (order: 3, 32768 bytes) TCP bind hash table entries: 4096 (order: 2, 16384 bytes) TCP: Hash tables configured (established 4096 bind 4096) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. NetWinder Floating Point Emulator V0.97 (double precision) PMU: registered new PMU device of type 0 omap-iommu omap-iommu.0: ducati registered omap-iommu omap-iommu.1: sys registered JFFS2 version 2.2. (NAND) (SUMMARY)  ? 2001-2006 Red Hat, Inc. msgmni has been set to 137 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) CMEMK module: built on Nov  6 2015 at 08:39:31   Reference Linux version 2.6.37   File /opt/dm385/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c allocated heap buffer 0xc7000000 of size 0x4000000 cmemk initialized Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0 console [ttyO0] enabled, bootconsole disabled console [ttyO0] enabled, bootconsole disabled omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 brd: module loaded loop: module loaded omap2-nand driver initializing -----------8000000, c5890000-------------- --------------------------busw = 2--------------- maf id=0x2c device id 0xca NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron ) Creating 8 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000020000 : "U-Boot-min" 0x000000020000-0x000000260000 : "U-Boot" 0x000000260000-0x000000280000 : "U-Boot Env" 0x000000280000-0x0000006c0000 : "Kernel" 0x0000006c0000-0x000006fc0000 : "File System" 0x000006fc0000-0x000007bc0000 : "Data" 0x000007bc0000-0x00000e4c0000 : "File System2" 0x00000e4c0000-0x000010000000 : "Reserved" UBI: attaching mtd4 to ubi0 UBI: physical eraseblock size:   131072 bytes (128 KiB) UBI: logical eraseblock size:    126976 bytes UBI: smallest flash I/O unit:    2048 UBI: sub-page size:              512 UBI: VID header offset:          2048 (aligned 2048) UBI: data offset:                4096 UBI: max. sequence number:       1331 UBI: attached mtd4 to ubi0 UBI: MTD device name:            "File System" UBI: MTD device size:            105 MiB UBI: number of good PEBs:        840 UBI: number of bad PEBs:         0 UBI: number of corrupted PEBs:   0 UBI: max. allowed volumes:       128 UBI: wear-leveling threshold:    4096 UBI: number of internal volumes: 1 UBI: number of user volumes:     1 UBI: available PEBs:             0 UBI: total number of reserved PEBs: 840 UBI: number of PEBs reserved for bad PEB handling: 8 UBI: max/mean erase counter: 5/1 UBI: image sequence number:  1008737709 UBI: background thread "ubi_bgt0d" started, PID 41 davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 davinci_mdio davinci_mdio.0: detected phy mask fffffffe davinci_mdio.0: probed davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown mice: PS/2 mouse device common for all mice i2c /dev entries driver Linux video capture interface: v2.00 OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec notify_shm_drv: no DSP present (MULTIPROC_INVALIDID) notify_init : notify drivercreated  for  remote proc id 1 at physical Address 0xbfd00000 nf_conntrack version 0.5.0 (1102 buckets, 4408 max) ip_tables: (C) 2000-2006 Netfilter Core Team TCP cubic registered