BIOS IPC notify例程报错ti.sdo.ipc.Notify: line 325: assertion failure: A_invArgument: Invalid argument supplied xdc.runtime.Error.raise: terminating execution
IPC例程与网口例程合并,cfg文件中内存分配是不是有冲突?
下面是我自己合并的cfg文件,求指教,非常感谢!!!
 * helloWorld.cfg
 * Memory Map and Program intiializations for the helloWorld example Utility
 * Copyright (C) 2010-2011 Texas Instruments Incorporated - http://www.ti.com/
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 *    Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *    its contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *   @file  helloWorld.cfg
 *   @brief
 *      Memory Map and Program intiializations for the HPDSP Utility.
*  Specify all needed RTSC MOudles and ocnfigure them.																*
var Memory  =   xdc.useModule('xdc.runtime.Memory');
var BIOS    =   xdc.useModule('ti.sysbios.BIOS');
var Task    =   xdc.useModule('ti.sysbios.knl.Task');
var HeapBuf =   xdc.useModule('ti.sysbios.heaps.HeapBuf');
var Log     =   xdc.useModule('xdc.runtime.Log');
** Allow storing of task names. By default if you name a task with a friendly display name it will not be saved
** to conserve RAM. This must be set to true to allow it. We use friendly names on the Task List display.
//Defaults.common$.namedInstance = true;
Task.common$.namedInstance = true;
var Clock   =   xdc.useModule ('ti.sysbios.knl.Clock');
** Interface with IPC. Depending on the version of BIOS you are using the
** module name may have changed.
/* Use this for pre BIOS 6.30 */
/* var Sem	    =	  xdc.useModule ('ti.sysbios.ipc.Semaphore'); */
/* Use this for BIOS 6.30 plus to get the IPC module */
var Sem	= xdc.useModule ('ti.sysbios.knl.Semaphore');
var Hwi	= xdc.useModule ('ti.sysbios.hal.Hwi');
var Ecm = xdc.useModule ('ti.sysbios.family.c64p.EventCombiner');
** Configure this to turn on the CPU Load Module for BIOS.
var Load       =   xdc.useModule('ti.sysbios.utils.Load');
Load.common$.diags_USER4 = Diags.ALWAYS_ON;
var Diags       = xdc.useModule('xdc.runtime.Diags');
/* Load the CSL package */
var Csl 					    = 	xdc.useModule('ti.csl.Settings');
/* Load the CPPI package */
var Cppi                        =   xdc.loadPackage('ti.drv.cppi');
/* Load the QMSS package */
var Qmss                        =   xdc.loadPackage('ti.drv.qmss');
/* Load the PA package */
var Pa 							= 	xdc.useModule('ti.drv.pa.Settings');
/* Load the Platform/NDK Transport packages */
var PlatformLib  = xdc.loadPackage('ti.platform.evmc6678l');
var NdkTransport = xdc.loadPackage('ti.transport.ndk');
** Sets up the exception log so you can read it with ROV in CCS
var LoggerBuf = xdc.useModule('xdc.runtime.LoggerBuf');
var Exc = xdc.useModule('ti.sysbios.family.c64p.Exception');
Exc.common$.logger = LoggerBuf.create();
Exc.enablePrint = true; /* prints exception details to the CCS console */
**  Give the Load module it's own LoggerBuf to make sure the
**  events are not overwritten.
/* var loggerBufParams = new LoggerBuf.Params();
loggerBufParams.exitFlush = true;
loggerBufParams.numEntries = 64;
Load.common$.logger = LoggerBuf.create(loggerBufParams);
** Use this load to configure NDK 2.2 and above using RTSC. In previous versions of
** the NDK RTSC configuration was not supported and you should comment this out.
var Global       = xdc.useModule('ti.ndk.config.Global');
