电源芯片tps65910配置不正确,启动不了emmc
[ 1.555882] Registering SWP/SWPB emulation handler
[ 3.582770] omap_i2c 44e0b000.i2c: controller timed out
[ 3.588311] tps65910 0-002d: No interrupt support, no core IRQ
[ 4.612760] omap_i2c 44e0b000.i2c: controller timed out
[ 4.618065] tps65910 0-002d: Error in configuring SLEEP register
[ 4.624168] tps65910 0-002d: Failed to initialise ext control config
[ 6.642746] omap_i2c 44e0b000.i2c: controller timed out
[ 7.682746] omap_i2c 44e0b000.i2c: controller timed out
[ 9.722750] omap_i2c 44e0b000.i2c: controller timed out
[ 9.742753] tps65910 0-002d: Error in configuring external control EN1
[ 9.749335] tps65910 0-002d: Failed to initialise ext control config
[ 10.773255] vdd3: failed to enable
[ 10.776977] tps65910 0-002d: failed to register tps65910-pmic regulator
[ 10.784888] tps65910-pmic: probe of tps65910-pmic failed with error -121
[ 10.792597] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 10.883336] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517
[ 10.892130] cpu cpu0: cpu0 clock notifier not ready, retry
[ 10.899351] hctosys: unable to open rtc device (rtc0)
[ 10.912550] lis3_reg: disabling
[ 10.916025] vbat: disabling