NET: Registered protocol family 17 Bridge firewalling registered lib80211: common routines for IEEE802.11 drivers Registering the dns_resolver key type VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 omap_voltage_late_init: Voltage driver support not added Power Management for TI81XX. Detected MACID=c4:ed:ba:c0:94:f0 UBIFS: mounted UBI device 0, volume 0, name "rootfs" UBIFS: file system size:   103612416 bytes (101184 KiB, 98 MiB, 816 LEBs) UBIFS: journal size:       9023488 bytes (8812 KiB, 8 MiB, 72 LEBs) UBIFS: media format:       w4/r0 (latest is w4/r0) UBIFS: default compressor: lzo UBIFS: reserved for root:  0 bytes (0 KiB) VFS: Mounted root (ubifs filesystem) on device 0:13. devtmpfs: mounted Freeing init memory: 216K Failed to execute /init.  Attempting defaults... INIT: version 2.86 booting Please wait: booting... Starting udev Root filesystem already rw, not remounting Caching udev devnodes Configuring network interfaces... CPSW phy found : id is : 0x4dd074 PHY 0:01 not found udhcpc (v1.21.1) started Sending discover... PHY: 0:00 - Link is Up - 100/Full Sending discover... Sending select for 192.168.202.27... Lease of 192.168.202.27 obtained, lease time 691200 adding dns 172.16.0.244 adding dns 172.16.0.240 done. Setting up IP spoofing protection: rp_filter. rm: can't remove '/tmp': Device or resource busy hwclock: can't open '/dev/misc/rtc': No such file or directory Mon Mar 17 01:38:00 GMT-8 2008 hwclock: can't open '/dev/misc/rtc': No such file or directory  inside finish.sh UBI: attaching mtd5 to ubi1 UBI: physical eraseblock size:   131072 bytes (128 KiB) UBI: logical eraseblock size:    126976 bytes UBI: smallest flash I/O unit:    2048 UBI: sub-page size:              512 UBI: VID header offset:          2048 (aligned 2048) UBI: data offset:                4096 UBI: max. sequence number:       129 UBI: attached mtd5 to ubi1 UBI: MTD device name:            "Data" UBI: MTD device size:            12 MiB UBI: number of good PEBs:        96 UBI: number of bad PEBs:         0 UBI: number of corrupted PEBs:   0 UBI: max. allowed volumes:       128 UBI: wear-leveling threshold:    4096 UBI: number of internal volumes: 1 UBI: number of user volumes:     1 UBI: available PEBs:             0 UBI: total number of reserved PEBs: 96 UBI: number of PEBs reserved for bad PEB handling: 2 UBI: max/mean erase counter: 3/2 UBI: image sequence number:  335838422 UBI: background thread "ubi_bgt1d" started, PID 287 UBI device number 1, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB) UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume" UBIFS: file system size:   10285056 bytes (10044 KiB, 9 MiB, 81 LEBs) UBIFS: journal size:       1015809 bytes (992 KiB, 0 MiB, 6 LEBs) UBIFS: media format:       w4/r0 (latest is w4/r0) UBIFS: default compressor: lzo UBIFS: reserved for root:  485787 bytes (474 KiB) UBI: attaching mtd7 to ubi2 UBI: physical eraseblock size:   131072 bytes (128 KiB) UBI: logical eraseblock size:    126976 bytes UBI: smallest flash I/O unit:    2048 UBI: sub-page size:              512 UBI: VID header offset:          2048 (aligned 2048) UBI: data offset:                