Dear TI engineer:
我在用flash tool烧写am3517的空板时,总是提示以下现象.我用的是sumsung k9f1g08的nand flash,根据配置文件,我修改了行列地址为2,2。容量也更改为了128M byte,用的cs0.我还有哪里没有配置对吗?请帮帮我。
-stdout
-omap 3
-no_force_package_alignment
-com 1
-t 60
-p CUSTOM_AM35XX_BOARD
-2
chip_download NANDINFO1BITBOOT D:\我的文档\桌面\AM3517-Debug\x-load.bin
Leaving parameter file:temp_script.txt
@temp_script.txt
Looking for device (omap com1)
Please turn off device, then turn it on again
Awaiting ASIC id
AsicId items 04
AsicId id 01 05 01 34 30 07 58
AsicId secure_mode 13 02 01 00
AsicId public_id 12 15 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
AsicId root_key_hash 14 15 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Searching 2nd for: CUSTOM_AM35XX_BOARD 343007 58 GP
Loading second file Targets\2nd-Downloaders\dnld_startup_omap3_gp_1g.2nd
Entering parameter file:omapflash2nd.txt at line: 7
-pheriphalboot_reopen
Reading board configuration file Targets\Configurations\configuration_custom_am35xx.txt
Reading definition file .\targets\definitions\definitions_omap3.txt
-board_config Targets\Configurations\configuration_custom_am35xx.txt
Leaving parameter file:omapflash2nd.txt
Sending size of second file (0x00006804 bytes)
Transferring second file to target (0x6804 bytes)
Closing boot connection
Found device (omap com1)
Waiting for 2nd
Found 2nd
Looking for a driver for 'NANDINFO1BITBOOT'
chip_driver NANDINFO1BITBOOT Targets\Flash-Drivers\nand_onfi_16bit_8bit.bin gpmc 0x6E000000 cs 0 address 0x30000000 bberase 0 onfi 0 bpp 2048 sbpp 64 ppb 64 bpl 1024 l 1 acv 0x22 f 0x0019 eTxp...
Downloading driver
Downloading 'Targets\Flash-Drivers\nand_onfi_16bit_8bit.bin'
Sending data (41008 bytes) :::::::::::::::..... [32764]
Sending data (41008 bytes) :::::::::::::::::::: [41008]
Interface 'OMAPFLASH DRIVER v5'
Driver 'NAND ONFI 16/8 BIT'
Driver configuration: gpmc = 0x6E000000
Driver configuration: cs = 0x00000000
Driver configuration: address = 0x30000000
Driver configuration: bberase = 0x00000000
Driver configuration: onfi = 0x00000000
Driver configuration: bpp = 0x00000800
Driver configuration: sbpp = 0x00000040
Driver configuration: ppb = 0x00000040
Driver configuration: bpl = 0x00000400
Driver configuration: l = 0x00000001
Driver configuration: acv = 0x00000022
Driver configuration: f = 0x00000019
Driver configuration: eccoffset = 0x00000002
NAND HW ECC
NAND BCH Mode = 0
NAND HWECC offset = 2, size = 12
NAND NONEv0 VENDOR 0x00 UNKNOWN
NAND 16 BIT DEVICE 0x00 UNKNOWN
NAND NAND CYCLES 0x22 (2 ROW, 2 COLUMN)
NAND 2048 BYTES/PAGE (SPARE 64)
NAND 64 PAGES/BLOCK (131072 BYTES/BLOCK)
NAND 1024 BLOCKS/UNIT (134217728 BYTES/UNIT)
NAND 0 BIT(S) ECC REQUIRED
NAND 128 MB TOTAL SIZE
NAND ONFI DRIVER INIT COMPLETE
Downloading complete
Elapsed time: 0:04.031 (10252 bytes/s)
End loading driver
Downloading
Downloading 'D:\我的文档\桌面\AM3517-Debug\x-load.bin'
Sending data (16616 bytes) :::::::::::::::::::: [16616]
NAND BAD BLOCK AT ADDRESS 0x00000000
NAND BAD BLOCK DURING WRITE AT 0x00000000
NAND BAD BLOCK AT ADDRESS 0x00020000
NAND BAD BLOCK DURING WRITE AT 0x00020000
NAND BAD BLOCK AT ADDRESS 0x00040000
NAND BAD BLOCK DURING WRITE AT 0x00040000
NAND BAD BLOCK AT ADDRESS 0x00060000
NAND BAD BLOCK DURING WRITE AT 0x00060000
NAND BAD BLOCK AT ADDRESS 0x00080000
