The Am335x uses MCASP0's TDM mode to read audio data from multiple codecs
Hello all,
As indicated in the title, the MCU is Am335x, I use MCASP0's AXR0, AXR1, ACLKX and FSX pins, which AXR0 is used for receiving,  and AXR1 is used for sending to read audio data from multiple codecs. The signals of the external multiple codec are converted into tdm format by a cpld, each frame includes 8 time slots.
My question is: can I use the kernel-drive ASOC framework to ahieve the requirement? If can't, how?   Thank you!