4096 UBI: max. sequence number:       243 UBI: attached mtd7 to ubi2 UBI: MTD device name:            "Reserved" UBI: MTD device size:            27 MiB UBI: number of good PEBs:        218 UBI: number of bad PEBs:         0 UBI: number of corrupted PEBs:   0 UBI: max. allowed volumes:       128 UBI: wear-leveling threshold:    4096 UBI: number of internal volumes: 1 UBI: number of user volumes:     1 UBI: available PEBs:             0 UBI: total number of reserved PEBs: 218 UBI: number of PEBs reserved for bad PEB handling: 2 UBI: max/mean erase counter: 4/2 UBI: image sequence number:  -1983773309 UBI: background thread "ubi_bgt2d" started, PID 300 UBI device number 2, total 218 LEBs (27680768 bytes, 26.4 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB) UBIFS: mounted UBI device 2, volume 0, name "ubifs_volume" UBIFS: file system size:   25776128 bytes (25172 KiB, 24 MiB, 203 LEBs) UBIFS: journal size:       1269760 bytes (1240 KiB, 1 MiB, 10 LEBs) UBIFS: media format:       w4/r0 (latest is w4/r0) UBIFS: default compressor: lzo UBIFS: reserved for root:  1217469 bytes (1188 KiB) --------------------------------- watchdog.c:41:Current timeout value is : 60 seconds watchdog.c:48:New timeout value is : 10 seconds watchdog.c:56:Current timeout value is : 10 seconds ---------update server V 1.0.03---- --------------------------------- upgrade server listening......... ./init.sh: line 5: -f: not found amixer: Control default open error: No such file or directory
net_config.c:65:Debug get net config ok net_config.c:73:Debug ifconfig eth0 172.16.135.81 net_config.c:76:Debug ifconfig eth0 netmask 255.255.254.0 net_config.c:79:Debug route add default gw 172.16.134.1  [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000  [m3video] Remote Debug Shared Memory @ 0xbff05020  [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 SysLink version : 2.20.02.20 SysLink module created on Date:Mar 29 2016 Time:10:25:17 Trace enabled Trace SetFailureReason enabled /dev/mem opened.              Phy Addr : 0x48181560 Data : 0x00000002              Phy Addr : 0x48180f10 Data : 0x0000Unhandled fault: external abort on non-linefetch (0x1018) at 0x402610e4 0000              Phy Addr : 0x48180508 Data : 0x00000302              Phy Addr : 0x48180520 Data : 0x00000002              Phy Addr : 0x48180524 Data : 0x00000002              Phy Addr : 0x48180528 Data : 0x00000002              Phy Addr : 0x4c0000e4 Data : 0x00170208 Bus error [host]  Setting DMM priority for [ISS     ] to [0] ( 0x4e000634 = 0x00800000 ) [host]  Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 ) [host]  Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500] share_mem.c:38:Debug shared memory id:0 msg_util.c:37:Debug Creat queue id:0 msg_util.c:39:Debug queue id:0 share_mem.c:54:Debug shared memory size 245760 share_mem.c:57:Debug shared memory id:32769 file_msg_drv.c:35:Debug Share Memory id : 32769 file_msg_drv.c:37:Debug Share Memory Address:0x403df000 share_mem.c:54:Debug shared memory size 245760 share_mem.c:57:Debug shared memory id:65538 file_msg_drv.c:43:Debug Share Memory id : 32769 file_msg_drv.c:45:Debug Share Memory