** This allows the heart beat (poll function) to be created but does not generate the stack threads
** Look in the cdoc (help files) to see what CfgAddEntry items can be configured. We tell it NOT
** to create any stack threads (services) as we configure those ourselves in our Main Task
** thread hpdspuaStart.
Global.enableCodeGeneration = false;
//Cache.MAR224_255 = 0x0000000f;
var Startup     =   xdc.useModule('xdc.runtime.Startup');
var System      =   xdc.useModule('xdc.runtime.System');
** Create a Heap.
var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
var heapMemParams = new HeapMem.Params();
heapMemParams.size = 0x200000;
heapMemParams.sectionName = "systemHeap";
Program.global.heap0 = HeapMem.create(heapMemParams);
/* This is the default memory heap. */
Memory.defaultHeapInstance  =   Program.global.heap0;
Program.sectMap["sharedL2"] = "L2SRAM";
Program.sectMap["systemHeap"] = "MSMCSRAM";
Program.sectMap[".sysmem"]  = "MSMCSRAM";
Program.sectMap[".args"]    = "MSMCSRAM";
Program.sectMap[".cio"]     = "MSMCSRAM";
Program.sectMap[".far"] 	= 	"DDR3";
Program.sectMap[".rodata"] 	= 	"MSMCSRAM";
Program.sectMap[".neardata"] 	= 	"MSMCSRAM";
Program.sectMap[".cppi"] 	= 	"L2SRAM";
Program.sectMap[".init_array"] 	= 	"MSMCSRAM";
Program.sectMap[".qmss"] 	= 	"L2SRAM";
Program.sectMap[".cinit"] 	= 	"L2SRAM";
Program.sectMap[".bss"]		=	"MSMCSRAM";
Program.sectMap[".const"]	=	"MSMCSRAM";
Program.sectMap[".text"]	=	"MSMCSRAM";
Program.sectMap[".code"]	=	"MSMCSRAM";
Program.sectMap[".switch"]	=	"L2SRAM";
Program.sectMap[".data"]	=	"MSMCSRAM";
Program.sectMap[".fardata"] = 	"L2SRAM";
Program.sectMap[".cio"] 	= 	"L2SRAM";
Program.sectMap[".vecs"] 	= 	"L2SRAM";
Program.sectMap["platform_lib"] 	= 	"MSMCSRAM";
Program.sectMap[".far:taskStackSection"] = "L2SRAM";
Program.sectMap[".stack"]	=	"MSMCSRAM";
Program.sectMap[".nimu_eth_ll2"] = "L2SRAM";
Program.sectMap[".resmgr_memregion"] = {loadSegment: "L2SRAM", loadAlign:128};	/* QMSS descriptors region 	*/
Program.sectMap[".resmgr_handles"] = {loadSegment: "L2SRAM", loadAlign:16};	/* CPPI/QMSS/PA Handles			*/
Program.sectMap[".resmgr_pa"]	= {loadSegment: "L2SRAM", loadAlign:8};		/* PA Memory					*/
Program.sectMap[".far:NDK_PACKETMEM"] = {loadSegment: "MSMCSRAM", loadAlign: 128};
/* Required if using System_printf to output on the console */
SysStd          		=   xdc.useModule('xdc.runtime.SysStd');
System.SupportProxy     =   SysStd;
* Define hooks and static tasks  that will always be running.               										*
** Register an EVM Init handler with BIOS. This will initialize the hardware. BIOS calls before it starts.
** If you are debugging with CCS, then this function will execute as CCS loads it if the option in your
** Target Configuraiton file (.ccxml) has the option set to execute all code before Main. That is the
** default.
Startup.lastFxns.$add('&EVM_init');
Startup.lastFxns.$add('&board_init');
** Create the stack Thread Task for our application.
Program.global.GE_communication = Task.create("&task_NDK_stack");
Program.global.GE_communication.stackSize = 262144;
Program.global.GE_communication.priority = 5;
