6678开发板串口通信不能打印IP地址
When I start with the TMX320C6678 Evaluation Module following the QSG, all are OK till the step 4. The problem is that the IP address can not be printed on console.I have checked the mode  setting up and LEDs, the mode is right and the LED indicates the system has been booted successfully. Why the IP can not been printed on the console ?