Address:0x404ca000 file_mng_main.c:502:Debug reloadFlag=0 net_db.c:358:Debug net->ip:192.168.1.65,str:192.168.1.65 get acounts[1].authority failed get acounts[2].authority failed get acounts[3].authority failed get acounts[4].authority failed get acounts[5].authority failed get acounts[6].authority failed get acounts[7].authority failed get acounts[8].authority failed get acounts[9].authority failed get acounts[10].authority failed get acounts[11].authority failed get acounts[12].authority failed get acounts[13].authority failed get acounts[14].authority failed get acounts[15].authority failed net_db.c:358:Debug net->ip:172.16.135.81,str:172.16.135.81 Unable to handle kernel paging request at virtual address a0000000 pgd = c3f3c000 [a0000000] *pgd=00000000 Internal error: Oops: 5 [#1] PREEMPT last sysfs file: /sys/devices/virtual/syslinkipc/syslinkipc_FrameQ/uevent Modules linked in: syslink rtc_jyrtc CPU: 0    Not tainted  (2.6.37_DM385_IPNC_3.50.00 #41) PC is at Cfg_prop+0xa8/0xc0 [syslink] LR is at Cfg_prop+0x28/0xc0 [syslink] pc : [<bf01ea64>]    lr : [<bf01e9e4>]    psr: 60000013 sp : c3e66fa8  ip : c3e66fa8  fp : c3e66fc4 r10: 00000000  r9 : fffff230  r8 : 00000000 r7 : bf063f35  r6 : 00000020  r5 : c3e66fc8  r4 : a0000000 r3 : bf063f56  r2 : bf063f55  r1 : 00000000  r0 : 00000020 Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user Control: 10c5387d  Table: 83f3c019  DAC: 00000015 Process fw_load.out (pid: 347, stack limit = 0xc3e662e8) Stack: (0xc3e66fa8 to 0xc3e68000) 6fa0:                   c6b6b000 c6b6b000 bf0ad920 c3e67064 c3e66fe4 c3e66fc8 6fc0: bf01ea98 bf01e9c8 c3e66fec c3e66fd8 c6b68000 bf0ad920 c3e6702c c3e66fe8 6fe0: bf01d7ec bf01ea88 c3e67064 bf01e67c 00000000 c6b68000 c3e67034 c3e67008 7000: bf019170 c6b68000 c3e67064 bf0ad920 00000008 00000000 fffff230 00000000 7020: c3e67054 c3e67030 bf0080e8 bf01d7a0 c3e67064 bf01e6cc c3e67e34 c6b80000 7040: c3e67eac c3e67078 c3e67e64 c3e67058 bf009e18 bf0080a4 c3e67eac 00000000 7060: 00000000 c3e67eac 00000000 00000000 00000000 00000000 00000000 00000000 7080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 70a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 70c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 70e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7100: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 71a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 71c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 71e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7200: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 72a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 72c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 72e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7300: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7320: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7380: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 73a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 73c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 73e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7420: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 