** Create a Periodic task to handle all NDK polling functions.
** If you are using RTSC configuration with NDK 2.2 and above, this is done by default and
** you do not need to do this.
/*var prdNdkClkParams         =   new Clock.Params ();
prdNdkClkParams.period      =   0x64;
prdNdkClkParams.startFlag   =   true;
Program.global.clockInst1   =   Clock.create("&llTimerTick", 5, prdNdkClkParams);
** If you are using RTSC configuration with NDK 2.2 and above, this is done by default, else
** register hooks so that the stack can track all Task creation
Task.addHookSet ({ registerFxn: '&NDK_hookInit', createFxn: '&NDK_hookCreate', });
/* Enable BIOS Task Scheduler */
BIOS.taskEnabled			=   true;
 * Enable Event Groups here and registering of ISR for specific GEM INTC is done
 * using EventCombiner_dispatchPlug() and Hwi_eventMap() APIs
Ecm.eventGroupHwiNum[0] = 7;
Ecm.eventGroupHwiNum[1] = 8;
Ecm.eventGroupHwiNum[2] = 9;
Ecm.eventGroupHwiNum[3] = 10;
Memory.defaultHeapSize = 16384;
Sem.supportsEvents = false;
Program.stack = 65536;
Program.heap = 32768;
var task4Params = new Task.Params();
task4Params.instance.name = "main_work";
task4Params.stackSize = 32768;
task4Params.priority = 6;
Program.global.main_work = Task.create("&SYS_work", task4Params);
Program.global.GE_communication.instance.name = "GE_communication";
var hwi3Params = new Hwi.Params();
hwi3Params.instance.name = "Hwi13_CIC0_out_32";
hwi3Params.eventId = 21;
Program.global.Hwi13_CIC0_out_32 = Hwi.create(13, "&ISR_uart_rx", hwi3Params);
var hwi4Params = new Hwi.Params();
hwi4Params.instance.name = "Hwi7_SRIO";
hwi4Params.eventId = 20;
Program.global.Hwi7_SRIO = Hwi.create(11, "&ISR_srio_doorbell", hwi4Params);
var task2Params = new Task.Params();
task2Params.instance.name = "sort_reset";
task2Params.priority = 4;
Program.global.sort_reset = Task.create("&signal_sort_reset", task2Params);
//music
var MultiProc = xdc.useModule('ti.sdo.utils.MultiProc');
/* Modules explicitly used in the application */
var Notify      = xdc.useModule('ti.sdo.ipc.Notify');
var MessageQ    = xdc.useModule('ti.sdo.ipc.MessageQ');
var HeapBufMP   = xdc.useModule('ti.sdo.ipc.heaps.HeapBufMP');
var Ipc         = xdc.useModule('ti.sdo.ipc.Ipc');
/* To avoid wasting shared memory for MessageQ transports */
for (var i = 0; i < MultiProc.numProcessors; i++) {
    Ipc.setEntryMeta({
        remoteProcId: i,
        setupMessageQ: true,
/* Synchronize all processors (this will be done in Ipc_start) */
Ipc.procSync = Ipc.ProcSync_ALL;
 *  Need to define the shared region. The IPC modules use this
 *  to make portable pointers. All processors need to add this
 *  call with their base address of the shared memory region.
 *  If the processor cannot access the memory, do not add it.
var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
/* Shared Memory base address and length */
var SHAREDMEM_0           = 0x0c370000;
var SHAREDMEMSIZE_0       = 0x00020000;
SharedRegion.translate = true; // 是否需要进行地址转换
/*SharedRegion.setEntryMeta(0,  // 区域ID
    { base: SHAREDMEM_0,        // 基地址
      len:  SHAREDMEMSIZE_0,    // 区域大小
      ownerProcId: 0,         // 所有者的核ID
      isValid: true,          // 对于当前核,该区域是否有效
      name: "DDR2_RAM_0",       // 区域名称
/* Create a semaphore with count 0 */
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
Program.global.semHandle = Semaphore.create(0);
var task3Params = new Task.Params();
task3Params.instance.name = "task3";
Program.global.task3 = Task.create("&tsk0_func", task3Params);
var execontextInstance0 = xdc.lookup('xdc.platform.ExeContext.Instance#0');
execontextInstance0.memoryMap["MSMCSRAM"].len = 16777216;