NAND BAD BLOCK DURING WRITE AT 0x00080000
NAND BAD BLOCK AT ADDRESS 0x000A0000
NAND BAD BLOCK DURING WRITE AT 0x000A0000
NAND BAD BLOCK AT ADDRESS 0x000C0000
NAND BAD BLOCK DURING WRITE AT 0x000C0000
NAND BAD BLOCK AT ADDRESS 0x000E0000
NAND BAD BLOCK DURING WRITE AT 0x000E0000
NAND BAD BLOCK AT ADDRESS 0x00100000
NAND BAD BLOCK DURING WRITE AT 0x00100000
NAND BAD BLOCK AT ADDRESS 0x00120000
NAND BAD BLOCK DURING WRITE AT 0x00120000
NAND BAD BLOCK AT ADDRESS 0x00140000
NAND BAD BLOCK DURING WRITE AT 0x00140000
NAND BAD BLOCK AT ADDRESS 0x00160000
NAND BAD BLOCK DURING WRITE AT 0x00160000
NAND BAD BLOCK AT ADDRESS 0x00180000
NAND BAD BLOCK DURING WRITE AT 0x00180000
NAND BAD BLOCK AT ADDRESS 0x001A0000
NAND BAD BLOCK DURING WRITE AT 0x001A0000
NAND BAD BLOCK AT ADDRESS 0x001C0000
NAND BAD BLOCK DURING WRITE AT 0x001C0000
NAND BAD BLOCK AT ADDRESS 0x001E0000
NAND BAD BLOCK DURING WRITE AT 0x001E0000
NAND BAD BLOCK AT ADDRESS 0x00200000
NAND BAD BLOCK DURING WRITE AT 0x00200000
NAND BAD BLOCK AT ADDRESS 0x00220000
NAND BAD BLOCK DURING WRITE AT 0x00220000
NAND BAD BLOCK AT ADDRESS 0x00240000
NAND BAD BLOCK DURING WRITE AT 0x00240000
NAND BAD BLOCK AT ADDRESS 0x00260000
NAND BAD BLOCK DURING WRITE AT 0x00260000
NAND BAD BLOCK AT ADDRESS 0x00280000
NAND BAD BLOCK DURING WRITE AT 0x00280000
NAND BAD BLOCK AT ADDRESS 0x002A0000
NAND BAD BLOCK DURING WRITE AT 0x002A0000
NAND BAD BLOCK AT ADDRESS 0x002C0000
NAND BAD BLOCK DURING WRITE AT 0x002C0000
NAND BAD BLOCK AT ADDRESS 0x002E0000
NAND BAD BLOCK DURING WRITE AT 0x002E0000
NAND BAD BLOCK AT ADDRESS 0x00300000
NAND BAD BLOCK DURING WRITE AT 0x00300000
NAND BAD BLOCK AT ADDRESS 0x00320000
NAND BAD BLOCK DURING WRITE AT 0x00320000
NAND BAD BLOCK AT ADDRESS 0x00340000
NAND BAD BLOCK DURING WRITE AT 0x00340000
NAND BAD BLOCK AT ADDRESS 0x00360000
NAND BAD BLOCK DURING WRITE AT 0x00360000
NAND BAD BLOCK AT ADDRESS 0x00380000
NAND BAD BLOCK DURING WRITE AT 0x00380000
NAND BAD BLOCK AT ADDRESS 0x003A0000
NAND BAD BLOCK DURING WRITE AT 0x003A0000
NAND BAD BLOCK AT ADDRESS 0x003C0000
NAND BAD BLOCK DURING WRITE AT 0x003C0000
NAND BAD BLOCK AT ADDRESS 0x003E0000
NAND BAD BLOCK DURING WRITE AT 0x003E0000
NAND BAD BLOCK AT ADDRESS 0x00400000
NAND BAD BLOCK DURING WRITE AT 0x00400000
NAND BAD BLOCK AT ADDRESS 0x00420000
NAND BAD BLOCK DURING WRITE AT 0x00420000
NAND BAD BLOCK AT ADDRESS 0x00440000
NAND BAD BLOCK DURING WRITE AT 0x00440000
NAND BAD BLOCK AT ADDRESS 0x00460000
NAND BAD BLOCK DURING WRITE AT 0x00460000
NAND BAD BLOCK AT ADDRESS 0x00480000
NAND BAD BLOCK DURING WRITE AT 0x00480000
NAND BAD BLOCK AT ADDRESS 0x004A0000
NAND BAD BLOCK DURING WRITE AT 0x004A0000
NAND BAD BLOCK AT ADDRESS 0x004C0000
NAND BAD BLOCK DURING WRITE AT 0x004C0000
NAND BAD BLOCK AT ADDRESS 0x004E0000
NAND BAD BLOCK DURING WRITE AT 0x004E0000
NAND BAD BLOCK AT ADDRESS 0x00500000
NAND BAD BLOCK DURING WRITE AT 0x00500000
NAND BAD BLOCK AT ADDRESS 0x00520000
NAND BAD BLOCK DURING WRITE AT 0x00520000
NAND BAD BLOCK AT ADDRESS 0x00540000
NAND BAD BLOCK DURING WRITE AT 0x00540000
Console program aborted or crashed, exit code: 62097
www.deyisupport.com/.../45858.aspx
作者 Qi Fu 发表于 2012-9-15 6:01
AM3517板整个开发过程记录
你可以在这里找到答案
f 0x0019改为0x0018去试试吧