74a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 74c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 74e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7500: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7580: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 75a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 75c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 75e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7600: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7620: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7640: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7660: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7680: 00000000 00000000 00000000 00000000 00000000 00000000 c46b2b30 c04f54c8 76a0: 94b82d00 00000003 c46b2b30 005b8d80 00000000 c46b2b30 c3e676e4 c3e676c8 76c0: c006c390 c006bc74 c46b2b30 c03ba180 c46b2b00 c04f5480 c3e67704 c3e676e8 76e0: c006c940 c006c220 c04f52b4 00000000 c3e6771c c3e67700 c0069da0 c0069b20 7700: c0519110 16ffad21 0000000f c04e0198 c3e6772c c3e67720 c00559c0 c0069d00 7720: 00000000 c45d9b80 00000001 18261df6 00000001 c04f5480 c3e6776c c3e67748 7740: c006de40 c0208db0 c04f5480 c45d9b80 c006ca7c c04f5480 c03ba148 00000000 7760: c04f5480 0000000f c3e6778c c3e67778 c0087ebc c008bcec 00000002 c3e66000 7780: c3e677bc c3e67790 c006dabc c03b1398 00000000 20000113 c04f71b0 c053a3c0 77a0: c0043a10 00000002 00000000 fffffffe c3e677e4 c3e677c0 c03b5688 c0043a1c 77c0: ffffffff c0518e10 ffffffff c46b0000 00000000 bf0ad9f4 00000001 00000001 77e0: c3e6782c c3e677f0 bf02db20 bf01e6cc bf0ad9f4 0000000c c3e67854 bf0ad920 7800: 00000000 c3e67854 c3e6782c bf0ad920 00000001 00000012 00000000 bf0ad920 7820: c3e67efc c3e67830 bf0526d8 bf01e6cc c024f352 beca5850 c46b2b00 c46b2b30 7840: c46b2b30 c04f54c8 95e95a00 beca5850 c46b2b30 00000000 00000000 00000000 7860: c3e6788c c3e67870 c006c390 c006bc74 c46b2b30 c03ba180 c46b2b00 c04f5480 7880: c3e678ac c3e67890 c006c940 c006c220 c04f52b4 00000000 c3e678c4 c3e678a8 78a0: c0069da0 c0069b20 c0519110 0000000e 0000000c 0000000c c3e678f4 c3e678c8 78c0: c027a544 c0054c94 00000000 c027a81c c4539a18 c4539a18 c3e678f4 c3e678e8 78e0: c0279ad8 c0054ccc c3e67944 c3e678f8 c0279950 c0279abc c3e6792c 000010de 7900: c4624480 c4624c80 c054c2e0 0000083a 00000038 00000200 c02755e4 c4539a18 7920: c4539810 000000bc c4624480 c4539810 000000bc 0000000e 0000000c 0000000c 7940: 00000000 00000000 c3e67994 c3e67958 c035ace8 c03b54a0 c4539a18 c4539a18 7960: c3e6797c 00000001 c0279ad8 93caa8c0 ebcaa8c0 c46bec00 c4699600 c054d8a8 7980: 93caa8c0 ebcaa8c0 c3e67a34 c3e67998 c03250c8 c03b54a0 c3e679b4 c3e679a8 79a0: c0279ad8 c0054ccc 000000c0 c3e679b8 c0279950 00000000 00000002 00000000 79c0: c05e27c0 c4402100 c3e679f4 c3e679d8 c00d0338 c03b54a0 40000113 c05ce400 79e0: c3d63850 c46bec00 c3e67a0c c3e679f8 c00d0494 0000000e 0000000c 0000000c 7a00: c3e67a3c c3e67a10 c027a544 c0054c94 00000000 c027a81c c4539a18 c4539a18 7a20: c3e67a3c c3e67a30 c0279ad8 c0054ccc c3e67a8c c3e67a40 c0279950 c0279abc 7a40: c3e67a64 000038fe c4624480 c4624c80 c054c2e0 0000083a 00000038 00000200 7a60: c02755e4 c4539a18 c4539810 00000598 c4624480 c4539810 00000598 00000000 7a80: c3e67aac c3e67a90 c004bf9c c004aa1c c004aa40 c3e66000 00000001 01c7eab0 7aa0: c3e67ad4 c3e67ab0 c004aa7c c004bf84 c3e67b04 c3e67af0 c03b5550 c02743dc 7ac0: 00000000 c03b5550 c3e67aec c3e67ad8 c03b5550 c004aa4c c4539a18 c4539810 7ae0: c3e67b04 c3e67af0 c02743dc c03b54a0 c3e67b94 c4539a18 c3e67b34 c3e67b08 7b00: c0276020 c0274398 c4539c0c c03b54a0 00000000 c4638800 00000000 006c0000 7b20: 00000000 015bf598 c3e67b74 c3e67b38 c026d41c c0275f94 c3e67b64 c3e67b48 7b40: c004bf9c c004aa1c c004aa40 c3e66000 00000001 00000000 c3e67b8c c3e67b68 7b60: c004aa7c c004bf84 c3e67bc4 c3e67ba8 c03b5550 c028110c 00000000 c03b5550 7b80: c3e67ba4 c3e67b90 c03b5550 c004aa4c c453a000 c3494200 c3e67bc4 c3e67ba8 7ba0: c028110c c03b54a0 c3e67b94 c453a000 00000000 c4654800 c3e67c0c c3e67bc8 7bc0: c0281480 c02810a8 00000ae8 c3e67bd8 c004aa7c c3d5a000 00000235 00000000 7be0: c3e67c14 c4654800 00000000 c3d5a000 0001e598 00000003 00000ae8 00000001 7c00: c3e67c44 c3e67c10 c02808c0 c0281214 0001dab0 00000ae8 00000000 c006b7f4 7c20: c006ca7c c3d5a000 0001dab0 00000235 00000ae8 0001dab0 c3e67c74 c3e67c48 7c40: c01ab89c c02807e0 00000ae8 00000000 c3e67c84 c3e67c60 c3d5a000 00000000 7c60: c3e67d30 00000235 c3e67cbc c3e67c78 c49b5ba5 c49b5ffc 00000ae8 c3e67d3c 7c80: 00000ab8 c3d5a030 00000001 c3e67d3c 00000fff c49b5000 c3e67cc4 c3e67ca8 7ca0: c01f12ec c0215aa8 00000000 00001000 c3e67d0c c0503090 c3e67cdc c3e67cc8 7cc0: c0518ec8 c05e86a0 c00515b8 c4169000 c3e67cf4 c3e67ce0 c004f41c c00be610 7ce0: c05e86a0 c41690a4 c3e67d0c c3e67cf8 c004f49c c004f380 c05e86a0 c3d5a000 7d00: c3e67d6c c3e67d10 c01a3f54 c005126c 00000001 00000001 c41690a4 00000020 7d20: 00056bf0 00000000 c3e67d54 00000057 000003fa 20000020 c3e67d64 c3e67d48 7d40: c004bf9c c004aa1c c004aa40 c3e66000 00000001 c05e86a0 c3e67d84 c3e67d68 7d60: c004bf9c c004aa1c c004aa40 c3e66000 00000001 00000020 c3e67dac c3e67d88 7d80: c004aa7c c004bf84 c3e67e0c c3e67dc8 c03b5550 c00aba20 00000000 c03b5550 7da0: c3e67dcc c3e67db0 c004bf9c c004aa1c c004aa40 c3e66000 00000001 00000000 7dc0: c3e67df4 c3e67dd0 c004aa7c c004bf84 c3e67e5c c3e67e10 c03b5550 c00bf89c 7de0: c05e86a0 00000000 c3e67e0c 00000003 c6b80000 c6b8d000 00000000 c05e86a0 7e00: c3e67e5c c3e67e10 c00bf920 c00a9b44 c37d9800 c37d98a0 00000000 00028000 7e20: 00000000 00000020 00000000 c3e67eac c3e67e64 c3e67eac bf008d2c beca5c0c 7e40: c3e66000 c00ce0a0 00000008 00000000 c3e66000 00000000 c3e67efc c3e67e68 7e60: bf00b068 bf009d58 c00ce0a0 beca5c0c c03b5550 00000000 c6b80000 beca5c4c 7e80: c3e67ea4 c3e67e90 c03b5550 c004aa4c c47bcc34 20000113 c3e67ebc c3e67ea8 7ea0: c0209700 c03b54a0 c46b2b00 00000000 00000000 c3e67ec0 c00909d4 c0209664 7ec0: c3e67f04 c3e67ed0 c03b5350 c00909d0 c6b80000 00000000 00000007 c3e37c00 7ee0: c3f381f0 beca5c0c 00000008 00000000 c3e67f74 c3e67f00 c00e3118 bf00a948 7f00: 00000001 c3ca0900 c3e67f3c c3e67f18 c004aa7c c004bf84 c3e67f74 c3e67f58 7f20: c03b5550 c00d56ac 00000000 c03b5550 c3e67f54 c3e67f40 c03b5550 c004aa4c 7f40: c3e37c00 00000000 c3e67f74 c3e67f58 c3e37c00 beca5c0c c00ce0a0 00000008 7f60: 00000000 c3e66000 c3e67fa4 c3e67f78 c00e31e4 c00e2bf8 c00e2070 00000001 7f80: 00000001 00000000 0007f344 000521d8 00000036 c00486c8 00000000 c3e67fa8 7fa0: c0048520 c00e3198 00000000 0007f344 00000008 c00ce0a0 beca5c0c 00000001 7fc0: 00000000 0007f344 000521d8 00000036 beca5c0c c00ce0a0 00000000 00000000 7fe0: 0007f65c beca5bd8 0002b404 402351cc 60000010 00000008 00000000 00000000 Backtrace: [<bf01e9bc>] (Cfg_prop+0x0/0xc0 [syslink]) from [<bf01ea98>] (Cfg_propBool+0x1c/0x74 [syslink])  r7:c3e67064 r6:bf0ad920 r5:c6b6b000 r4:c6b6b000 [<bf01ea7c>] (Cfg_propBool+0x0/0x74 [syslink]) from [<bf01d7ec>] (DM8168VPSSM3PROC_attach+0x58/0x34c [syslink])  r4:bf0ad920 [<bf01d794>] (DM8168VPSSM3PROC_attach+0x0/0x34c [syslink]) from [<bf0080e8>] (Processor_attach+0x50/0xac [syslink]) [<bf008098>] (Processor_attach+0x0/0xac [syslink]) from [<bf009e18>] (ProcMgr_attach+0xcc/0x1bc [syslink])  r6:c3e67078 r5:c3e67eac r4:c6b80000 [<bf009d4c>] (ProcMgr_attach+0x0/0x1bc [syslink]) from [<bf00b068>] (ProcMgrDrv_ioctl+0x72c/0x14d4 [syslink]) [<bf00a93c>] (ProcMgrDrv_ioctl+0x0/0x14d4 [syslink]) from [<c00e3118>] (do_vfs_ioctl+0x52c/0x5a0)  r8:00000000 r7:00000008 r6:beca5c0c r5:c3f381f0 r4:c3e37c00 [<c00e2bec>] (do_vfs_ioctl+0x0/0x5a0) from [<c00e31e4>] (sys_ioctl+0x58/0x7c)  r9:c3e66000 r8:00000000 r7:00000008 r6:c00ce0a0 r5:beca5c0c r4:c3e37c00 [<c00e318c>] (sys_ioctl+0x0/0x7c) from [<c0048520>] (ret_fast_syscall+0x0/0x30)  r8:c00486c8 r7:00000036 r6:000521d8 r5:0007f344 r4:00000000 Code: eb4793c9 e3500000 089da8f0 e2804001 (e5d40000)  [c6xdsp ] Remot---[ end trace e33c8e5f6ac5b06d ]--- e Debug Shared Memory @ 0xbff00000  [m3video] Remote Debug Shared Memory @ 0xbff05020  [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 INIT: Entering runlevel: 5  inside autorun PM: Adding info for No Bus:254:0 PM: Adding info for No Bus:sbulla  sbulla: unknown partition table Starting telnet daemonPM: Removing info for No Bus:254:0 PM: Removing info for No Bus:sbulla PM: Adding info for No Bus:254:0 PM: Adding info for No Bus:sbulla  sbulla: unknown partition table
  • 你好,
    请问两台出问题的机器的log是完全一样的错误么?出错的机器再断电,重启,能否正常工作?
  • 两台断电重启都不能恢复工作,
    使用PS查看状态,发现两台都有异常线程
    367 root       0:00 {exe} ash ./scripts/load_vpss.sh
    369 root       0:01 [fw_load.out]
    370 root       0:00 {exe} ash ./scripts/load_video.sh
    371 root       0:00 sh -c ./scripts/wait_cmd.sh s m3vpss
     372 root       0:00 {exe} ash ./scripts/wait_cmd.sh s m3vpss
    373 root       0:00 ./bin/fw_load.out startup VIDEO-M3 ./firmware/ipnc_rdk_fw
    374 root       0:11 ./bin/remote_debug_client.out 0xbff00000 --waitch s m3vps
    390 root       0:00 /usr/sbin/telnetd
    进行错误定位跟踪,是在执行函数loadDspCode中的system("./scripts/load_vpss.sh&")时,出现错误,
    用tftp去获取文件fw_load.out时会提示出错,感觉此文件已损坏。
    还有sys_server文件也损坏。
    root@dm814x-evm:/opt/ipnc# tftp -l sys_server -p 172.16.135.149 sys_server            29% |*********                      |   367k  0:00:02 ETAUBIFS error (pid 3863): ubifs_decompress: cannot decompress 1877 bytes, compressor lzo, error -22 UBIFS error (pid 3863): read_block: bad data node (block 252, inode 4732) UBIFS error (pid 3863): do_readpage: cannot read page 252 of inode 4732, error -22 tftp: read error
    还在进一步分析中,为什么会出现文件损坏,从哪些方面分析。
